Airtable automation action: Hootsuite post
Last updated: November 16, 2026
Plan availability
All paid plan types with varying limitations
Permissions
  • Owner / Creator - Can create, delete, duplicate, configure, or rename an automation and edit an automation’s description
  • Editor, Commenter, Read-only (Base collaborators) - Can view an automation’s configuration or copy an automation’s URL
Platform(s)
Consider having Omni create an automation for you. With Omni's AI capabilities, you can use plain text requests to build, update, and query data in your Airtable base.
Creating, managing, and posting multiple social campaigns at once can mean juggling a lot. Airtable’s flexible workflows are a natural fit for keeping track of all those moving pieces. Using the Hootsuite action allows you to schedule your posts ahead of time, with no copy-pasting, as soon as they meet your standards.
Setting up an automation to post via Hootsuite
  2. Open the base where you want to create an automation
  3. Click Automations.
  4. Click + Create new.
  5. Click + Create automation.
  6. Click + Add trigger.
    1. Once clicked, the available triggers will be displayed for you to choose from. Click here to learn more about all available automation triggers. Once you have configured and tested the trigger, you can move on to the next step.
  7. Next, add the “Hootsuite: Schedule post” action.
    1. Click the + Add advanced logic or action option.
    2. Scroll down in the menu that appears and find the “Hootsuite” section.
    3. While hovering over that option, click the Schedule post option.
  8. Now you will configure the “Hootsuite: Schedule post” action:
    1. Feel free to enter a description of what the action will do. You can always add one later if you prefer to skip this step.
    2. Under “Configuration,” click the dropdown below the “Hootsuite account” section. From here, either select a previously connected account or connect a new account. More information on managing connected accounts is available here.
    3. Once you have connected an account, you’ll need to select the social profiles where the post will be sent.
    4. After choosing the social profiles, you can start configuring the “Scheduled time” section. Enter a static date and time or click the cogwheel icon and the Dynamic option to utilize a datetime token from a date field referenced from a field in the underlying Airtable base.
    5. Next, you’ll configure the message that will be posted via Hootsuite.
      1. This message can include a mix of static information including text and emojis, as well as dynamic information from records in Airtable using the blue and white plus button to add those tokens.
      2. You can also add one or more attachments to include in your post.
    6. Then, optionally add any “Tags” you want the post to contain.
    7. After your action configuration looks the way you want it to, click Test action to ensure the message is looking the way you want it to. Feel free to adjust the configuration before moving on to the final step below
  9. Test and turn on the automation - Be sure to test all of the steps in the automation that you are building. Once every part of the automation has tested successfully, you’ll likely be ready to turn the automation on. Find the red colored “OFF” toggle and click it so the automation now appears as “ON” in green
Hootsuite post action use case walkthrough
For this example, let’s say we wanted to leverage the information held in a simple table we created to keep track of all the upcoming articles for a blog that we manage. Our ideal workflow is that once a featured article’s status is set to “Approved,” then a new Hootsuite post is automatically scheduled with all the correct content at that article’s “Post Time.”
  1. Choose a trigger - After creating your new automation, the first thing you’ll need to do is carefully choose the trigger. This trigger will tell the automation when to run, and which record’s information you’ll be using to schedule a post with Hootsuite.
    1. For our example workflow, we’d like to schedule a post whenever a featured article’s status has been set to Approved. We’ll use the When a record matches conditions trigger to ensure that our new automation is triggered only when a blog post has the Approved status and it is one of our featured articles.
  2. Add an action - Once our trigger is configured, and tested, we can move on to setting up our action. Select the “Hootsuite: Schedule Post” action and you’ll then be prompted to select or connect, your Hootsuite account. Once your account is connected the “Social Profiles” dropdown will populate with all the Social Profiles that you currently have set up in Hootsuite. You can choose to use one, or multiple, social profiles to schedule a post for. Now you can specify the following inputs for your future post(s):
    1. Scheduled Time - the date and time your post(s) will be scheduled to be posted
    2. Message - the content you’d like your post to include, and the format for that content
    3. Attachments - any images or other files you’d like to attach to your post
    4. Tags - you can specify comma-separated tags for your post
  3. We’ll start with the “Scheduled Time” input. In our example table, let’s say that we have a date field named “Post Time” that specifies both the date and time that our article will need to be posted.
  4. We can then format the content for our future post using the “Message” input. Finally, we want to make sure we include any attachments that are associated with our article by filling in the “Attachments” input. Below is the configuration for our article example.
  5. At this point, you’ll want to make sure to test your action and ensure everything is configured properly. You’ll now be able to turn on the automation and see your new posts in Hootsuite. If you have any final tweaks to make to a post once the Automation has run- you can always change those posts in Hootsuite before it goes live.
FAQs
What happens if I try to schedule a post in Hootsuite for a date that has already passed?
Your automation will display an error for attempts to schedule posts in the past.
What happens to my automations if my Hootsuite account gets deactivated?
If the Hootsuite account for a related automation is deactivated or disconnected, then the automation will cease to work until a new Hootsuite account is connected and configured.
Which types of Hootsuite social profiles are supported?
Airtable supports choosing the following popular social media profiles for the Hootsuite post automation action:
Can I select a Facebook personal profile to post as in a Hootsuite automation action?
You are unable to select Facebook personal profiles in the Hootsuite action because the Facebook API won’t allow posting to them.
Why did my Hootsuite automation fail when attempting to post messages over 280 characters to X (Twitter)?
X (Twitter) displays the "Message too long" error for posts exceeding 280 characters, causing automations to fail. Messages posted to X via the Hootsuite automation are required to be under X's 280-character limit.
