Vision extension
Plan Availability
All paid plans
Permissions
  • Owners / Creators - Can create, delete, and modify extensions
  • Editors - Can edit the configuration of previously configured extensions
Platform(s)
If you have an attachment field, the Cloud Vision API can quickly classify your images into thousands of categories, and you can extract those labels and save them to a field in your table—meaning that you can tag hundreds of images with just a few clicks. You can also identify logos, or use optical character recognition (OCR) to extract text from images.
Adding a Vision extension
  2. Create or open the base where you want to install the vision extension.
  3. Click Tools in the upper-right corner.
  4. Click the Extensions option.
  5. Click Add an extension.
  6. Search for and locate the vision extension.
  7. Click Add, then Add extension.
  8. Click Get started and follow the on-screen prompt to create a Google Cloud project and an API key.
Using the vision extension
After adding a vision extension:
  1. Click Use Vision.
  2. Select your preferred table, view, and attachment field.
  3. Click Done.
  4. Select your preferred features to extract.
  5. Click Analyze, then Start.
  6. Select your preferred labels, logos, or text.
  7. Click Save.
