Using logical operators to compare field values in Airtable
Plan Availability
All plan types
Permissions
  • Owner / Creator - Can add, delete, duplicate, rename, and customize fields
  • Editors - Sort, filter, group, hide, and copy field URL
  • Commenters / Read-only - Copy field URL
Platform(s)
Web/Browser, Mac app, and Windows app (with some additional limited support on mobile)
Understanding logical operators in Airtable
Logical operators allow you to compare values in one field to other fields. See the operators listed below for an introduction to their symbols and usage.
Operator
Symbol
Use
Example
Greater than
Compare if one number is greater than another
IF(5 > 5 ...
Less than
Compare if one number is less than another
IF(5 > 5 ...
Greater than or equal to
Compare if one number is greater than or equal to another
IF({Field A} >= {Field B} ...
Less than or equal to
Compare if one number is less than or equal to another
IF({Field A} = {Field B} ...
Equal to
Compare if one value is equal to another value
5 = 5
Does not equal
Check if one value is not equal to another value
IF({Field A} != {Field B} ...
Greater and less than operators
For the following examples, assume that you want to compare income against expenses on a weekly basis.
  • Greater than - First, check if income is greater than expenses. If income is greater than expenses, the result of the formula will be a 1 (meaning true), and if not, a 0 (meaning false).
    • Example formula: {Income} > {Expenses}
  • Less than - Now, check if income is less than expenses. If income is less than expenses, the result of the formula will be a 1, and if not, a 0.
    • Example formula: {Income} < {Expenses}
Greater, less than, and equal to operators
  • Greater than or equal to - Similar to the formulas above, we can compare if income is greater than or equal to expenses (still returning a 1 or 0). The difference is most obvious in the below table when the Income and Expenses are equal—the formula returns 1.
    • Example formula: {Income} >= {Expenses}
  • Less than or equal to - Now we can check the opposite, let's compare if income is less than or equal to expenses by changing the operator.
    • Example formula: {Income} <= {Expenses}
Equal and does not equal to operators
  • Equal - Check if income is exactly equal to expenses.
    • Example formula: {Income} = {Expenses}
  • Does not equal - Likewise, we can check if a value is not equal to another by adding “!” before the “=” icon.
    • Example formula: {Income} != {Expenses}
