AI-generated interface elements in Airtable
Last updated: November 9, 2026
Plan availability | All plan types |
Permissions |
Platform(s) | Web/Browser, Mac app, and Windows app |
Related reading |
You can also have AI build out custom interface elements using the Airtable MCP server.
AI-generated interface elements overview
AI-generated interface elements allow Airtable builders to use Omni to create custom visualizations and layouts tailored to meet specific needs. AI-generated interface elements are available on all plans and don't require AI Labs to be enabled.
There are 2 types of AI-generated elements:
Full table layouts
Dashboard elements
AI-generated interface elements are different from traditional interface pages created in Interface Designer. Here's what you need to know:
AI-generated interface elements are custom visualizations and layouts created by Omni from natural language prompts. They include full table layouts and dashboard elements.
Traditional interface pages are built manually in Interface Designer and include options such as Gantt views and blank page layouts.
AI-generated interfaces are built on the same underlying page/page-layout model as manually built interfaces and are editable in the standard Interface Designer experience. Available controls can still vary based on permissions, feature flags, and page state.
Omni can create or modify traditional interface pages or visualizations, however, it’s important to call this out to Omni when you are interacting with it to ensure that it creates a native interface rather than creating a custom one.
When you ask Omni to "build an interface," it typically creates AI-generated interface elements rather than native interface pages.
If you want a native interface, then try something like “Create a native list interface page for the Projects table.”
Creating AI-generated elements
You can create AI-generated elements from a base and Interface Designer:
To create an AI-generated element from a base:
Open your Airtable home screen.
Select the base where you want to create an AI-generated element.
Open a chat with Omni and describe the interface element you want to build.
Review the plan Omni proposes, which describes what it will build and any necessary changes to your tables and fields.
Provide additional details or suggestions to refine the plan when necessary.
Click Build it.
Omni may take a few minutes to generate your element.
If Omni doesn't generate your element, toggle "Generate an interface" element from the "Tools" menu to direct Omni to always create custom elements.
You can also upload an image as a visual reference for the element you're asking Omni to build.
To create an AI-generated element from Interface Designer:
Open the base where you want to create an AI-generated element.
Click Interfaces at the top of the base.
Click + New interface or open an existing interface.
Click Generate with Omni.
Describe the interface element you want to build, or choose from Omni's suggestions.
To create dashboard elements, open the relevant dashboard page in the “Interfaces” tab before submitting your prompt—otherwise, Omni will create a full table layout by default. If Omni replies that it can’t build a custom element, it is most likely building a native interface page instead. Turn on “Generate an interface” element in Omni’s “Tools” menu, then ask again with the dashboard page open.
Configuring and editing AI-generated elements
AI-generated elements can be configured like standard interface elements through the properties panel to:
Change the data source
Apply filters and sorting
Enable user actions like inline record creation, editing, and deletion
Connect elements to record detail pages
If data is missing, verify that the correct tables and fields are selected in the “Data” panel. Your custom elements can only access data from selected tables and fields.
Omni may generate custom properties specific to your element. These can be edited directly in the “Properties” panel, allowing you to make changes without modifying the code.
If you don't see the configuration panel:
Verify you have Creator or Owner permissions on the base.
Ensure you're in Edit mode (not preview mode).
Check that you've selected the interface page from the Pages sidebar.
Try refreshing the page or logging out and back in.
Updating AI-generated elements
To make updates to an AI-generated element:
Select the element on the canvas.
A blue border will appear around it, and the selection context will be visible in the Omni prompt box.
Clicking on elements within the custom element (Headers or content boxes) provide Omni with selection context.
Describe the changes you want to Omni.
If you're familiar with JavaScript or React, you can work with the element's source code directly. With the element selected in Edit mode, open the overflow menu at the top of the element's properties panel, then choose Download source code or Edit source code.
These options only appear for elements that Omni generated. Interface pages and elements you built manually in Interface Designer have no source code to edit or download, and neither do native interface pages that Omni built for you.
To revert to an earlier version, use the “History” menu. If Omni isn't resolving an issue, try creating a new chat before requesting changes.
Download source code is a one-way export. There’s no matching upload or import option, so you can’t move an element to another page by downloading its code and adding it somewhere else. Use Edit source code to change an element in place, and ask Omni to build the element again on any other page where you want it.
AI-generated element limitations
AI-generated elements cannot securely store credentials for third-party services.
You can create elements that integrate with third-party services, but any credentials used are visible to all element users.
AI-generated elements are not viewable on mobile devices.
AI-generated elements cannot be added to blank layout or record detail pages; they can only be used on dashboard or standalone pages.
AI-generated elements cannot be reused across multiple pages or apps. An element Omni builds on one dashboard page can’t be added to another dashboard page, interface, or app. You can duplicate a page or app containing an AI-generated element, but this creates a fork—further code changes won’t apply to the copy. To get the same element on a second dashboard page, ask Omni to build it again with that page open.
If you ask Omni to add an element it already built to a different dashboard page, it builds the element on a new page instead, and it may point you to Add group and then + Add custom on the page you wanted it on. That picker will be empty. There is no library of saved custom elements to add from, so nothing appears there to choose—this is the same limitation, seen from the other side. Open the second page and ask Omni to build the element again.
Only Anthropic and OpenAI models are supported. If your enterprise has restricted these AI models, Omni can’t generate custom interface elements.
Your enterprise admin must allow AI internet access. If "Enable Internet access" is turned off in admin panel, Omni can't create or edit custom interface elements. Omni doesn't name the setting when this happens—it may report that it can't change the page, or build a dashboard page instead. For more details, see our Settings - Airtable admin panel article.
AI-generated elements load data from the table they're connected to, so connecting an element to a large table can slow how quickly it loads.
On tables with many records, for example, 10,000 or more, open the element's properties panel, apply filters, and limit the number of visible fields so the element loads only the data that end user’s need to see.
You can also consider utilizing record detail pages to allow end users to open the record and reveal additional information.
FAQs
Does creating or updating AI-generated interface elements use AI credits?
No. Creating or updating AI-generated interface elements does not use AI credits.
How do I write effective prompts for creating or updating AI-generated interface elements?
Plan ahead: Before writing your prompt, develop a high-level plan with clear goals and features. A helpful format includes:
High-level description and goals
Required fields and their purposes
Detailed UI/layout description
User interactions to support
Be descriptive: Add as much detail as possible to remove ambiguity. Optionally, attach a screenshot or sketch as a visual reference.
Update in smaller amounts: Break down your element into smaller pieces of functionality and add them incrementally rather than trying to get everything right in one prompt.
How do I fix interface errors?
Interface errors indicate that code generation succeeded but that a bug exists in the generated code. Try copying the error into the chat and asking Omni to fix it. You can also revert to an earlier version using the “History” menu, or by clicking the “Revert” button in Omni under the desired message.
How do I submit feedback when creating or updating AI-generated interface elements?
To submit feedback, use the thumbs-up or thumbs-down icons in Omni. After rating your results, click Give feedback to provide additional details.
Why don't I see the option to edit or download source code?
The Download source code and Edit source code options appear only when all of the following are true:
The element was generated by Omni. When you ask Omni to "build an interface," it sometimes creates a native interface page instead of an AI-generated element, and native pages have no source code. See "AI-generated interface elements overview" for the difference between the two.
You're in Edit mode and the element is selected on the canvas, rather than viewing the published or preview version of the page.
You have Creator or Owner access to the base. Learn more about Interface Designer permissions.
The element is on a dashboard or standalone page. AI-generated elements can't be added to blank layout or record detail pages.
Your organization hasn't restricted the Anthropic and OpenAI models. Omni can't generate custom interface elements when those models are unavailable, so the elements it creates won't have source code.
If the options still don't appear, Omni most likely built a native interface page rather than an AI-generated element. Toggle "Generate an interface" element on from the "Tools" menu in Omni, then ask for the element again.
Omni says it can’t create a custom element for my dashboard page. What do I do?
Omni can create custom elements on dashboard pages, but it will decline or quietly build something else in a few situations. Work through these in order:
Open the dashboard page first. Open the page in the “Interfaces” tab before you send your prompt. If no dashboard page is open, Omni builds a full table layout instead.
Check the page type. AI-generated elements can only be added to dashboard or standalone pages—not to blank layout or record detail pages. See Airtable interface layout: Dashboard for more about dashboard pages.
Turn on the element tool. In Omni, open the “Tools” menu and turn on “Generate an interface” element so Omni builds a custom element rather than a native interface page.
Confirm your permissions. You need Creator or Owner access to the base. Learn more about Interface Designer permissions.
Check your AI model access. Omni can’t generate custom elements if your organization has restricted the Anthropic and OpenAI models.
Check your organization's internet access setting. If an admin has turned off "Enable Internet access" in admin panel, Omni can't build custom elements at all. Ask your admin to check it.
Omni can’t copy an existing custom element onto another dashboard page. Ask Omni to build the element again with the second page open.
