Comparing dates using conditional statements in Airtable
Plan availability
All plan types
Permissions
  • Owner /Creator - Have access to all field configuration options. Additionally everything editors, commenters, or read-only users can do.
  • Editor - Can sort by, filter by, group by, or hide the field within a view.
  • Commenter / Read-only - Copy a field's URL
Platform(s)
This article covers how to compare dates using conditional statements in Airtable formula fields.
Comparing dates against one another
Using an IF statement is a quick way to compare two dates. The formula below will compare both dates, and return the second date only if it is greater than the first date, and otherwise show a blank value.
IF({Date 2} > {Date 1}, {Date 2},BLANK())
Output values depending on date comparisons
For another approach, you may want to measure the days between the current date and time, and a static date field (like the date the invoice was billed). Adding in a conditional IF statement allows you to do the following:
  • If the payment received field is empty
  • And the days passed between the current day and the day the invoice was billed is more than 25 days
  • Then output a message to send the customer a reminder
  • And if none of the above is true, output a blank value
  AND({Payment Received}=BLANK(),
   DATETIME_DIFF(NOW(),
    {Invoice Billed},
     'days') > 25),
   "Send customer reminder"
