Introduction to Airtable basics
Plan availability
All plan types
Platform(s)
Try it in Airtable
Start building in Airtable now
Airtable’s intuitive yet powerful platform gives everyone the flexibility to create their own solution and make work flow faster. Use this article for a high-level summary of core Airtable features, along with links to explore more documentation for each area.
Start creating
  • With the power of Omni AI, you can ask Omni to build you a custom Airtable app and hit the ground running in just a few minutes. You can even ask Omni to update the structure of a base, create AI-generated interface elements, build automations, and more. Whenever possible, this should be the option you use, as it often will save you time.
  • Enterprise Scale users can alternatively utilize a managed app already approved for use at your Airtable organization
  • As always, you can also choose to build an app on your own, from scratch. If it’s your first time building, we recommend that you consider using a template.
Workspaces
Workspaces contain collections of bases and are tied directly to a plan type. You can have multiple workspaces each with its own plan type.
Learn more about workspaces →
Bases
Bases contain all of the information you need for a particular project or collection, similar to a folder that contains individual files. Bases contain and use all of the features listed below (depending on your plan type).
Learn more about bases →
Tables
Every base is organized into tables: distinct groups and sets of data you use in your work.
Learn more about tables →
Records
A record is an individual item in your table. If you’re assembling a staff directory, it’s each person; if you’re tracking inventory, it’s a product.
Learn more about records →
Fields
Fields store rich custom details related to your workflow—and allow you to organize all that information so it can easily be sorted, managed, and analyzed. These are the vertical columns in your table, each one for a different variable associated with a record. Airtable has dozens of field types to enhance your record data.
Learn more about fields →
Views
Views let you see the same information from different angles, and are specific to each individual table in your base. You can use views to show only specific fields or records, and apply other configurations to manage the information in that view.  Views enable each team member to the full picture, whether they’re using the Grid view or other view types like the Form View, Gallery View, Timeline View, Gantt View, Kanban View, or Calendar View.
Learn more about views →
Bring your team onboard
Collaboration
Collaborators are other people that are added to individual bases or entire workspaces.
Learn more about collaboration →
Permissions
Airtable collaborators can be given specific permissions that determine what they can and cannot edit in a workspace or base. Permissions are an important part of healthy team collaboration: with the right permissions, you can ensure that only certain people are permitted to change the information held within your bases.
Learn more about permissions →
Account
Your account page contains information specific to you—like your password, the email address associated with your account, and the number of credits you have. If you're an owner of any workspaces, your account page also gives you easy access to manage the settings (including billing) of those workspaces, as well as workspace and base collaborators.
Learn more about Airtable accounts →
Billing
Learn how to understand and manage billing for Team workspaces and self-serve Business plans in Airtable. For Enterprise billing questions, please reach out to your Customer Success Manager or sales representative.
Learn more about Airtable billing →
Enterprise Scale
Build a single source of truth that connects your data, workflows, and teams so you can all move faster, together. Every Enterprise Scale plan includes personalized guidance from our team of experts. We’ll get you started quickly and set you up for long-term success with our proven methodology.
Learn more about Airtable Enterprise →
Automate and customize
Icons and colors
To provide an additional layer of organization and a splash of design to bases and interfaces Airtable offers helpful icons and different suites of colors (paid plans only). These simple features give a quick visual indicator of what kind of data is held in the underlying base or shown in an interface that end-users will view and interact with.
Automations
Automations help work to flow quickly and seamlessly, across all your tools and processes. They can trigger notifications, streamline redundant work, integrate your tools, run custom code, and more.
Learn more about automations →
Interfaces
Create custom interfaces that give each and every teammate the relevant information they need and a simple way to take action.
Learn more about interfaces →
Extensions
Airtable Extensions plug into the workflow you’ve built in your base, but allow you to add extra functionality—like generating dynamic, at-a-glance summaries inside the base itself. Extensions also allow teams to import information and engage with external services. Like everything you build on top of your base, extensions update automatically and are easy to adjust.
Learn more about extensions →
Expand and scale
Airtable API
Connect Airtable with your favorite apps and services through the Airtable Web API.
Learn more about the Airtable API →
External integrations
Know code? Build your own reporting systems using scripting, our extensions SDK, or by developing on our robust APIs.
Learn more about integrations →
Airtable Sync
Airtable Sync brings records from a view in a base (or an external source with a sync integration) to one or more destination bases, helping you keep information updated across your organization.
Learn more about Airtable Sync →
FAQs
Can I change Airtable’s interface to Spanish, French, German, or another supported language?
Yes. You can display Airtable’s GUI in English (United States), French, German, or Spanish. To change the language setting:
  1. Open your Airtable homepage.
  2. Click your account icon in the top-right corner.
  3. Click Language preferences.
  4. Select your preferred language.
    1. You can also choose Auto to follow your browser or system language when a supported language is available.
What changes when you select a different language?
  • Menu labels, buttons, and other system-generated text follow the language you chose (or Auto).
  • Product labels, including field types and most interface chrome, are shown in that language where translations exist.
What doesn’t change automatically?
Your own content stays as you wrote it, including:
  • Base, table, field, and view names
  • Record data
  • Custom descriptions and labels
Need base content in another language?
  • Rename bases, tables, fields, and similar items yourself—Airtable doesn’t translate user-created names or data for you.
  • Note that if you are looking to translate data inside an Airtable base, then you can prompt an AI text field agent to translate text from another field.
Does Airtable support right-to-left (RTL) languages like Hebrew or Arabic?
The Airtable interface is currently available in English, French, German, and Spanish. Hebrew and Arabic aren't supported interface languages at this time.
Known limitations with RTL languages:
  • Text alignment - Text entered in Hebrew or Arabic fields will display in left-to-right (LTR) format rather than right-to-left (RTL) format across views, interfaces, and automated emails.
  • Interface directionality - The Airtable interface doesn't automatically adjust layout direction for RTL languages.
  • Field and view display - While you can enter Hebrew or Arabic characters into text fields, the text alignment and reading direction won't automatically adjust to RTL conventions.
Potential workarounds:
  • Some users have found success using browser extensions that force RTL text direction, though this isn't officially supported by Airtable.
  • For automated emails containing Hebrew or Arabic text, consider using the Gmail: Send email or Outlook: Send email automation actions with accounts configured for RTL languages, rather than the native "Send email" action.
How can I learn more about Airtable terminology?
Refer to our glossary article to learn more about the terminology that you’ll encounter across Airtable.
