Using Airtable templates
Plan availability | All plan types/levels |
Permissions | Owner/Creator - You’ll need at least owner or creator permissions in at least one workspace in order to create a new base from a template. |
Platform(s) | Web/Browser, Mac app, and Windows app |
Related reading |
We recommend using Omni to experience a more customized app building experience.
Using templates in Airtable
To use an Airtable template:
Visit the Airtable Templates gallery.
Search for and select your preferred template.
You can also browse templates by selecting a preferred use case, industry, or feature.
Select a template that might fit your use case to reveal a visual example and written overview of what the template accomplishes. Then, click Use template.
Select your preferred workspace, then click Add base.
Clearing sample data included in templates
To clear the data included in Airtable templates:
Visit your Airtable homepage.
Open your preferred template base.
Click Restart from scratch in the bottom right corner.
Note that if you close out of the sidebar shown on the right, then you will not be able to find this option at a later time.
To clear the template data another way:
Click the ˅ icon next to your table’s name.
Click Clear data.
Select Clear data for confirmation.
FAQs
How are Airtable Universe and templates different from each other?
Airtable Universe differs from our official templates in that the bases on Airtable Universe are created and published by Airtable users. In contrast, our templates are developed and managed by the Airtable team.
