Setting up custom domains for bases in Airtable
Plan availability
Enterprise Scale plans
Permissions
Enterprise admins
Platform(s)
Custom domains overview
Custom domains are base-scoped. This means 1 custom domain can host 1 base.
Custom domains allow you to replace Airtable’s domain (Airtable.com) with your own branding (Example-my-company.com), giving bases a more custom look and providing a branded experience for your collaborators.
The custom domains beta is only available for Enterprise admins on Enterprise Scale plans.
To set up a custom domain:
  1. Open your admin panel.
  2. Click Bases.
  3. Locate the base where you want to add a custom domain.
  4. Click Edit to the right of the base’s name.
  5. Enter the domain URL.
  6. Click Add Domain.
    • The message "We're preparing the DNS records you'll need to add to your domain provider. Check back in a few minutes." appears while your custom domain is being configured.
  7. Log in to your DNS provider once your records are available, and paste the CNAME records.
    • This step may vary depending on which DNS provider you use.
    • Please submit your questions or feedback if you're experiencing issues during the custom domain setup process.
  8. Custom domains typically verify within a few hours, but can take up to 48 hours depending on your DNS provider. Once your custom domain is active, the message "Custom domain is successfully configured and active" appears.
  9. Visit your custom domain’s URL to confirm your custom domain is active.
FAQs
Why am I seeing the “Your connection is not private” error?
If you're seeing the "Your connection is not private" error, then review the status of your custom domain. It might take some time for SSL certificates to be generated and attached. Please get in touch with our support team if you have additional questions.
Why does my custom domain's status show "Successful" while I'm still receiving the "Your connection is not private" error?
If your custom domain status is "Successful," your new certificates have been installed on our end. We recommend confirming your DNS settings include the “.” when copying your CNAME records.
Keep in mind that different providers like GoDaddy, Route 53, etc, may have different setups with things like:
  • Trailing “.” in CNAME records
  • Restrictions on ALIAS / A records and apex domains
Can I add an apex domain?
While apex domains are unsupported during the custom domains beta, they'll be available in the future.
Why is my custom domain still not verified after adding CNAME records?
Your domain may still be unverified because you potentially have a CAA record that blocks certificate issuance. If you use CAA records, make sure they authorize at least one of the following: amazon.com, amazontrust.com, awstrust.com, amazonaws.com.
Your proxy is enabled on the CNAME record that points to *.acm-validations.aws via Cloudflare. Please ensure this record is not proxied. You may still proxy the other CNAME records that point to domains.airtable.com if desired, as this has no impact on domain verification.
What is the login experience for end users when using SSO on custom domains?
Custom domain SSO has to go through airtable.com before connecting with identity providers. This can seem like a "loop" but the additional airtable.com hop is currently needed to support the function. As long as a user continues through the sign in flow, they will be able to reach the target page.
