Configuring web clipper field types and default values
  • 04 Oct 2022
  • 2 Minutes to read
  • Dark
    Light
  • Dark
    Light
The web clipper currently supports several field types and different default values can be configured depending on what those field types are.
Note that many websites have terms of service restricting you from capturing information from their sites. Please always review and adhere to the terms of service of those sites before using the Airtable web clipper on any page you visit.
Text-based fields
Single line text, long text, phone numbers, email and URL fields are all supported field types. When configuring the default values for these field types, you have the following choices:
  • None (no initial value)
  • Page title (e.g. “Airtable Universe”)
  • Page URL (e.g. https://airtable.com/universe)
  • Selected text (text highlighted on the page at the time that the web clipper button was clicked)
  • CSS selector (e.g. .inline.t-24.t-black.t-normal.break-words)
In the web clipper browser extension, any configured default value will be automatically populated as soon as you open the clip action. You can choose to override the default value by typing your own values.
blobid39
Select fields
Both single select fields and multiple select field types are supported. When configuring the default values for these field types, you have the following choices:
Within the web clipper browser extension, the select field options will have the same colors that you defined in the field configuration.
blobid40
blobid41
Number-based fields
Number, currency, and percent fields are all supported field types. When configuring the default values for these field types, you have the following choices:
As you type a number in the web clipper extension, any formatting (decimal places, percent signs, currency symbols) will be applied when you move to another field.
web-clipper-numbers
Collaborator fields
Adding a collaborator field to your clip action allows you to select one of the collaborators in your base for the record. When configuring the default values for this field type, you have the following choices:
Your selections in the web clipper browser extension have the collaborator name and image just like they appear in the Airtable UI.
blobid13
Attachment fields
You can use an attachment field to capture one or multiple images from a web page. When configuring the default values for this field types, you have the following choices:
  • Social media image (first image on the page)
In the web clipper browser extension, the image will be automatically added if you have a default value configured. You can override the default value or add new images on the extension using one of three image field inputs.
blobid44
The currently supported attachment field inputs are:
  • Add screenshot, which will allow you to capture a selected portion of your screen by clicking and dragging your cursor to highlight a rectangular section of the web page
  • Add page screenshot, which will capture a full-page screenshot of the web page you’re currently on.
  • Add image from page, which will capture an image by clicking on it. As you mouse over images, the image will be highlighted in blue if it can be selected
Was this article helpful?
