Using REGEX() functions in Airtable
Plan Availability | All plan types |
Permissions |
Platform(s) | Web/Browser, Mac app, and Windows app (with some additional limited support on mobile) |
REGEX() in Airtable overview
REGEX functions only work with text strings. If you are using either a rollup or lookup field, you may need to first convert the data into a string before you can use a REGEX function on it (you could use
ARRAYJOIN()for this). Also note that rollup, lookup, and formula fields do not currently support rich text.This content does not cover Regular Expression patterns in-depth. There are outside resources that provide great deep dives into REGEX and pattern matching (like regex101, or the MDN Regex cheatsheet) that we recommend checking out for more detai.
In our formula field reference, you'll find the basic overview for the REGEX() functions that Airtable currently supports. Currently, Airtable supports three functions: REGEX_MATCH(), REGEX_EXTRACT(), and REGEX_REPLACE(). Each of these functions has advantages and disadvantages depending on the formula output you are expecting to be produced in your formula field.
In Airtable, we offer the find bar as well as the Search extension to find certain literal instances of certain strings or patterns. Additionally, we offer the FIND() and SEARCH() functions as well as other relevant text extraction functions in the Text operators and functions section of the formula field reference.
REGEX_MATCH in Airtable
The REGEX_MATCH() function returns whether the input text matches a regular expression and outputs in the Boolean data type as a 1 (true) or 0 (false) result. Two examples of where this may be useful are in phone number validation and email validation within your base.
REGEX_MATCH phone number validation - If you need to validate a set of phone numbers against specific criteria, you can use
REGEX_MATCH()like in the formula below.REGEX_MATCH({Possible Phone Number}, '^(\\+\\d{1,2}\\s?)?\\(?\\d{3}\\)?[\\s.-]?\\d{3}[\\s.-]?\\d{4}$')This regular expression handles a number of different phone number formats:
Country codes
Using dashes or spaces as delimiters
Parentheses around the area code
Using letters instead of numbers
REGEX_MATCH email validation - Similar to the other example above, you can use REGEX_MATCH() to validate a list of email addresses as well.
REGEX_MATCH({Email address}, "(\W|^)[\w.\\-]{0,25}@[A-Za-z0-9.-]+\\.[A-Za-z]{2,}(\W|$)")
This regex handles basic validation for email addresses: Starts with a username that is composed of letters, numbers, or characters like underscore, period or dash. An at-sign (@). A domain name, which is a string of letters, numbers, or characters like underscore, period, or dash, followed by a period, followed by another string of letters, numbers, or characters like underscore, period or dash.
Email validation is a very complicated subject, but this regex is a good starting point for most use cases.
REGEX_EXTRACT in Airtable
The REGEX_EXTRACT() function enables you to extract specific substrings from a text field based on a regular expression. If the REGEX_EXTRACT() function finds no matching instance of the provided regular expression it will return an ERROR. Here are some example use cases:
Extracting domains from URLs
REGEX_EXTRACT( {URL}, '^(?:https?:\\/\\/)?(?:[^@\n]\+@)?(?:www\\.)?([^:\\/\n?]+)')URLs start with HTTP or HTTPS, possibly a username followed by an @ symbol, the domain, and then the rest of the URL. Here, we strip off the subdomain if it’s ‘www’, but otherwise preserve it.
Extracting numbers from a text field
When you want to pull out numerical values from a text field, the
REGEX_EXTRACT()function offers precise control over what you retrieve.Extracting the First Single Number:
REGEX_EXTRACT({Field}, "[0-9]")The pattern [0-9] tells Airtable to find any single digit from 0 to 9. This will only return the first individual number it encounters in the text field.
Extracting the First Set of Numbers:
REGEX_EXTRACT({Field}, "[0-9]+")To extract a complete sequence of numbers, you'll add a + to the pattern. The + matches one or more of the digits. This allows the formula to find and extract the entire first group of consecutive numbers it finds in the text.
REGEX_REPLACE in Airtable
The REGEX_REPLACE() function substitutes all matching substrings with a replacement string value. Building off of the example above, if we have a valid phone number, we can normalize it using REGEX_REPLACE() to make it easier to work with in the rest of our Airtable base.
Normalizing phone numbers
IF({Is Valid Phone Number?}, UPPER(REGEX_REPLACE({Possible Phone Number}, '[^A-Za-z0-9]', '')), ERROR('Invalid phone number'))If the phone number passed validation, we normalize it by using
REGEX_REPLACE()to replace non-alphanumeric characters with an empty string, resulting in just the dialable digits. We also use theUPPER()formula to make the casing consistent. Normalizing phone numbers into a prettier format is an exercise left to the reader.
Using T() and REPT() in Airtable
This content is part of a guided course, which includes the functions listed below that can help expand functionality in your Airtable base.
T()This function returns the argument if it is text, and otherwise returns blank.
T("Text only")would return the argument, "Text only", whileT(42)would return as blank.
REPT()This function repeats any referenced string a specified number of times.
For example,
REPT("Hi! ", 3)would result inHi! Hi! Hi!.
FAQs
What REGEX tokens are supported in Airtable?
Token | In Airtable formula | Matches |
Character shorthands | ||
| Any digit — |
| Any non-digit character |
| Any word character — |
| Any non-word character |
| Any whitespace — space, tab, newline |
| Any non-whitespace character |
| Any single character except newline |
Anchors | ||
| Start of the string |
| End of the string |
| Word boundary |
| Non-word boundary |
Quantifiers | ||
| 0 or more (greedy) |
| 1 or more (greedy) |
| 0 or 1 — makes preceding token optional |
| Exactly n repetitions |
| n or more repetitions |
| Between n and m repetitions |
| 0 or more (lazy — stops at first match) |
| 1 or more (lazy) |
| 0 or 1 (lazy) |
Character classes | ||
| Any one of: |
| Anything except |
| Any character in the range a through z |
| Any uppercase letter |
| Any digit — equivalent to |
| Any alphanumeric character |
Groups and alternation | ||
| Capturing group — matches and captures the content |
| Non-capturing group — matches without capturing |
| Alternation — matches |
Escape sequences | ||
| Newline character |
| Tab character |
| Carriage return |
| Literal period — escapes the wildcard |
| Literal parentheses |
| Literal square brackets |
| Literal backslash |
Not supported in Airtable (RE2 engine) | ||
| — | Lookahead — not supported |
| — | Negative lookahead — not supported |
| — | Lookbehind — not supported |
| — | Negative lookbehind — not supported |
| — | Backreferences — not supported |
