Documentation Index
Fetch the complete documentation index at: https://support.airtable.com/llms.txt
Use this file to discover all available pages before exploring further.
Airtable technical requirements
Prev Next
Plan availability
All plan types
Platform(s)
Web/Browser, Mac app, Windows app, iOS and Android apps
Related reading
  • Create base share links
  • Embedding Airtable views
  • Getting started with Airtable views
  • Getting started with Airtable form views
The Airtable technical requirements listed below are necessary when using Airtable's desktop and mobile apps, shared links, embedded views, and forms.
Airtable general requirements
Internet, browser, and settings requirements:
  • Internet access
  • For the best performance, we recommend:
    • The latest versions of the browsers listed below. The versions below represent the bare minimum requirement:
      • Chrome 91 or higher
      • Firefox 94 or higher
      • Safari 14.1 or higher
      • Edge 107 or higher
    • JavaScript enabled
    • Cookies enabled
Mobile requirements
iOS and Android requirements:
Mac app requirements
Windows app requirements
Allowlisting Airtable IP addresses
In some cases, general Airtable access or access to certain Airtable features may be blocked by your organization’s network security settings. The list below only represents the static IP addresses that we are able to share publicly. Other features in Airtable such as webhook API pings, scripting actions in automations, and the scripting extension do not utilize static IPs. So, these features might still be affected by your organization’s network security settings even after allowlisting the IPs listed below.
We recommend that your organization allows the following IP addresses:
IP address
Region
3.231.96.120
us-east-1
3.215.151.50
us-east-1
52.44.24.118
us-east-1
34.204.30.184
us-east-1
3.225.92.43
us-east-1
34.236.75.94
us-east-1
44.232.41.45
us-west-2
52.29.196.195
eu-central-1
3.125.75.166
eu-central-1
3.78.197.245
eu-central-1
FAQs
How do I confirm what browser I'm using?
We recommend using tools like whatismybrowser.com to help confirm your current browser's version?
Airtable doesn't support my browser version. How can I access my account?
If your browser version is deprecated, you may not be able to access Airtable and will see a message like what's shown below:
If you see a message similar to the one above, please update your browser to the latest version to continue using Airtable.com.
I can access Airtable.com, but see a message stating my browser will no longer be supported. What can I do?
If your browser version notifies you it will be deprecated soon, you'll see a deprecation notice and date.
I use an unsupported browser (Opera, Brave, etc.). Can I still use Airtable.com?
While an unsupported browser may be able to load Airtable.com, we cannot guarantee Airtable compatibility and recommend using a supported browser instead.
Can Airtable be hosted on-premise?
Airtable is a cloud-based SaaS product, and we do not plan on offering an on-premise or self-hosted solution.
Does Airtable offer an offline access feature?
Offline access to Airtable is not supported, however, there are several options available for exporting your data to access it offline.
If you want to save your current Airtable records offline, you can export data from Airtable as CSV files. Keep in mind that you will need to export attachment files separately. Each table in your base will need to be downloaded as its own CSV.
Note
Exports do not include record-level comments, extension content, field descriptions, or base guide content.
And lastly, you can set up an API integration to periodically fetch your data and save it. You can find API documentation specific to your bases at airtable.com/api.
