Creating custom notifications using Airtable automations
Last updated: November 16, 2026
Plan availability
All plan types with varying limitations
Permissions
  • Owner / Creator - Can create, delete, duplicate, configure, or rename an automation and edit an automation’s description
  • Editor, Commenter, Read-only (Base collaborators) - Can view an automation’s configuration or copy an automation’s URL
Platform(s)
Airtable Automations allow you to control when and where you receive notifications. You can easily set up automations to send notifications via email, Slack, or Microsoft Teams to yourself or others.
This guide walks you through building an automation that sends a notification when a record matches a condition you define — for example, when a form submission comes in. You'll set up two notification actions: one via email and one via Slack (or Microsoft Teams).
By the end, you'll have a working automation that:
  • Triggers when a record in your table meets a condition you define
  • Sends an email to the person who submitted the request
  • Posts a Slack message to your team's channel
Creating custom notifications using Airtable automations prerequisites
Before building the automation, make sure you have the following:
  • An Airtable account with a base you want to use
  • An account for whichever notification channel you want to use: email, Slack, or Microsoft Teams
  • An email field or user field in your table, so Airtable knows where to send the message (Email notifications only)
Your automation triggers when a record in your table matches a condition you define. Before building, decide which table you want to monitor, which field you want to watch, and what state that field needs to be in to trigger the automation.
You can use almost any field type. A few examples:
Field type
Example condition
Single select
"Status" is "Needs approval"
Date
"Deadline" is within 3 days
Single select
"Status" is empty (new, unreviewed record)
Step 1: Open the automations panel
  1. Open your base in Airtable.
  2. Click Automations in the top-center of your base.
  3. Click + Create new…, then Create automation.
Step 2: Configure the trigger
  1. Under "Trigger type," select When record matches conditions.
  2. Select the table you want to monitor. (In the example: "Request log.")
  3. Click + Add condition, choose the field you want to watch, and set the condition.
Need a test record? Before moving on, test the trigger by clicking Test trigger. Airtable looks for a record that matches your condition — make sure at least one exists in your table. Click Use suggested record to let Airtable choose one, or Choose record to pick one yourself.
If you have an email or user field in your table, make sure your test record contains your own email address so you can receive the test notification in the next step.
Step 3: Add a Send email action
  1. Click + Add advanced logic or action.
  2. Under the Airtable header, choose Send email.
  3. Fill in the To, Subject, and Message fields. You can mix static text with dynamic values pulled from the triggering record — click the blue + button in any field to insert a dynamic value.
For the example automation:
Field
Value
To
Record (Step 1: Trigger) → Field values → Requestor: Email
Subject
Record (Step 1: Trigger) → Field values → Request Title
Message
Any text you like — consider thanking the requestor for their submission and summarizing what happens next.
Email action configuration example
Step 4: Add a Slack (or Teams) message action
First time connecting Slack? Click + Connect new account from the dropdown and follow the prompts. Once connected, select your account from the same menu.
  1. Click + Add advanced logic or action again.
  2. Under the Slack header, choose Send a message. (Substitute Microsoft Teams if that's your platform.)
  3. Choose your Slack account and the channel where the message should appear.
  4. Compose your message using a mix of static text and dynamic values, just like you did for the email action.
For the example automation, the Slack message uses:
  • Static text: "Incoming Request from:"
  • Dynamic value: requestor's name and request title
  • Static text: "View Request:"
  • Dynamic value: the Airtable record URL
Slack message configuration example
For additional Slack-specific configuration options, see the Slack action article.
Step 5: Test and enable the automation
  1. Click Test automation to run both actions at once — or test each action individually using the test button within each action step.
  2. If the results look right, give the automation a name and optionally add a description.
  3. Toggle the automation on. From this point, notifications will send automatically whenever your condition is met.
Want to set up a similar automation? Instead of starting from scratch, click the … icon next to this automation's name and choose Duplicate automation.
Triggering runs on a specific field change
Sometimes you only want an automation to run when one particular field changes—for example, when a "Status" field moves to "Complete"—rather than on any update to a record. The "When record updated" trigger supports this field-level change detection through its watched fields setting.
To watch only a specific field:
  1. In the "When record updated" trigger, select the table you want to monitor under the "Table" section.
  2. Click Select fields.
  3. Click Unwatch all to clear every field from the watch list.
  4. Select the specific field—or fields—you want to watch.
With only those fields watched, the automation runs solely when one of them changes. Updates to any other field in the record won't trigger it.
Watching a field detects any change to that field's value. To run an automation only when a field reaches a specific value—such as a "Status" of "Complete"—use the "When record matches conditions" trigger instead. Learn more in our Airtable automation trigger: When record matches conditions article.
FAQs
How do I message multiple Slack users at the same time?
Separate multiple usernames with a comma. Note that each user will receive the message individually via Slackbot. If you want everyone to see the messages in a shared space, create a dedicated Slack channel and set the automation to post there instead.
