Managing and organizing extensions on a base
Last updated: August 11, 2026
Plan Availability
All paid plans
Permissions
  • Owners / Creators - Can create, delete, and modify extensions
  • Editors - Can edit the configuration of previously configured extensions
Platform(s)
Managing extensions in Airtable
To manage an extension:
  2. Open the base where you want to manage an extension.
  3. Click Tools in the upper-right corner.
  4. Click Extensions.
  5. Click the dropdown next to the name of an extension that you want to manage.
  6. The settings window allows you to manage the following options:
    1. Rename extension
    2. Edit extension
    3. Share an extension
    4. Manage its settings
    5. Reload the extension
    6. View the extension’s description (About this extension)
    7. Duplicate the extension
    8. Move the extension
    9. Disable the extension
    10. Delete the extension
To bulk manage extensions:
  5. Click the dropdown arrow next to the name of the dashboard.
  6. Click Manage extensions.
Viewing extensions
  2. Open the base where you want to view an extension.
  5. Here, you will find a dashboard of one or more extensions.
    1. If there is more than one dashboard of extensions, then you can switch to another extensions dashboard by clicking the dropdown arrow next to the name of the dashboard and selecting a different dashboard.
    2. You can also expand an individual extension to fill the whole screen by hovering over that extension and clicking the expand button.
Rearranging extensions
You can either rearrange extensions by moving them within the same dashboard or into another dashboard.
Moving an extension within the same dashboard:
  1. From the extensions dashboard, click the dropdown arrow next to the name of the dashboard.
  2. Hover over the extension and click the six dot icon.
  3. Drag and drop the extension into your preferred location within the dashboard.
Moving an extension to another dashboard:
  1. From the extensions dashboard, click the dropdown arrow next to the name of the extension you want to move.
  2. Click Move to another dashboard.
  3. Click the dropdown menu and click another dashboard or click Create a new dashboard…
  4. Click Move extension.
Creating and modifying dashboards
To add a new dashboard:
  5. On the left of the dashboard, you'll see the name of your current dashboard. Click the dropdown arrow to the right of the name, and click + Add a dashboard.
To rename or delete a dashboard, click on the three dot icon near the + Add an extension button. Click Rename dashboard or Delete dashboard.
Managing all base extensions
The extensions management window allows base Owners and Creators to:
  • Disable or enable extensions (Bulk enabling extensions is also possible)
  • Add new extensions
  • Search for existing extensions
  • See the Extension name, Extension type, Dashboard location, Added by, Added on, and Status for each extension within the base
  • Rename an extension, edit an extension's description, learn more about an extension, duplicate an extension, move an extension to another dashboard, and delete an extension.
To see and manage all of the extensions in a base:
  1. Click on Tools in the upper-right corner of the base where you want to create the extension.
  2. Click the Extensions option.
  3. Click the drop-down next to the name of the dashboard.
  4. Click Manage extensions. This will open the extensions management window.
To bulk enable disabled extensions:
  1. From the extensions management window. click the checkbox next to any of the disabled extensions you would like to enable and
  2. Then click the "Enable x extensions" button in the upper-right portion of the window.
  3. Additional options can be found by clicking the "..." three-dot icon to the far right of each extension.
Deleting extensions from Builder Hub
You can delete custom extensions directly from the Builder Hub extensions list. This is useful when you want to remove an extension without opening the base where it lives.
To delete an extension from Builder Hub:
  2. Click your account name or avatar in the upper-right corner and select Builder Hub.
  3. In Builder Hub, click the Extensions tab.
  4. Locate the extension you want to delete.
  5. Click the extension's options menu (the … icon) and select Delete.
  6. Confirm the deletion when prompted.
Deleting an extension from Builder Hub removes it from every base where it was installed. This action cannot be undone. Only the extension's creator or a base Owner can delete it.
