Using Organizations
Last updated: September 17, 2026
Plan availability
Business and Enterprise Scale plans only
Platform(s)
Related reading
Airtable terminology
  • Organizations: All Organizations must have a set member list, managed by a designated person with full administrative rights.
Organizations member types
Organizations represent individual Enterprise accounts and are associated with email domains (e.g., acme.com). So whether you're rolling out Airtable to an entire company or just a department or team, Organizations are linked to single Enterprise accounts.
  • Organization member: A user account owned by an Organization. The user’s email address must match the Organization’s set of email domains; otherwise, the user cannot join as an Organization member. A user account can only be a member of one Organization.
  • Unmanaged user: A user account matches the Organization’s set of email domains but is not owned by the Organization. The most common example of unmanaged users is customers with multiple Organizations (multiple enterprise accounts).
  • External user: A user account that does not match the Organization’s set of email domains (e.g., example.com instead of acme.com). Learn more about managing external users below.
  • SSO-managed external user: An external user who signs in through the Organization’s identity provider, or links an existing account to it. As an exception to the member-only actions below, the owning Organization can administer their account — deactivate, sign out, and sync via SCIM — and the identity provider’s SSO requirement can apply to them. They otherwise remain external users: they can hold collaborator permissions and licenses, but can’t join user groups or org units. For more information, check out the Configuring SSO in the admin panel article.
Managing organization memberships
Understanding how users and members are managed is an essential part of getting the most out of organizations and what you can do with Airtable. Airtable provides admins with three ways to allow a user to become an Organization member:
  • Domain capture: All Airtable users with emails that match their Organization's email domains become Organization members. As an example, when a new user from Acme company creates an Airtable account with their @acme.com email address, they are automatically added as an Organization member in Acme's Airtable instance.
  • Member-by-invite: Unlike domain capture, even though a user's email domain may match an organization's domain(s), they will not automatically be added as an Organization member, instead that user would be an unmanaged user. After accepting an invitation to an Organization-owned workspace/base or being added to a user group, users with emails that match their Organization's email domains are then upgraded to Organization members.
  • Manual: By default, all users are unmanaged or external users. Admins must explicitly upgrade users to members.
Organization members support the account-management actions listed below. SSO-managed external users are an exception for supported actions such as deactivation and signing out, and their linked IdP’s SSO requirement can apply. The link does not let them join user groups or org units or make them eligible for every member-only action:
  • Requiring users to log in via SSO
  • Changing user email addresses
  • Deactivating user accounts
  • Granting the admin role to users
  • Signing users out of all sessions
To access the Users page for your organization:
  1. Visit your admin panel and select Users from the side menu.
  2. From Users, you can see which collaborators are organization members or unmanaged/external users.
To view non-enterprise workspaces where workspace owners are Organization members:
  1. Visit your admin panel and select Workspaces from the side menu.
  2. Select Other Workspaces.
    1. From here, admins can select a workspace(s) and upgrade them to an enterprise account.
What your capture type means
If you see a large number of users showing as “Guest” after a new deployment, check your “Membership Capture Type” in Admin panel > Settings. If set to “Manual,” you will need to manage each user individually or request an account-level change via your Airtable account team.
Capture type
What happens when a user with a matching domain joins
What an admin sees in the Users page
Action needed
Domain capture
User is automatically an Organization member
No Guest tag
User appears as managed Member
None required
Member-by-invite
User becomes a member only after accepting a workspace or base invite
Guest tag until invite accepted
Ensure invites are sent. Once accepted, the Guest tag clears automatically.
Manual
User is unmanaged by default regardless of domain match
Guest tag appears for all unmanaged domain users
Admin must click … > Start managing for each user, or request a capture type change via your Airtable account team.
Organizations' dependencies
  • Organization member: A user can only be a member of a single Organization. Keep in mind that this does not prevent users from being shared on content across Organizations.
  • Unmanaged users: Customers with unmanaged users often have overlapping collaborators across workspaces, but a user can only be a member of a single Organization. This helps to prevent being billed multiple times for the same user in federated organizations.
  • Member-by-invite: Any user account matching the set of the Organization’s email domains and the user account cannot already be a member of another Organization.
    • If multiple Organizations with member-by-invite share email domains, membership will be determined on a first-come-first-serve basis depending on which workspaces/bases a user accepts an invitation to first.
  • Domain capture: When future users sign up for Airtable with a matching email address, they immediately become Organization members. This is only recommended for wall-to-wall deployments of Airtable.
    • Admins cannot stop managing Organization members when domain capture is enabled.
  • Admins upgrading non-enterprise workspaces: Workspace owners will receive an email notification stating the workspace is upgraded to an Enterprise account.
    • Organization members can upgrade non-enterprise workspaces to Enterprise, if they are a workspace owner.
After claiming your users
Once your Organization membership is configured, you'll likely want to:
FAQs
How do I upgrade another user to be an admin for my organization?
Learn how to upgrade a user to be an admin by reading our Users - Airtable Enterprise Admin Panel article.
Do organizations change how billable users are calculated?
No, the shift to organizations does not impact how billable users are calculated. Billable users continue to be based on the number of collaborators included in enterprise-owned workspaces.
Can multiple Organizations share the same set of email domains?
Yes, an email domain can be associated with multiple Organizations because enterprise accounts within the same parent company frequently share email domains.
How does the shift to organizations change how workspaces are upgraded to Enterprise plans?
  • Workspaces are automatically upgraded to the Enterprise plan when created by an organization member.
  • Admins may upgrade non-enterprise workspaces to their Enterprise plan if the workspace is owned by at least one organization member.
Do organizations change how SSO is enforced?
SSO can be required for organization members. It can also be required for SSO-managed external users: when a domain associated with their linked identity provider requires SSO, that requirement extends to those users.
External users must first link their accounts to the organization’s IdP. Turning on SSO required does not link them or make them organization members.
Organizations sharing a domain still need to coordinate their SSO configuration and membership management. See Configuring SSO in the admin panel for setup and external-user onboarding.
