Using Airtable AI in fields
Plan availability | All paid plans |
Permissions |
Platform(s) | Web/Browser, Mac app, and Windows app |
Related reading |
AI credits and enabling AI on the workspace level are required to use AI in fields.
Understanding Airtable AI in fields
In Airtable, we refer to most AI-enabled fields as Field agents. Field agents are AI-powered fields in Airtable that can automatically retrieve, analyze, or generate data at the cell level. Unlike standard fields, field agents are dynamic. They can pull in information from the web and analyze documents to perform tasks that would otherwise require external tools or manual entry. Field agents can be added manually or generated by Omni when it recognizes that an AI-powered workflow is the most efficient solution.
There are several field types in Airtable that support AI features. The set of features supported varies depending on the type of field you are creating and configuring.
Formula field - When you begin configuring a formula field, you can have AI help build out a formula by clicking the Generate formula button in the field editor. It’s worth noting that you can also ask Omni to help you build a formula.
Long text field (a.k.a. AI text) - Have a field agent generate content based on custom instructions. The content generated will directly refer to information held in other fields related to the record that you are working with.
Linked record field - Toggle on the “Show AI-suggested records” option in the field configuration menu to turn on AI. This enables Airtable AI to suggest linked records in the field based on the context held in other fields within the table(s) connected via linked records, streamlining repetitive and manual tasks.
Select fields (Single or Multiple select) - Allow a field agent to output single or multiple select options based on information held in other field(s) across a table.
Number-based fields (Number, Currency, or Percent) - Have an agent determine a number, currency, or percent based on other numbers and/or information on the record the agent runs on.
Adding a field agent
Open the preferred base and table where you would like to add a field agent.
Click the + button located next to the last field in the table or click an existing field’s dropdown menu and click Insert left or Insert right to add a new field next to an existing one.
In the menu that appears, you’ll notice a “Field agents” section at the top where you can choose from one of the common field agent use cases, click Build a field agent, or click Browse catalog to open up the Field agent catalog.
In the field agent catalog, you’ll find a “Suggested for your base” section with field agent suggestions tailored to the Airtable base you are working out of. You can also choose a use case next to the “Specific to your use case” section. This will update the available preset options. You can also click Browse all to view even more options.
Depending on the option you chose above, you’ll have one of two experiences:
Field agent suggestion or catalog - After choosing a pre-set field agent, we will open up Omni with a request to build out the field agent you chose. After Omni has completed the initial request, you can ask it to further alter the field’s configuration or begin making some manual adjustments to the newly created field.
Build a field agent - After choosing to manually build a field agent, you’ll be brought to the field configuration window. By default, the field type will be set to “Long text.” Click the dropdown to choose another AI field type. After configuring the field and giving it “Custom instructions,” click Create field.
Giving field agents custom instructions
Consider the following items when building out custom instructions (prompt) for a field agent from scratch or modifying existing instructions:
Describe the task you want the agent to accomplish and share as much context as possible.
Add any rules that will provide guardrails for the agent.
Include "Do" and "Do Not" statements to set boundaries for the AI model.
Provide any data or benchmarks that might be relevant to the prompt you are writing.
For more complex prompts, consider asking the agent to take on the task in a step-by-step manner
Include any formatting instructions to drive consistency in the AI output
Giving the AI model a role can be helpful (i.e. "You are a product manager...")
Include as many Airtable fields in the prompt as needed to provide context for the request.
You can use the + Insert field button in the custom instructions window to add fields or begin typing the field name with a curly bracket
{in front of the name. Either option will open up a list of the fields you can use in the prompt. The field name will appear as a token in the prompt and will automatically update, even if the name of the field is changed later.Click on the dropdown within a field to reveal a menu with more options:
Change field - Change the current field in the prompt to be another field in the table
Make optional - This will allow the field agent to run even if that field is empty
When “Make optional” is enabled, you can Add conditional instructions that will let you insert additional instructions for that field if a value exists.
You can also Copy, Duplicate, or Delete a field from this menu.
Referencing lookup, rollup, and linked record fields - Lookup, rollup, and linked record fields can hold more than one value — a list rather than a single piece of text — so the token for one of these fields may not reach the model as the readable text you see in the cell. When a prompt depends on the exact wording of a multi-value field, convert it to text first:
Add a rollup field on the linked record field and use
ARRAYJOIN(values, ", ")as the aggregation formula, then reference the rollup in your custom instructions.Or add a formula field that appends
& ""to the lookup field to convert it to a string, then reference that formula field.Either way, describe what the field holds in the prompt itself — for example, "The following is a comma-separated list of this project's task names: {Task names}" — so the model knows it is reading a list. For more detail on how these field types collect values, see our Lookup field overview and Rollup field overview articles.
When you include a field, provide the context of what kind of content the field is storing, such as:
"Write an email that addresses the following customer feedback: {customer_feedback}"
or "Create a meeting summary based on the following notes: {Meeting Notes}"
Remember that more specific prompts typically yield more specific outputs, while less specific prompts might result in more variation. You can use either method to achieve different results, but it's important to be intentional with your approach.
You can always go back and edit a prompt, but we strongly recommend that you save a previous prompt in case you want to revert back to it (paste it back into the prompt text box) while you are testing the AI's output.
Point out specific examples of what the agent output should look like.
To that end, add any default language/pre-determined outputs that the AI should always include.
Provide the AI model with examples to work from. When providing examples, clearly state at the end of the examples section what you want the model to do by prompting it specifically with the content you want it to ingest and the desired action.
Below are some examples of feedback and related sentiments that you'd output. The feedback statements below are examples only. Feedback: "This is the worst tent I've ever used." Sentiment: Negative Feedback: "This backpack is alright." Sentiment: Neutral Feedback: "I really love this sleeping pad." Sentiment: Positive Feedback: {customer_feedback} Sentiment:
Managing field agent prompts across a team
Only Owners and Creators can change an agent's custom instructions, so in a team of any size a small number of people own the wording that everyone else's records depend on. Decide where the canonical version of each prompt lives before that becomes a problem.
Keep the source of truth outside the field. The instructions in the field are the running copy, not a history. A "Prompts" table in the same base — one record per agent, holding the current instructions, what the agent is for, and who owns it — gives you somewhere to review and compare wording without opening each field.
Start from one prompt per agent, and vary it only where a team genuinely needs a different output. Every variation is a separate thing to test when a model changes.
Record which model each prompt was written against. Custom instructions are calibrated against the model you tested them with — see "Changing the model on a field agent" below.
Test a change before it reaches your records. Preview the new instructions against a record in the view, or duplicate the agent and compare the two outputs side by side, as described in "Changing the model on a field agent".
To recover a prompt from before a change, restore a snapshot of the base. Restoring creates a separate base, so you can copy the earlier instructions out of it and leave your production base untouched.
Writing custom instructions with Edit with AI
You don't have to write custom instructions from scratch. Airtable can draft them from a plain-language description, or rewrite instructions you've already written.
Open the field agent's configuration window.
Click Edit with AI.
Describe what you want the field to do. For a new field you'll see the placeholder "Describe what you want this field to do"; when you're refining instructions that already exist, you'll see "Describe any additional changes or updates".
Click Update agent.
Airtable replaces the custom instructions with a fuller prompt based on your description. Review it before you create or save the field, and check it against the guidance above - the assistant writes a well-structured prompt, but it only knows what you've told it. To return to the previous version, click the undo icon next to the input. The undo icon only appears once you've generated at least one version.
You can keep refining by describing further changes and clicking Update agent again. This is the quickest way to turn a short instruction such as "give me the country for this region" into instructions detailed enough for the agent to follow consistently.
Editing a field agent's instructions doesn't regenerate cells that already hold content. See "Understanding field agent dependencies and limitations" below for what happens to content that has already been generated.
Adjusting a field agent configuration
After a new field agent has been created, you can modify its AI configuration in a few ways. Click the dropdown next to a field agent’s name and click Edit field to reveal these options:
Settings - Toggle each of these settings on or off.
Enable internet search - If this setting is enabled, we evaluate the prompt to determine whether internet access is required. If it can be carried out without using the internet, then we won't use the internet.
Please note that this often requires additional credits, and you should verify the results for accuracy.
This option may not be available if internet access has been disabled in admin panel. (Business or Enterprise Scale only)
We support both general internet search (e.g. "Research this company," "find this person's job title") as well as search that specifies a URL ("get the company address from {Company_webpage}")
We also support internet browsing (e.g. "Pull the text from this webpage and identify any grammatical errors")
If the AI uses the internet in creating its response, then the sources will be included in the agent’s output.
Google Drive - If this setting is enabled, then you can reference specific Google Drive files or the folders and the documents/files contained within them. This can help to give your field agents the necessary context to output high-value information.
Airtable supports up to 100 folders per run.
Airtable searches those folders and their subfolders automatically.
In very large folder structures, search may stop early, so results may be partial.
To limit Google Drive searches to specific folders you can use this tag format in your prompt:
<gdrive_folder> {Insert your identifier(s) here} </gdrive_folder>Supported inputs inside the tag:
A folder ID
A full Google Drive folder URL
A comma-separated list of folders
Multiple
<gdrive_folder>tags
One Drive - If this setting is enabled, then you can reference specific One Drive files or the folders and the documents/files contained within them. This can help to give your field agents the necessary context to output high-value information. Note that One Drive access does not have the same functionality described above for the Google Drive connection type.
Run automatically - This will cause the agent to automatically run (generate values) when input values change
Much like an automation, be sure to consider the downstream effects of enabling this option.
i.e. If you have other field agents, formulas, or automations that are referencing the values output by the field agent, then this can trigger a lot of other changes to occur in your base.
Model - Choose between various AI models available to you based on your plan and/or organization's admin panel settings. There is typically a relationship between the cost and quality of a model. You'll see a "Low cost" tag next to models that will consume fewer credits. Changing the model changes what each run costs—the "Preview" window below "Custom instructions" shows the credit usage for the current configuration, so check it there before you save. The difference between a low-cost model and a more capable one can be several times the credits per run, not a few percent. To understand how credits are counted and where to review your balance, see Airtable AI billing.
When selecting a model, consider the complexity of your prompt. Lower-cost models work well for straightforward tasks like text summarization or sentiment analysis. They are less reliable at arithmetic. If an agent needs to calculate rather than interpret, use a formula or rollup field instead—both return an exact result and consume no AI credits—or select a more capable model and check its output against a figure you already know.
However, if your field agent uses advanced features like internet search or requires multi-step reasoning, a more capable model will produce more reliable results.
Using a low-power model with complex tool-calling prompts may result in errors such as "Unknown error while using tools with the agent." If you encounter this, try switching to a higher-powered model and simplifying your prompt language (for example, use direct instructions like "Use these patterns for your search queries" rather than conditional phrasing like "To search the internet, use these patterns").
Every field agent is created with a model already selected, so an agent you didn't configure yourself is still running on a specific model.
Triggering a field agent run
A new field agent runs only when you trigger it. It does not produce a value when a record is created, or when the fields it reads change, until you turn on Run automatically.
To turn on have field agents run automatically:
Double-click the field agent's header, or click the dropdown arrow in the header and click Edit field.
Under Settings, turn on Run automatically.
Click Save.
From a base, there are a few ways to manually trigger a field agent to run. Remember, only users with editor permissions or higher can manually trigger field agents to run.
Click Run agent within a cell to run the agent only for that individual cell/record
If a cell is empty and you don’t see Run agent, then click into the cell. Then, click the two arrow icon to run the agent again.
To perform bulk field agent runs:
Click the dropdown menu next to the field agent’s name
Hover over Run field agent
Then click one of the options available:
All cells in the view
Cells modified by agent
Outdated cells
Cells with errors
Cells never modified
Using a field agent in an automation
An automation that reads a field agent's output can run before the agent has produced one. The automation reports a successful run and writes an empty value, because the cell really was empty when it read it.
To build the chain in the right order:
Turn on Run automatically on the field agent, so it produces a value without being triggered manually.
Point the automation's trigger at the field agent's field — for example, "When record updated", watching the agent field — rather than at the source field the agent reads.
Pointing the trigger at the source field starts the automation and the agent at the same moment, and the automation usually wins.
A field agent only sees the record it runs on - A field agent reads the fields on its own record and nothing else. It can't look across the other records in its table, records in another table, or records in another base, so it can't total, compare, or rank records against each other—for example, it can't work out a remaining balance that depends on every other pending request.
Values from other records are available to an agent only when they already appear on the agent's own record through a lookup, rollup, or linked record field. See "Referencing lookup, rollup, and linked record fields" above for how to pass those values into custom instructions.
To work with values the agent can't reach:
Use a rollup field when you need an aggregate of linked records, such as a total or a count. A rollup is exact and consumes no AI credits. See Rollup field overview.
Use an automation when you need AI to reason over several records at once. Add a Find records action to gather the records, then pass its results to a Generate with AI action. See Airtable automation actions: Generate with AI.
Output field types - A field agent writes its result as text. It can't write directly into a date field. To use an agent's output for date filtering or date grouping, have the agent return the date in a consistent written format, then use an automation with an Update record action to copy that value into a real date field.
Word limits - The total number of words in your query (custom instructions) and agent response must be under a certain amount set by the AI model being used on the backend. This includes the words in the fields referenced by your query. If you exceed these limits in your query, an error message will appear. If the AI's response exceeds the limits, the text will be truncated.
Lower powered AI models: Up to ~12,000 words
Higher powered AI models: Up to ~90,000 words
Automatic generation - The Run automatically setting in a long text field can be enabled in tables containing many records. However, if you do choose to "Run automatically" on a table with thousands of records, you are still limited by the amount of credits available to you and your team. Therefore, it's possible that some records will generate automatically, but others may eventually encounter errors due to other limitations.
If this setting is toggled on, and you proceed to make any edits to your prompt or prompt settings and then save the field, we will display a message asking if you want to overwrite existing records. You will only see this messaging if it is generated automatically.
Clicking Continue will overwrite existing content by regenerating it for those cells. However, we will never automatically overwrite any cells that were edited by a human, even if you toggled on “Generate automatically.” This remains true whether you change your field configuration or modify the cells on which the AI field depends.
Users will also have the option to proceed without overwriting their existing data. Choosing this option will still save any edits made to the prompt or prompt settings, but none of the existing content for that field will be overwritten. This will ignore automatic generation at the moment the field configuration is saved. Any future edits to existing records that trigger automatic generation or the addition of new records will now generate content adhering to the AI field’s current configuration.
A cell you edit or clear stays under your control - Airtable never automatically overwrites a cell that a person has edited, even when Run automatically is turned on. Clearing a cell counts as an edit. The cell stays empty, and the agent won't generate a value for it again—including later, when the record starts meeting the conditions the agent generates on. Nothing in the cell indicates that automatic generation is paused for it, so an agent that has stopped filling in a particular record is worth checking here first.
To hand a single cell back to the agent, click into the cell and click Run agent.
To do the same for many records at once:
Click the dropdown menu next to the field agent's name.
Hover over Run field agent.
Click Cells never modified.
Once the agent generates a value, that cell is back under the agent's control and generates automatically from then on.
Avoid clearing field agent cells by hand. To replace a value, run the agent on the cell instead—a cell you cleared yourself is skipped by automatic generation until you run the agent on it again.
Automatic generation needs the base to be open
Run automatically generates a value when the inputs an agent references change, and those changes are picked up while the base is loaded in a browser. When an input changes only because time has passed—a date moving into a window such as "within the next 14 days", for example—nothing generates until someone opens the base again.
If you need generation to happen on a schedule rather than when someone happens to open the base, create an automation using the "At a scheduled time" trigger, add a Find records action to select the records you want, and add an Update record action that writes to a field the agent references. Changing that input is what causes the agent to run. The "How can I re-check a URL on a schedule?" FAQ below walks through this pattern in full.
Configuring AI in linked record fields
We provide additional context and information about dependencies in this article; however, the steps below outline the basic setup process.
Navigate to an existing linked record field where you want to configure AI settings or add a new linked record field to a table.
Toggle on the “Show AI-suggested records” option.
Next, you’ll select one or more fields from each table linked together that will help to give AI context about the relationship between the linked records.
You can utilize this feature on intra-linked (within the same table) or inter-linked (between two tables) record fields.
You’ll want to connect as many fields as needed to provide the AI model with the necessary context to suggest records with greater precision.
Click Save if you are modifying an existing linked record field or Create field if you just configured a new linked record field.
Configuring a Deep match field agent
A Deep match field agent links a record to the best match in another table when the values don't match exactly. Use it when the same thing arrives in different forms from different sources — "Acme Corp.", "ACME Corporation", and "acme corp" all pointing at one company record — or when the right match depends on meaning rather than on identical text.
A Deep match agent lives on the table you're linking from, and it matches outward into the table you choose. It reads the record it sits on, compares it against candidate records in the match table, and writes the link.
To add a deep match field agent:
Open the table that needs the link, and click the + button next to the last field.
Click Deep match to another table under the "Field agents" section.
Select the table you want to match into.
Select the source fields on both tables that the agent should compare — for example, a company name on each side, plus a domain or a region field to break ties.
Write a match instruction describing what counts as a match, and what to do when nothing is close enough.
Set how many matches the agent may return. Limit it to a single match when the link should be one-to-one.
Under Settings, turn on Run automatically if you want new and updated records matched without running the agent by hand. See "Triggering a field agent run" above.
Click Create field.
Before you backfill a whole table, run the agent on a small grouped subset and check the links it produces. Adjust the match instruction and run it again until the results are right.
When to use an automation instead
A Deep match agent matches from the table it lives on, and it runs when that record changes. It doesn't re-run when a record is added or changed in the table it matches into, so rows that had no good candidate when they were matched stay unmatched.
Use a Find records action followed by an Update record action in an automation when:
New records arrive in the table being matched into, and earlier records should be rechecked against them.
You want matching to run on a schedule rather than when a record changes.
You need to match in the opposite direction from the one your link field runs in.
Editing an agent's match instruction causes it to run again on the records it covers.
Converting field agents to standard fields
If you're trying to change an AI field agent to a regular field type, you may notice that only AI field types appear as options in the edit field configuration menu. To see standard field types, you'll first need to convert the AI field agent into a standard field. Once that's done, you’ll be able to update the field type as you normally would. To convert a field agent to a standard field:
Double-click the field name.
Click on the … icon in the upper right corner of the field configuration window.
Click Convert to standard field.
Once you've converted the field, all standard field types will become available, and you’ll be able to choose the one that best fits your needs.
You can also convert standard field to be field agents by double clicking the field name and then clicking Convert next to the “Automate this field with an agent” section of the standard field’s configuration window.
Configuring field agents for document extraction
Document extraction in Airtable is the ability to create an AI field that can reference an attachment. Can be used for use cases such as:
Create company summaries from lengthy financial documents
Digitize key pieces of data from forms
Translate the text from a document into another language
To add a Document Extractor field agent:
If the table doesn’t already contain an attachment field, add one now so that you can reference it in the prompt.
Click the + button located next to the last field in the table, or click an existing field’s dropdown menu and click Insert left or Insert right to add a new field next to an existing one.
Click the Analyze attachment option under the “Field agents” section.
From here, you’ll configure the various field options, including:
The field’s name.
Whether or not to enable internet search, run automatically, or any other options under “Settings.”
Your preferred AI model.
By selecting the Analyze attachment field agent option, Airtable will provide you with a boilerplate prompt. Consider updating the prompt to be more inclusive of your specific needs. You may also need to modify the attachment field token to be another attachment field if your table contains multiple attachment fields.
When you are finished configuring the field, click Create field.
Document extraction limitations include:
This functionality only works with attachments in the following formats: PDF, DOCX, PPTX, JPG, PNG, TIFF, BMP, XLSX, or WEBP.
Field agents that extract data from attachments can read PDF files by default. To analyze image files (PNG, JPG, and WebP), an admin needs to enable Airtable Labs first which is only available for Business or Enterprise Scale plan customers.
Can support documents up to the context window of the LLM you're using. For example, OpenAI models support up to 128,000 tokens, which translates to documents that contain approximately 400,000 characters. However, this will vary by model type, but should likely increase in capacity over time as model providers become more efficient.
Images contained within attachments are not supported. Document Extractor currently just extracts information from text.
Choosing between a formula and a field agent
Formulas and field agents both derive a value from other fields, but they behave differently when your data doesn't fit the pattern. A formula follows the rules you write exactly. A field agent interprets what it's given and can make a reasonable assumption.
Use a field agent when:
Values arrive in different formats from different sources - for example, a region field holding "California" in some records, a non-US region in others, and only a city name in the rest.
The output depends on knowledge that isn't in your base, such as which country a city belongs to.
Some records are missing a value a formula would need, and a best guess is more useful than a blank.
Use a formula when:
Every record follows the same pattern.
The same input should always produce the same output.
You want results to update instantly without consuming AI credits.
If you've already written a formula that returns blanks or errors for the records that don't match your pattern, that's a sign the task needs interpretation rather than a rule. You can turn that field into a field agent - double-click the field name, then click Convert next to the "Automate this field with an agent" section.
Custom instructions are calibrated against the model you tested them with. Models from different providers interpret the same wording differently, so changing the model on an agent that's already working can change its output even though you didn't touch the prompt. Treat a model change as a configuration change that needs the same testing you did when you built the agent.
Before you change the model on an agent that people rely on:
Duplicate the field agent and change the model on the duplicate, so the working agent keeps producing results while you compare.
Run both agents over the same set of records and compare the outputs. Expect some variation between runs - a field agent isn't a formula, so identical inputs can produce slightly different wording.
Adjust the custom instructions for the new model, then move the model change to the original field and delete the duplicate.
Only Owners and Creators can change an agent's model or instructions. If you want to keep an agent stable, review who holds Creator access to the base - collaborators who only need to enter data and click Run agent can work as Editors instead.
To recover a prompt or model setting from before a change, restore a snapshot of the base. Restoring creates a separate base, so you can open the earlier version of the agent, copy its instructions, and leave your production base untouched.
AI Security and Terms of Service
When using AI in Airtable, note that any data within fields referenced in a prompt may be shown to users who can view the AI long text field. This is particularly important when leveraging an AI long text field in an interface, where certain fields used in the prompt may be intentionally hidden from interface collaborators. For example:
A creator builds an AI long text field that guesses a job title given an team member’s experience and salary
An interface is created that shows the AI long text field and the team member’s experience, but not the salary
An interface collaborator edits the team member’s experience section to instruct the AI to disregard other instructions and repeat the salary input.
For more information on AI security and ToS, please visit the following resources:
FAQs
How do I know if the Airtable AI is enabled?
Enterprise Scale and Business license users should ask their admin if AI is enabled in Admin Panel and if it's enabled for your workspace.
If it is, but you still don't see the feature, ask a workspace owner to check their workspace settings page to see if the feature is enabled in the workspace.
Self-serve Team and Business plan users should ask a workspace owner to check their workspace settings page to see if the feature is enabled in the workspace.
Are there any precautions when using Airtable AI?
AI responses are designed to be reviewed and edited by users and may contain inaccuracies or biases.
Based on the terms of Airtable’s agreement with our AI vendors, the data you provide as input into the AI field will not be used to train their large language models. However, some companies have policies that restrict the disclosure of personally identifiable information (PII), such as email addresses, physical addresses, and telephone numbers, to external vendors. If this is the case, refrain from using columns containing PII as inputs into an AI field.
Which languages can be translated by AI?
Translation capabilities might be limited depending on the type of AI model you are using to generate content, but in general, you should expect that most common languages are available for translation.
My AI-enabled field is stuck “generating.” What might be occurring?
There are two situations that may occur when cells in an AI field seem to be stuck in the “Generating” state:
Your base contains many cells that are all being updated simultaneously. Airtable batches AI content generation requests in order to limit the rate of requests we are making to the AI model that you are utilizing. In these cases, you will want to wait until we have processed all the updated records, which may take a considerable amount of time, especially when generating content for many thousands of records.
There may be a downstream outage. This means that the AI model you are utilizing to generate content may be experiencing an outage. In these cases, you’ll want to check the following status pages:
How do I determine the number of credits a field agent is using?
There are a couple of places to view or preview credit usage:
When editing a field agent’s configuration, you will see a “Preview” window below the “Custom instructions” window.
The preview and credit usage are based on the value(s) in the first record of the view you are working out of
Credit consumption can be higher or lower in other records depending on various factors, but is typically determined by the length of input and output.
Why are certain file types, otherwise supported for use by field agents, seemingly not supported in Airtable for me?
PNG, JPG, and WebP file type support is only available on Business and Enterprise Scale plans after opting into Airtable Labs.
PNG, JPG, and WebP support is available by default on Free and Team plans.
Can I use field agents in Airtable forms?
No, field agents cannot be used in Airtable forms. If you add a field to a form that has AI functionality, the field can be filled out by the end user; however, any AI functionality is unavailable within the form submission experience.
That said, consider ways to gather the necessary information from form submitters and use a field agent to generate summaries, resolutions, or other prompted outputs to achieve your desired workflow efficiencies. You can even send the user an automated email with the field agent’s output if that is helpful for the workflow you are trying to operationalize in Airtable.
Is there an Airtable integration in ChatGPT?
Yes, OpenAI offers an Airtable integration in ChatGPT. You can use this integration to query information stored in Airtable and make updates to your Airtable base directly from ChatGPT.
Read more about this feature in our Newsroom press release.
Why can't my field agent access PDF files in my Google Drive folder?
Field agents are blocked from reading files stored in Google "My Drive" (personal Drive folders) to prevent unintentional exposure of personal documents. If you receive a "no files" error when trying to analyze files from Google Drive:
Verify the folder location — if it's under an individual's "My Drive," the field agent cannot access it.
Move the folder containing your files to a Shared Drive that the integration can access. Once the files are in a Shared Drive, the field agent will be able to read and analyze them.
My field agent can preview a web image but won't save it to my attachment field. Why?
A field agent can successfully preview an image it finds on the web, but saving that image to an attachment field requires downloading the file from its source. If the source website blocks downloads—for example, some stock photo sites, social media platforms, or pages with hotlink protection—the preview still works, but the save to your attachment field fails.
As a workaround, ask the field agent to find and return multiple candidate images in its prompt instead of a single image. Requesting several options increases the odds that at least one source allows downloads, so the field agent can successfully save an image to the attachment field.
How do I reference multiple fields in an AI field's custom instructions?
To reference fields in an AI field's custom instructions:
Click the dropdown next to the AI field's name and select Edit field.
In the "Custom instructions" section, click + Insert field or type
{followed by the field name.Select the field from the list that appears.
Repeat for each additional field needed in the prompt.
The field will appear as a token (e.g., {Campaign Name}) in the custom instructions. If the field name changes later, the token will automatically update.
For prompts requiring many fields, consider organizing them with clear labels and structure to make the prompt easier to read and maintain.
What should I do when a field agent stops behaving the way it used to?
If a field agent that used to work well suddenly gives weaker, inconsistent, or wrong results, work through these checks.
Confirm the AI model - Open the field’s menu (for example, the menu on the field name), choose Edit field agent (or your field’s customize option), and review Model. Providers change and retire models over time. Try another model that supports what you need (including internet or integrations, if you use them) and compare results.
If you use “Enable internet search” - Not every field agent shows this control; when it’s present:
Make sure Enable internet search is still on for the field.
If the toggle is disabled or results fail when the field relies on the web:
Enterprise organizations: an admin may have turned off AI internet access for the org. An admin should check the enterprise AI / internet access settings (wording in your admin docs).
Any workspace: some models don’t support internet tools; the UI can disable the toggle for that reason. Pick a model that supports internet search if web data is required.
Simplify and retest the instructions - Long or highly conditional prompts can be more sensitive when models update. Shorten the custom instructions, use clearer steps, and regenerate a few representative records to see if quality stabilizes.
Check fields referenced in the prompt - If instructions reference other fields, confirm those fields still have the values, types, and shapes you designed for (including linked records and attachments). Schema or data changes often show up as “the field agent got worse” when the inputs changed.
Provider health and deprecation - If outputs fail or stall, use the “AI-enabled field is stuck on Generating” FAQ above.
Before contacting support, if the troubleshooting steps above were unhelpful, then:
Re-run a small test set of records with the current model so you know today’s behavior.
Tighten the prompt (scope, format, examples) if answers became generic or inconsistent.
Keep a short “good output” reference (example cells or a screenshot) so the team can tell normal drift from a real regression.
Does enabling internet access for AI expose my base data publicly?
No, you cannot expose base data publicly just by enabling internet access. Internet access lets AI retrieve information from the web to help answer a prompt; it doesn't publish or share your base data externally.
Can I restrict specific fields from being used by AI features?
No, Airtable doesn't currently support field-level exclusion from AI processing. Use table-level and base-level permissions to control which collaborators, and therefore which AI requests, can access sensitive fields.
Is my data secure when utilizing Airtable’s suite of AI features?
When you use Airtable AI features, including Omni and field agents, your prompts and the base data referenced in those prompts are sent to the configured AI model to generate a response. Airtable's AI features respect your existing base and record permissions: AI can only access data the requesting collaborator already has permission to view.
Airtable doesn't use your data to train third-party AI models. For details on how your data is encrypted and stored, see our Airtable security practices article.
A field agent runs at a point in time—when you trigger it, or when the values it depends on change. It doesn't watch a URL and report back as that page changes over the following days. To keep a value current against a page that updates over time, such as a shipment tracking page, pair a field agent with a scheduled automation.
Set this up in two parts:
Build the field agent that reads the URL. Create a field agent with "Enable internet search" turned on and reference the URL field in the custom instructions—for example, "Report the current status shown at {Tracking URL}." Turn on "Run automatically" so the agent regenerates whenever the values it references change.
Schedule the re-check. Create an automation using the "At a scheduled time" trigger, add a Find records action that selects the records you want to re-check, and add an Update record action that writes a new value into a field the agent references—a "Last checked" date field named in the agent's custom instructions works well. Changing that input is what causes the agent to run again.
You can also re-check records on demand without an automation. Click the dropdown menu next to the field agent's name, hover over Run field agent, and click Outdated cells or All cells in the view.
Every agent run consumes AI credits, so match the automation's schedule to how often the source page actually changes. A daily check across a few hundred records costs considerably less than an hourly one.
Why does my field agent return a different answer each time I run it?
AI models are probabilistic, so rerunning an agent against the same record and the same custom instructions can return wording — and occasionally a different judgment — that is not identical to the previous run. To reduce the variation:
Narrow the task. Specific instructions produce more consistent output than open-ended ones.
State the output format you want, and include two or three examples of a correct answer in the custom instructions.
Use a more constrained field type. A single select or number field agent varies less than a long text one, because the shape of a valid answer is narrower.
Keep a few example cells that you consider correct. Comparing new output against them is how you tell normal variation from a real regression.
How do I write instructions for agents that read a web page?
A field agent that reads a URL needs the "Enable internet search" setting turned on. When the setting is on, the field shows a globe icon next to the field name. If you enable more than 1 tool, you'll see an icon for each.
A field agent doesn't copy a page the way a scraper does - it produces the most likely answer given the page and what the model already knows. That has 2 consequences worth writing instructions for:
The agent can return content that isn't on the page you gave it, such as an older image of a product or a phrase that commonly appears alongside it. Tell the agent explicitly to use only the content at the URL you supply and to return nothing it can't find there.
The agent paraphrases by default. If you're comparing text exactly, say so - for example, "Return the text verbatim. Do not summarize, reorder, or shorten it."
If a page repeats a label in more than one place - for example, a short "Ingredients" line in a summary block and the full statement further down - the agent may take the first match it finds. Name the section you want and the sections to ignore.
To see what the agent can actually read on a page, create a second field agent whose instructions are to output the structure and section headings of the URL with no interpretation, then use those section names in your extraction prompt.
