Supported DATETIME_DIFF unit specifiers in Airtable
Plan Availability
All plan types
Permissions
  • Owner / Creator - Can add, delete, duplicate, rename, and customize fields
  • Editors - Sort, filter, group, hide, and copy field URL
  • Commenters / Read-only - Copy field URL
Platform(s)
Web/Browser, Mac app, and Windows app (with some additional limited support on mobile)
DATETIME_DIFF() in Airtable overview
The DATETIME_DIFF() function allows you to calculate the difference between two different datetimes in specified units.
Each specifier has a corresponding abbreviation that works like the long-form version of the specifier—.DATETIME_DIFF(Date, Date2, 'y')—resulting in same output as DATETIME_DIFF(Date, Date2, 'years').
  • The output will default to seconds if no unit is specified or the function does not recognize the specifier.
  • The output will default to milliseconds if the unit specified is not recognized.
The DATETIME_DIFF() function allows you to calculate the difference between two different datetimes in specified units. Each specifier has a corresponding abbreviation which will work the same as the longform version of the specifier, e.g. DATETIME_DIFF(Date, Date2, 'y') will have the same output as DATETIME_DIFF(Date, Date2, 'years').
  • We encourage using the WORKDAY_DIFF() instead of DATETIME_DIFF() if you want to use workdays as a unit.
  • Be sure to nest the DATETIME_PARSE() function within your formula to turn the string into a readable date when attempting to use DATETIME_DIFF() with static dates or dates that are formatted as strings.
Supported DATETIME_DIFF() time units and specifiers
Unit specifier
Abbreviation
 'milliseconds'
 'ms'
 'seconds'
 's'
 'minutes'
 'm'
 'hours'
 'h'
 'days'
 'd'
 'weeks'
 'w'
 'months'
 'M'
 'quarters'
 'Q'
 'years'
 'y'
