Converting numbers and text in Airtable formula fields
Plan Availability | All plan types |
Permissions |
Platform(s) | Web/Browser, Mac app, and Windows app (with some additional limited support on mobile) |
Converting numbers to text strings in Airtable
If you append &"" to a formula working with numbers, then it will convert that value to a string in Airtable. Additionally, the &operator is equivalent to the CONCATENATE() function. This means you can also add "" to a CONCATENATE() function in order to convert a value to a string. Examples:
{Number field's name} & ""CONCATENATE({Number field's name} , "")
Converting arrays to text strings in Airtable
Lookup fields can be appended with &""or "" in a CONCATENATE() function to convert their outputs (arrays) to text for use in text-based functions. Examples:
{Lookup field's name} & ""CONCATENATE({Lookup field's name} , "")
Converting strings to numbers in Airtable
If you append +0 to a function using numeral string from a field in your Airtable base, it will convert the value back to a number and allow number formatting in your formula output. Example:
{Name of the numeral string field that you are referencing} + 0
Converting text to dates in Airtable
Synced fields arrive as text, and text fields that hold a date can't be sorted, filtered by date, or plotted on a calendar view until they're converted. Because a synced field is read-only, convert it with a formula field rather than by changing the field type.
Add a formula field and use DATETIME_PARSE() to read the text value as a date:
DATETIME_PARSE({Synced date text}, 'YYYY-MM-DD')
The second argument is the format the text is already in—it has to match the incoming text, not the format you want back. Some common patterns:
YYYY-MM-DDfor 2026-08-26MM/DD/YYYYfor 08/26/2026DD/MM/YYYYfor 26/08/2026MMMM D, YYYYfor August 26, 2026
To control how the result displays, wrap it in DATETIME_FORMAT():
DATETIME_FORMAT(DATETIME_PARSE({Synced date text}, 'MM/DD/YYYY'), 'MMMM D, YYYY')
If DATETIME_PARSE() returns a blank value, the format string doesn't match the incoming text. Check for leading or trailing spaces in the source values, and confirm whether the day or the month comes first — MM/DD/YYYY and DD/MM/YYYY both parse 03/04/2026 without error, but they produce different dates.
