Airtable automation trigger: When record matches conditions
Plan availability
All plan types with varying limitations
Permissions
  • Owner / Creator - Create, delete, duplicate, configure, or rename an automation and edit an automation’s description
  • Editor - View an automation’s configuration or copy an automation’s URL
Platform(s)
Consider having Omni create an automation for you. With Omni's AI capabilities, you can use plain text requests to build, update, and query data in your Airtable base.
Learn how to use the "When record matches conditions" trigger to trigger an automation to run anytime a record in a specified table matches one or more configured conditions.
Considerations before using the “When record matches conditions” trigger
  • The "When a record matches conditions" trigger will run when a record matches the conditions you define in a particular automation’s configuration.
  • Records currently matching the conditions set will not cause the trigger to fire. Records must change states to the matching condition(s) for the trigger to start the automation. More information in the FAQs section below.
  • This trigger is similar to the When a record enters view trigger, except that you don't need to create a view to set it up. This allows you to create a more “self-contained” automation and avoid the problems of accidentally triggering executions or breaking the automation by changing the view it depends on.
  • The trigger runs every time a record changes into the matching state, not once per record. If a record stops matching your conditions and then matches them again, the automation runs again. Build for this whenever your automation creates records, sends a message, or does anything else you don't want repeated.
    • Conditions that span more than one field are evaluated as soon as the last one is satisfied. When someone edits a record manually, that can happen partway through their typing, the trigger doesn't wait for the rest of the record to be filled in. An automation built on a multi-field condition can appear to work for one person and fail for another purely because of the order they filled the fields in.
    • For anything that should happen exactly once per record (generating a set of child records, sending an approval, or kicking off a billing step), trigger on a single field that only ever changes once, such as a checkbox a person ticks when the record is ready. A dedicated "ready" checkbox gives you one unambiguous signal and takes the timing of every other field out of the picture. Avoid basing a one-time automation on a multiple select field, where adding a second value can put the record back into the matching state.
  • A trigger's conditions compare a field to a value you enter, not to another field. Dynamic conditions — the cogwheel that points a condition at a value from an earlier step — are only available in a Find records action or a conditional group of actions, both of which run after the trigger has already fired.
    • To trigger on a comparison between 2 fields, make the comparison in a formula field and trigger on its result. Add a formula field that returns a flag value only when the comparison holds — for example, IF({Completed assignments} = {Total assignments}, "Ready") — then set the trigger's condition to watch that formula field, with the is operator and the value Ready.
  • Records that arrive through a sync are a good fit for this trigger. A synced record arrives with all of its synced fields populated at once, so condition it on a field the automation itself fills in—a linked record field pointing at your destination table, set to "is empty"—and the record stops matching once the automation has processed it. See "Triggering automations from synced records" in Getting started with Airtable sync for the full setup.
Setting up an automation to trigger when a record matches conditions
  2. Open the base where you want to create an automation.
  3. Click Automations.
  4. Click + Create new.
  5. Click + Create automation.
  6. Click + Add trigger.
    1. Once clicked, the available triggers will be displayed for you to choose from. Choose the “When record matches conditions” option.
  7. Under the “Table” section, select the table containing the view you want this automation to watch.
  8. Under the “Conditions” section click + Add condition.
  9. From here, if you are unfamiliar with the process of creating conditional logic in Airtable, then consult this support article.
  10. It’s important to test the trigger at this point so that you can utilize dynamic tokens in the automation action steps. This trigger allows you to pull in information from the record that triggered this automation such as record ID or last modified time.
  11. Again, be sure to test all of the steps in the automation that you are building. Once every part of the automation has tested successfully, you’ll likely be ready to turn the automation on. Find the red colored “OFF” toggle and click it so the automation now appears as “ON” in green.
FAQs
Why aren't the date, or time-based, conditions in my "When a record matches conditions" trigger evaluating correctly?
Automations run on GMT since that is the default timezone that Airtable operates on behind the scenes. When setting up time-based conditions in Automations you may need to adjust times manually or create a formula to auto-adjust times so that the conditions evaluate according to your timezone.
Why aren't all of the records currently matching the conditions I've set triggering the automation to run?
Triggers do not work retroactively. Records that matched the conditions before the automation was configured and turned on will not cause the trigger to run. The record will need to “change states” for the trigger to recognize the conditions being matched.
As a workaround, you could clear out the data from multiple records (just one of the fields related to conditions you've set will need to be cleared) and then press CtrlZ (undo). This will cause the record to change states, thus triggering the automation to run. Using this workaround, it's important to think about how clearing data out might affect other automations or workflows. Be cautious when using this method.
Alternatively, if you find yourself needing to update existing data in your tables we recommend checking out the Batch update extension.
How can I get the automation to reference data in other tables?
If the data in another table is referenced in an action step, then you might be able to reference that information via a token, dynamically using the + button.
However, data in other tables may need further connection via linked record, rollup, count, or lookup fields in order to be referenced in your automation. Think of it this way, if the table you are using in the trigger step isn’t connected via linked record relationships to the other table that you want to pull information from, then the automation has no awareness to be able to inherently make that connection. In these instances, you will want to go and work on the base design a bit more, return to the “Automations” tab, retest the trigger step, and then add in those linked record relationship’s information.
Why does my automation run sometimes but not others when someone adds a record by hand?
Your conditions are probably spread across more than one field. The trigger fires as soon as the record matches, which during manual entry can be seconds after the first field is set and well before the rest of the record is filled in.
Open the record's activity feed and compare the timestamps on the edits. Two edits a few seconds apart, with the automation run between them, confirms it. To fix it:
  1. Add a checkbox field such as "Ready" to the table.
  2. Change your trigger's conditions to watch that checkbox instead of the data fields.
  3. Tell the people entering records to tick the checkbox last, once they've filled in information elsewhere in the record.
Why didn't my automation run when a rollup or count field reached the value in my trigger's conditions?
Rollup and count fields recalculate after the linked record field that feeds them finishes saving. If your trigger watches that linked record field, Airtable evaluates the conditions the moment the link changes — which can be before the rollup has caught up. The condition is checked against the old value, doesn't match, and no run is created. There's nothing in the automation's run history to find, because the automation never triggered.
It doesn't correct itself either. A record only has to change state once for the trigger to miss it, and nothing changes it back.
To confirm this is what happened, open the automation's run history and compare the field values captured at trigger time. A run that fired as soon as the first of several linked records changed, with the rollup still showing its earlier value, is the signature of this problem.
To build around it:
  • Trigger on a field you set once the record is ready — a checkbox someone ticks, or a field an earlier automation fills in — rather than on the linked record field or the rollup itself.
  • Or use the At scheduled time trigger with a Find records action that sweeps for records matching the count, so records missed in the moment get picked up on the next run.
