Filtering records using conditions
Last updated: November 10, 2026
Plan Availability
All plan types
Permissions
  • Owner / Creator - Can add, delete, duplicate, rename, and customize fields
  • Editors - Sort, filter, group, hide, and copy field URL
  • Commenters / Read-only - Copy field URL
Platform(s)
Web/Browser, Mac app, and Windows app (with some additional limited support on mobile)
Filtering in Airtable overview
Using filters in Airtable allows you to limit what collaborators can access, review, or edit.
  • Interfaces: Filters in interfaces allow builders to create a way for collaborators to interact with specific information that may only relate to individual teams, projects, or insights across visualizations on an interface page.
  • Views: View filters allow builders to filter out records from a view based on your conditions. When a record is filtered out based on a condition, it is not deleted—it's just hidden from the particular view you're using to look at your table.
  • Automations: Conditions in automations allow builder to apply logic so that the automation only runs or performs certain actions when particular conditions are met. The When record matches conditions trigger, Conditional logic in groups of automation actions, and Find records action all leverage conditions to increase the precision of automation runs.
  • Forms: Visibility rules in forms allow builders to control when and whether form submitters can input information in form fields.
What is a condition and how can I use it in Airtable?
Conditions are rules that control:
  • Which records are visible in a particular view or interface
  • Which records are found or watched in an automation run, and whether a particular group of automation actions runs
  • Whether a field is hidden in a form until another field has been entered, or entered in a particular way
Use conditions when you want to:
  • Find a record(s) that meet certain conditions quickly (e.g., records that have a due date after X date and before Y date).
  • Focus on records that meet certain conditions (e.g., the records that have been assigned to me AND have not been marked as completed).
  • Prevent collaborators from seeing certain records.
Conditions in Airtable
Conditions read much like sentences. The example below reads: "Show me the records where the DRI is Jordan Peretz."
  1. Field: Any field in your table. (The “DRI” field using the example above)
  2. Operator: After selecting a field, choose an operator from the pre-populated dropdown menu.
    • Which filter operators are available is determined by the field type. For example, text fields will have filter operators like "contains," "does not contain," "is empty," or "is not empty"; number fields will have filter operators like "is greater than" or "is less than."
      • Note that operators "Is empty" and "Is not empty" do not require you to input a value because the default value is empty.
    • Fields that hold more than one value—linked record fields, lookup fields, and multiple select fields—use array operators instead of the single-value operators. To filter these fields by specific records or values, choose one of these operators:
      Operator
      Shows records where the field...
      Is exactly
      Contains exactly the values you select, and no others
      Has any of
      Contains at least one of the values you select
      Has all of
      Contains every value you select (it can also contain others)
      Has none of
      Contains none of the values you select
    • Looking for an "is any of" operator? On linked record and lookup fields, Has any of is the equivalent of "is any of" on single-value fields such as single select fields.
    • Matching a long list of values at once? Each condition holds one value, but a shared view link can carry many. For more details, see Shared view URL filters.
    Multiple select fields use the array operators above rather than the text operators, so there is no "contains" option for matching part of an option name. To filter on part of a value, add a formula field that returns the select value as text, then filter on that formula field.
    A blank field holds no values at all, so it can never match "has any of," "has all of," or "is exactly." It always matches "has none of," because it genuinely contains none of the values you selected. A "has none of" condition therefore returns every record where the field is empty, alongside the records you were looking for.
    • To leave empty records out, click Add condition, then set the new condition to the same field with the "is not empty" operator and join it with the "And" conjunction.
    • To keep empty records in alongside a "has any of" condition, join the two conditions in the same group with the "Or" conjunction and set the second one to "is empty."
  3. Value: This is the value you compare all of your records against using the field you specified earlier in the conditional statement.
Conjunctions in Airtable
Conjunctions are used to logically connect multiple conditions within filter groups, allowing you to create more complex and precise filtering rules. The two available conjunctions are "And" and "Or".
  • You can use "And" when you want all conditions in a group to be met.
  • Otherwise, you can use "Or" when you'd like any condition in a group to be met.
Using the “And” conjunction example:
In this example, will use the "And" conjunction to create a new condition group where records must meet all of our conditions. Let's get a little more complex with our rules: "We want to see all chairs with a unit cost of over $1,000".
We can break this down into two conditions:
  1. Where the "[Type] [is] [Chairs]", and
  2. The "[Unit cost] is [greater] than [$1,000]".
When adding a second condition, clicking the "Add Condition" button will add both a conjunction and a new condition to be filled in. The "And" conjunction is selected by default. Now we can add our second condition, and by using "And" as our conjunction, we ensure that all records must meet both conditions to be visible in the view.
Using the “Or” conjunction example
If you want any of your conditions to be met in a condition group, you can use the "Or" conjunction. In this example, we'll create a view where we want to see records either:
  1. Where the "[Type] [is] [Chairs]", or
  2. The "[Materials] [has any of] [Reclaimed wood]".
By clicking on the conjunction type, you can choose between "And" & "Or.”
Rearranging conditions
With the conditions menu open from any surface that supports filters, find the six-dot icon to the far right of the condition that you want to move. When hovering over that icon, you should see your cursor/mouse change to a hand. Click and drag the filtering condition to the appropriate ordering location of your choice. Keep in mind that conjunctions (And/Or) may be altered depending on how many conditions you have set or the position of the condition that you are moving.
Removing conditions
With the conditions menu open from any surface that supports filters, find and click the trash icon next to the condition or conditional group that you want to delete.
Using conditions outside of views in Airtable
Using conditions in interfaces:
  • Setting conditional filters for interface visualization layouts
  • Allowing users who have access to an interface visualization the ability to configure their own filters
  • Setting filters for dashboard layouts to gain specific insights into underlying data
  • Utilizing and configuring filter elements (Blank, Record Review, and Record summary layouts only) on interface pages
Conditions in automations:
  • Adding filters to automations allows you to prevent unexpected runs and only perform certain actions or groups of actions when conditions are met. This is important because narrowly-scoped automations are generally more trustworthy and will only update records when necessary.
Conditions in forms:
  • Hiding fields until other fields are entered
  • Limiting which form fields certain form submitters can see
  • Creating efficient form flows to save submitters time and ensure they only fill out absolutely necessary fields
Condition groups and advanced filtering
Nesting condition groups
Now let's expand on this concept of conditional filtering. You can use conjunctions to combine and connect condition groups nested within other condition groups.
Combining conditional groups allows you to start building more and more complex filters. For example, we can create a rule to “Show chairs, AND those chairs must be in stock OR show furniture made of reclaimed wood”:
We strongly recommend playing with conditional groups as you read along. Advanced filtering is a feature with a delightfully mix-and-match feel that is best learned by doing.
Creating new condition groups
There are two ways to create a new condition group.
  1. The first way is from the first level condition group, by clicking on the Add condition group button. This will add an additional condition group nested within the first level condition group we’ve been using up to this point:
  2. The second way to create a new condition group is from within a second level nested condition group. Click the + button inside of the existing condition group and then click Add condition group. This will create a nested condition group on the third level. You can nest condition groups for a maximum depth of three levels:
Some important things to note:
  • You cannot nest a group any deeper than the third level and the option to add a group will be grayed out
  • Though three levels are the maximum depth level possible, you can still achieve complex and precise filtering by combining conjunctions with multiple levels of condition groups:
  • Each level of a condition group can have multiple conditions, but only a single conjunction. Meaning that each condition group can use either “And” or “Or,” but not both.
Understanding relative date filters
An operator that matches a single exact day is a one-day window, so it will only match a record whose date falls on precisely that day. When using date field operators like "is within the past month," "is within the past week," or "is within the past year," it's important to understand how Airtable calculates these time periods:
  • "Is within the past month" means the past 30 days from today, not the previous calendar month. For example, if today is March 11, this filter will show records dated from February 9 through March 11 on a non-leap year.
  • "Is within the past week" means the past 7 days from today, not the previous calendar week.
  • "Is within the past year" means the past 365 days from today, not the previous calendar year.
It’s worth noting that the same holds true for “the next year”, “the next month”, and “the next week” operators. i.e. next year is 365 days in the future from today and so on.
To filter by the current calendar week, month, or year, use the “is within” operator with “this calendar week,” “this calendar month,” or “this calendar year.” These cover the whole period, not a rolling window. For example, on March 11, “is within this calendar month” returns records dated March 1–31, while “is within the past month” returns only February 11 through March 11.
To filter by any other calendar month (for example, all of February), add two conditions to the filter: your date field “is on or after” February 1, and “is on or before” February 28 (29 in a leap year). You don't need a formula field for either case.
Filtering by a number of days
When the interval you need isn't a week, a month, or a year, use one of the four date values that take a number:
  • "Number of days ago" and "number of days from now" each match one specific day - that many days before or after today. Pair them with a point-in-time operator such as "is," "is before," or "is after."
  • "The past number of days" and "the next number of days" match every day in the range. Pair them with the "is within" operator.
After you pick one of these values, type the number into the box that appears next to it.
These values are useful whenever work has to start a set time ahead of a date. In an When record matches conditions trigger, a condition of "Start date" "is" "number of days from now" "16" fires 16 days before each event, so prep records are generated on a rolling basis instead of all at once. For a step-by-step reminder example, see Creating reminder automations in Airtable.
How filters affect interface records added inline
When an interface page has a "Filter by" condition and the element's Add records inline user action is turned on, a record an end user creates on that page is created with the filtered values already filled in, in the same way records created in a filtered grid view inherit the view's values. On a page filtered to where "Department" is "Men's apparel", a record a collaborator adds is saved with that department and stays visible on the page after it's created. On pages where adding and deleting are controlled by a single toggle, this setting appears as Add/delete records inline.
This makes one filtered page per team a practical alternative to building a separate base for each team—keep one table as the source of truth, then give each team a page filtered to the records they own.
Values are only inherited when a condition points to a single, unambiguous value. That includes "is" conditions on text, number, select, multiple select, checkbox, and linked record fields, and an "is any of" condition with exactly one value selected. Conditions such as "is not" or "is not empty", an "is any of" condition with several values selected, and two or more conditions joined by "or" don't give Airtable a value to fill in, so a record added on that page can be created without the value and disappear from the page immediately. When the value has to be guaranteed, set a default value on the field itself or add an automation that fills it when a record is created.
Troubleshooting a "My Tasks" interface page
Interface pages that show each collaborator only their own records—like the "My Tasks" page in Airtable's project management templates—rely on a filter that compares an assignee field to the person viewing the page. If tasks aren't showing up as expected, check the following:
  • No tasks appear for the logged-in collaborator - The page filter needs to reference the person viewing it. Confirm the filter compares your assignee field to the "Current user" value - or, if you filter on an email field, to the "Current user's email" value - rather than to a hard-coded name. When you filter on an email field, the comparison matches the viewer's Airtable account email to the value stored in the field, so confirm the two addresses match before looking elsewhere.
  • The assignee field isn't a User field or an email field - The current-viewer comparison works in two ways. Assign tasks through a User field, which links each record to an Airtable collaborator, and compare that field to "Current user". Or, if your records identify people by email address instead, compare an email, single line text, or formula field holding that address to "Current user's email".
    • The second option is useful when the names on your records come from an outside system, such as a CRM export, and the people viewing the page were never added as collaborators on the base. A single-select or text field storing names as plain text can't be matched to the logged-in collaborator, so either switch that field to a User field or add each person's email address to the record.
    • If the email addresses live on a different table, add a linked record field pointing to that table, then add a lookup of the email field so the address is available on the records you're filtering.
    • For more on setting this filter up, refer to Interface Designer permissions.
  • The collaborator isn't listed in the assignee field - Even with the correct filter and field type, a task only appears for someone whose account is selected in that record's assignee field. Open the record and confirm the collaborator is added there.
  • The page isn't updating - Filters re-evaluate as records change. If a newly assigned task doesn't appear, refresh the interface page and confirm the record matches every condition on the page—remember that conditions joined with "And" require all conditions to be met.
FAQs
Are there any special considerations to be aware of when changing filters in views?
Yes. When you change view filters we recommend turning off any automations that may be associated with the view that you are altering. This is because live changes to filters can often cause unintentional automation runs while you are modifying them.
Where are advanced/nested filters currently integrated within the product?
You can currently access advanced filtering within the view filtering menu, record coloring, conditional form fields, and interfaces. This functionality is not available in the Airtable Automations feature.
What if I try adding a condition to a nested condition group and make a mistake? Is there a way to revert to the original?
You can easily rearrange, add, or remove conditions from any of your condition groups. If you are in the process of building a new view and are playing around with filters, we recommend creating a duplicate view. Within your new duplicate view, you can change filtering without affecting any ongoing workflows or other collaborators.
What are the best practices for migrating my current filter configurations to advanced filter options?
Advanced filters will not change any of the filtering conditions you previously had set up in your views. However, you will be able to add new condition groups—the world is now your oyster!
Using our product example, imagine a customer comes in asking for either:
  1. A living room piece, OR alternatively,
  2. Something made of wood OR above a price point of $3,500 per unit AND is in stock now.
Advanced filters can help you quickly get to the data you need. Here is a visual for the scenario we just described:
Will I be able to copy view configurations that have advanced filters?
Yes, you can copy a configuration from one view to another within the same table. Either follow the procedure described in this article or click on the “Copy from another view” option at the bottom of the filter menu:
This functionality does not exist across other areas of the product, just views. Additionally, there must be at least one other view in the table you are working from in order to see this option.
What is the maximum number of filter conditions per view?
There is a maximum of 49 filter conditions per view. This total is calculated by adding any standalone filter conditions, plus any filter conditions inside of filter condition groups.
What is the maximum number of nested conditional filter groups per view?
There is a maximum of 2 nested conditional filter groups. This means that there are 3 levels of filters possible:
  1. Standalone filter conditions
  2. A conditional filter group
  3. A conditional filter group inside of another conditional filter group
How might title-casing impact a filter using the “contains” or “is” operator?
The "contains" filter is case insensitive and will match records regardless of case, while the "is" filter is case sensitive and will only match records with an exact case match to the filter condition set. To display all relevant records regardless of case, we recommend using the "contains" filter instead of "is."
How do I prevent default auto-selection when opening an interface form?
To prevent auto-selection when opening a form, open the form from the “Add activation project” button, set the default for the select field to an empty value in the property panel, and re-publish.
Can I filter by a list of values copied from a spreadsheet?
Not directly. You can't paste a list into the filter menu, so you add values one at a time. A view can hold up to 49 filter conditions. These options get you closer:
  • Single select and user fields: Use the is any of operator and select every value you want to match in one condition.
  • Multiple select, multiple user, and linked record fields: Use the has any of operator and select every value in one condition. Lookups of these field types work the same way.
  • A shared view: Add the values to the share link as URL parameters. How you repeat them depends on the field type:
    • Multiple select: ?filter_Code=A1&filter_Code=A2 creates one has any of filter.
    • Single select:
      ?filterIsAnyOf_Code=A1&filterIsAnyOf_Code=A2 creates one is any of filter.
    • Text, number, or linked record:
      ?filter_Code=A1&filter_Code=A2&filterConjunction=or. Without filterConjunction=or, each value becomes a separate condition and a record has to match all of them. Note that filterConjunction applies to every URL filter in the link.
