Using Omni AI in Airtable
Plan availability
All plan types
Permissions
Platform(s)
Related reading
Guide: Accelerate your work with Airtable AI
AI credits and enabling Airtable AI are required to use Omni to its full extent.
What is Airtable’s Omni AI?
Omni is the AI assistant built into Airtable. It helps you build apps, research the web, analyze data and documents, create and update records, and answer questions - all through natural language conversation. Both builders and end users can use Omni to work with the core functions of Airtable.
Omni keeps improving as the AI models it runs on improve. Omni takes on bigger, multi-step jobs: it plans the work, carries it through from start to finish instead of handling one request at a time, and tells you what it changed along the way.
How to turn on or disable Airtable AI
  • This section covers the general steps taken to enable or disable AI features at the workspace level. To adjust AI integration settings from the admin panel level, consult this section in the admin panel settings article.
  • Workspace Owner permissions are required to turn on or off AI workspace settings.
    • By default, Airtable AI is automatically enabled for all plans including legacy plans.
    • This is not true for our EU / GDPR customers, who may choose to turn on Airtable AI features by choice instead.
To turn on or off your Airtable AI workspace settings:
  1. Open your Airtable account page.
  2. Select the workspace where you want to turn on or off AI under the “Workspace settings” section.
  3. Navigate to the “Workspace AI permissions” section.
  4. Toggle on or off the “Turn on Airtable AI for all bases within this workspace” setting.
Accessing Omni in Airtable
From a base:
  1. Open the base where you want to use Omni.
  2. Click the Omni icon on the upper-left corner of the screen.
From an interface:
  1. Open the interface where you want to use Omni.
  2. Click the Omni icon in the lower-right corner of the interface.
From the homescreen:
  1. Open your homescreen.
  2. Click + Create in the lower-right corner of the page.
  3. Click Build an app with Omni.
  • In interfaces, Omni cannot use conditional visibility rules on data that the user can see, like if the interface is configured to hide field X unless field Y has value Z.
  • The "Allow Omni to create, update, and delete data for interface-only collaborators" setting defaults to "On". Turning this setting "Off" removes the ability for interface-only collaborators to create, update, and delete data.
Understanding Omni’s capabilities
Using plain language requests, there are several ways to use Omni. The options below are some common examples of how you can use Omni to work more efficiently in Airtable.
  1. Ask
    1. Ask Omni a question about the data in your base.
    2. Ask Omni to search the internet for an answer to a question you have, or to pull what you need from a webpage you link.
    3. Upload a file and ask Omni about it - for example, which people in a spreadsheet aren’t in your contacts table yet.
  2. Analyze
    1. Have Omni read all of the data in a table or field to find patterns, themes, and insights.
    2. Have Omni turn your data into a report you can share.
  3. Build, create, or edit
    1. Tell Omni to create or update parts of your base:
      1. New tables, and table names and descriptions
      2. New fields and changes to existing fields - this includes traditional field types as well as AI fields
      3. New records, and updates to or deletions of the records you point to
    2. Tell Omni to create interfaces.
      1. AI-generated interface elements: When you ask Omni to build an interface or interface element, it creates custom visualizations and layouts using AI. For more details, see our AI-generated interface elements in Airtable article.
      2. Traditional interface pages: Omni can create native interface pages built in Interface Designer, such as list layouts. It cannot create Gantt or blank page layouts - these must be created manually.
      3. Dashboards: Omni can add pages with the charts and numbers you care about, like deals by stage and total pipeline.
    3. Tell Omni to create a new automation, update an existing one, or explain what your automations do. Omni leaves a new automation turned off so you can review it before you turn it on.
    4. Have Omni pull out the key points from a document that you upload and then add those key points to a long text field in your base.
Omni always asks you to confirm before it deletes records, tables, or pages. It leaves publishing an interface and turning on an automation to you, because those steps affect everyone who uses your base.
What’s new with Omni capabilities
The enhanced capabilities below are generally available. With improved capabilities, Omni can now:
  • Carry out multi-step requests - Omni plans the steps, completes them in one conversation, and tells you what it changed.
  • Turn files into tables - Upload a spreadsheet and Omni reads its structure, suggests how to organize it, and builds the tables and fields. This is still rolling out, so not everyone has it yet.
  • Work with your files - Omni can read PDFs, Word, PowerPoint, and Excel files, CSV, JSON, Markdown, plain text and code files, and Google Docs, Sheets, and Slides. Where available, it can also read images. You can upload up to 10 files at a time, up to 10 MB each.
  • Delete tables and interface pages - Omni confirms before deleting.
  • Read and add record comments - Ask Omni to catch you up on a record’s comment thread, or to leave a comment.
  • Help debug an automation - Omni checks the automation’s setup and the records it runs on and points you to the likely cause. Omni can also look at recent runs of a turned-on automation to find the step that failed and the type of error.
  • Fill out and submit a form - Point Omni at a form and it fills in the fields and submits it for you.
  • Build and edit a form - Ask Omni to create a standalone form from any table, write the question text and help text for each question, set which questions are required or read-only, and edit a form you already have. Omni can publish the form and give you the share link. For more details on what you can do with forms, see our Building and sharing forms in Airtable article. Forms inside an interface aren't supported yet. The same form building is available through the Airtable MCP server.
  • Undo its own changes - Ask Omni to undo records it added or deleted, fields it created, changed, or deleted, a table it deleted, and changes it made to pages and automations. Learn more in the Post response considerations section of this article.
After Omni reads content from outside your base, like web search results or a webpage, it asks you to confirm before it changes your base.
What works differently with enhanced capabilities
  • Change view filters, sorts, and grouping: Omni can update the filters, sorting, grouping, and visible fields of an existing grid, gallery, kanban, calendar, timeline, or Gantt view. It can't create new views or change form views.
  • Write script steps in automations: Omni can write and edit the code in script steps when it builds or changes an automation. If your admin has turned off AI script generation, you'll need to write that code yourself.
  • Edit charts and numbers: On a page with a single chart, Omni can change the chart's or number's settings directly. To add, remove, or move charts and numbers, change a chart's type, or make any change on a dashboard, Omni rebuilds the page. The page keeps its URL. Omni can't rebuild pages that contain custom elements.
  • Undo changes: Omni can undo many of its changes when you ask, but it can't undo creating a new interface or page.
  • Look up Airtable help articles: Omni can search Airtable's support articles to answer how-to questions. This requires internet search to be turned on.
  • Create AI text fields: Omni can create AI text fields.
  • Work on published interface pages: Enhanced capabilities also work when you use Omni on a published interface page. There, Omni answers in the chat by default and asks before changing your base's structure unless you ask for that change directly. (The interface page must originally have been created by Omni.)
What Omni can’t do yet
These aren’t supported yet:
  • Create a new base from a base chat: When you chat with Omni inside a base, it works only on that base. To build a new base with Omni, click + Create and choose Build an app with Omni from the Airtable home screen.
  • Build or change a form inside an interface: Omni can create, edit, and publish a standalone form, but it can't build or change a form on an interface page.
  • Create other types of AI fields: Omni can create AI text fields, but not other AI field types.
  • Create new views: Omni can change existing views, but you'll need to create new views yourself.
Tips for best results using Omni
  • Describe the outcome, not the steps. Say what the finished thing should be and who it's for, and let Omni choose the tables, fields, and layout that get there. A prompt that walks Omni through construction steps constrains it to your plan; a prompt that describes the result lets it use what it knows about building in Airtable.
  • Batch your changes when you refine. Gather a full list of what you want changed and ask for it in one message, rather than sending a run of small follow-ups. Long chains of single tweaks make it harder for Omni to hold the whole result in view.
  • Keep iterating until it's right. There's no publish step to get wrong — what Omni builds is live in your base as it builds it, so refining is the normal way to work, not a sign the first prompt failed.
  • Describe the task you want Omni to accomplish and give it as much context as possible.
  • Add any rules that will provide guardrails for Omni.
  • Provide any data or benchmarks that might be relevant to your request.
  • Include any formatting instructions to drive consistency in the AI output.
  • Give Omni specific instructions about what data it should access or which part of your app it should build or update.
  • Use standard Airtable terminology to help prevent confusion.
  • When building tables from a spreadsheet, upload the file and describe the structure you want rather than asking Omni to reshape a table you already imported. Name the tables you expect and say how rows should map - for example, “Create three new tables - Assignments, Students, and Tutors - from the attached CSV, and populate them with the data in that file.”
    • Creating a table and filling it with data can be separate requests. If a new table comes back empty, follow up and ask Omni to populate that specific table from the file you uploaded.
    • A CSV export includes only one tab of a spreadsheet. If your source file has several tabs you want Omni to use, export and upload each tab separately.
    • If you only need to move data into Airtable as it already is, importing is more reliable than asking Omni to do it. For more details, see our Importing third-party data into Airtable article.
    • For a very large migration - like tens of thousands of records or a complex multi-table restructure - consider contacting your Airtable account team before you start.
  • If a request doesn’t give you the result you expected, try rephrasing it with a more specific ask.
Understanding Omni’s permission access
When Omni interacts with your Airtable app, it will mirror the same permission settings of the user interacting with it. This means that:
  • Omni can only perform actions that the user could perform in the base or interface
  • Omni only has access to the data within a base or interface that the user can see
  • Field and Table permissions can also prevent Omni from making changes
Consult the Airtable permissions article to better understand your permissions that Omni will mirror and remember that your permissions can vary by the workspace, base, and/or interface that you are working out of.
Adjusting Omni AI settings
Adjusting Omni’s settings can only be performed by users with Owner or Creator permissions.
To access Omni’s settings:
  1. With Omni open, click the dropdown icon ⌄ next to the name of your chat. If you have not renamed the chat, then the name will be “New chat.”
  2. Click Settings.
From the settings menu, you can adjust various settings for Omni at the app level:
  • Enable Omni in {Your base} - Toggling this option off will turn off Omni in your base as well as interfaces. You must enable Omni in your base to allow it to be used in any interfaces.
    Any Owner or Creator of this base can turn this setting back on, so it isn't an enforced restriction. To turn Omni off across your whole organization in a way collaborators can't reverse, an admin can disable it in admin panel instead. For more details, see our Settings - Airtable admin panel article.
  • Enable Omni in interfaces - Toggling this option off will turn off Omni in any interfaces that are part of your app.
  • Allow Omni to create, update, and delete data for interface-only collaborators - Lets people who only have interface access use Omni to change records.
  • Allow interface-only collaborators to upload attachments - Lets people who only have interface access upload files to Omni.
  • Customization - There are two text boxes you can use to set guardrails or give Omni more specific instructions of how to respond or build in your Airtable base:
    • What context should Omni know about your organization or app?
    • What preferences should Omni consider in responses?
  • Internet access - Toggle this option on to allow Omni to utilize internet resources when answering questions or pulling data in from external sources. When toggled off, Omni will only utilize information in your Airtable base to answer questions and generate content.
After adjusting Omni’s app-level settings, be sure to click Save before returning to your base.
Renaming or deleting an Omni chat
  2. Click Rename or Delete.
    • If you are renaming, then type out a new name and press Enter/Return
    • If you are deleting, then a confirmation modal will appear. You’ll need to confirm by clicking Delete chat.
Preventing development of custom code
To prevent development of custom code:
  1. Open your admin panel.
  2. Click Settings.
  3. Click Integrations & development.
  4. Click the arrow icon to the right of “Prevent development of custom code.”
  5. Toggle the button next to “Prevent development of custom code” to “ON.”
After Omni has completed its response to a request, you will see several additional options appear.
  • Undo icon - This option appears in responses where Omni built or updated something in your app. Use it if the results were unexpected and you want to undo the actions that Omni performed.
    • You can also ask Omni in the chat to undo its changes. Omni can undo records it added or deleted, fields it created, changed, or deleted, a table it deleted, and changes to pages and automations. It can’t undo edits to existing record values, or creating a table, interface, or page. It only undoes its own actions in the current conversation, not changes you or other collaborators made.
    • The Undo icon doesn’t appear when Omni created an interface or page in that response.
  • Checklist icon - Click this icon to show the steps that Omni took to respond to your request. This can help you improve a request or see what Omni may have missed.
  • Thumbs up/down icon - Share positive or negative feedback about Omni’s response. Clicking the thumbs down icon opens a short form where you can describe what went wrong. This feedback helps us improve Omni over time.
  • Follow-ups - Omni generates suggestions for additional requests you could use to improve or gain insights into your app.
Note that you may need to hover over Omni’s output to see these icons appear.
Omni limitations
  • Cannot create views or change view filters. Omni can rename a view or update its description.
  • Cannot set up table syncs.
  • Cannot export data. See "Getting Omni's output out of Airtable" below for the supported ways to reuse an Omni response.
  • Omni sometimes struggles with certain calculation-based queries. However, Omni can summarize a table, including sums, averages, medians, minimums, maximums, and counts, grouped by a field.
  • Cannot configure base or workspace permissions.
  • Cannot create record templates.
  • Omni can only work with the data and actions a base or interface page gives you access to.
  • Cannot rebuild or replace an entire table, automation, or dashboard element that it did not create itself.
    • Omni will only restructure or overwrite something it built. If you ask it to rebuild a table that already existed, it declines with a message like “To preserve existing data, I can only edit entire tables that I recently created. Request to create a new table or create, edit, or delete existing columns instead.” and leaves the original table untouched.
    • To move forward, ask Omni to create a new table instead, or ask it to create, edit, or delete individual fields on the existing table - both are supported. If Omni keeps declining after several attempts, start a new chat and describe the structure you want from scratch.
  • Cannot create Gantt or blank page interface layouts
    • Omni can build a timeline page that uses a Gantt-style layout
  • Cannot create a new base from inside a base conversation. Click the + Create and Build an app with Omni option from your Airtable home screen to have Omni help build a new base/app.
  • Working with attachments in custom extensions - When Omni creates a custom extension that handles attachment fields, attachment cells cannot be set using raw base64 data directly. If you encounter a “Lost connection to the server” error when saving attachments, the extension may need to be updated to use one of the supported methods:
    • Provide a publicly accessible URL to the file
    • Upload the file via the Upload Attachment API (supports files up to 5 MB), then write the returned attachment object to the cell
    • If Omni generates code that doesn’t work for attachments, ask it to revise the implementation using one of these supported approaches.
Omni can't export data or produce a file to download, and the response in the chat can only be copied. To get an Omni answer out of Airtable as something you can send on:
  • Paste the response into a long text field on a record. From there it's ordinary Airtable data — you can include it in a Page Designer extension layout, send it in an automation's email step, or attach it to a record.
  • Ask Omni to write the result into your base instead of answering in the chat. Omni can create and update records, so a summary that lands in a field is reusable, while a summary that stays in the chat isn't.
  • For a recurring report, build the output as an interface page rather than as a chat answer, and share the page.
FAQs
Can I ask the support team question in Omni?
No. You can't start a conversation with our support team from the Omni chat window, though Omni may offer to hand a build request it can't complete over to the support chat for you. If you have a question about product behavior, need help troubleshooting something, or need to reach our Support team, then please click the question mark icon from the left vertical side bar and then click Get help. This will open up our support chat bot within Airtable.
What permissions are required to use Omni in a base or interface?
Omni’s permission levels will match that of your own. For example, if you only have permissions to edit certain fields in a base and you ask Omni to update a field where you do not have access to do so, then it will also not have access. Field and table permissions may also limit Omni’s ability to perform certain tasks.
How does Omni consume AI credits?
Check out our AI credits article to learn more about how Omni uses credits.
Can I use my own API key with Airtable’s AI Omni features?
No. Airtable AI only runs on Airtable-hosted models, so connecting a model that uses your API key isn’t supported.
Is there a limit to the number of questions I can ask Omni?
Yes. Asking Omni questions consumes AI credits. Check out our AI credits article to learn more about how Omni uses credits.
What are Omni’s limitations in Airtable?
To understand what Omni can and can’t do, check out the Understanding Omni’s capabilities and Omni limitations sections of this article.
Why can’t I access Omni?
In addition to enabling AI at the workspace level, organizations whose admins manage Airtable in the admin panel need to have AI turned on and allow the AI models that Omni requires. If those models aren’t allowed, Omni won’t be available across your organization. For more details, see our Settings - Airtable admin panel article.
If your workspace shows AI turned on but Omni still isn’t available, and your account recently had a plan or trial change (for example, a Team trial extension), your AI eligibility status may not have refreshed yet. Contact Airtable Support so we can confirm your eligibility is up to date.
Can Omni duplicate records in my table for me?
Omni can duplicate a smaller number of records - roughly 30 or fewer - in a table. However, when duplicating, there are often better choices such as using record templates, automation, scripting, or even just copy/paste functionality. These other choices are more reliable ways of duplicating records and minimizing incorrect information.
When should I use Omni to build or improve processes designed in Airtable?
While Omni can handle many tasks in Airtable, it's important to understand when traditional Airtable features may be better suited for complex workflows:
  • When to use Omni:
    • Quick data analysis and pattern recognition across records
    • Building new tables or fields with natural language
    • Generating content based on existing data
    • Creating and updating automations
  • When traditional features may work better:
    • Complex multi-step workflows requiring precise control - consider using Airtable automations with multiple conditional paths
    • Detailed audit trails and change tracking - use revision history, comments, and automations to create custom notification systems
    • Bulk updates requiring validation - use views with filters, batch editing, and field validation rules
    • Workflows requiring approval processes - build interfaces with forms and automations
  • Combining Omni with traditional features:
    • For complex workflows involving updates and audits, consider this approach:
    • Use Omni to build the initial structure (tables and fields)
    • Set up automations to track changes and send notifications
    • Create interfaces for team members to submit updates with proper validation
    • Use comments and @mentions for approval workflows
    • Leverage revision history to audit changes over time
Why did I receive the error, “Something went wrong: Unknown error," when trying to use Omni AI in Airtable?
Third-party web filters can sometimes block access to Omni AI in Airtable. To resolve this issue, update your third-party settings or disable the web filter to allow for use with Omni.
Why do I keep getting "Something went wrong" when using Omni?
The most common cause of the “Something went wrong” error is a third-party web filter or corporate security setting blocking access to Omni. Updating or disabling that web filter (often controlled by an IT team) usually resolves the repeated errors. If errors persist after that, try a smaller, simpler request and check that the task is something Omni supports.
Why does my custom extension for the attachment field produce the “error uploading” error?
When Omni builds a custom extension that handles attachment fields, the generated code often fails because attachment fields cannot be set using raw base64 data directly. To resolve the error, ask Omni to revise the extension to use one of the supported methods for writing attachments:
  • Provide a publicly accessible URL to each file, or
  • Upload the file via the Upload Attachment API (which supports files up to 5 MB each), then write the returned attachment object to the cell.
If your images are larger than 5 MB each, the Upload Attachment API will fail on size; either reduce the image size or use the public-URL approach. Note this is different from Airtable's normal in-app attachment field, where the per-file limit is much higher; the 5 MB cap applies specifically to the Upload Attachment API that an Omni-built uploader may rely on.
Can Omni rebuild a table that I created myself?
No. Omni can only rebuild or replace tables, automations, and dashboard elements that it created itself, so it declines requests to restructure anything that already existed and leaves your data untouched. You can still ask Omni to create a new table with the structure you want, or ask it to create, edit, or delete individual fields on the existing table. Once you have confirmed the new table is correct, you can delete the old one yourself.
Why did Omni create empty tables from my CSV?
Creating a table and populating it with data can be separate steps for Omni. Ask Omni to populate the tables it just created from the file you uploaded, and name any table that is still empty. If Omni built fewer tables than you expected, check whether your source spreadsheet had more than 1 tab - a CSV export includes only 1 tab, so each tab has to be exported and uploaded separately.
Can the support chat widget finish a build that Omni could not complete?
No. When Omni declines a build request it can hand the conversation to Airtable's support chat, but the support assistant guides you through building it yourself - it cannot build in your base the way Omni can. The handoff also passes along only your most recent message, not the whole Omni conversation, so restate what you are trying to build when the support chat opens. For a large build, the faster path is usually to return to Omni and work through one table or one automation at a time.
