Settings - Airtable admin panel
Plan Availability | Business and Enterprise Scale plans only |
Permissions |
Platform(s) | Web/Browser, Mac app, and Windows app |
Accessing admin panel settings
To access your admin panel settings:
Open your admin panel.
Click Settings.
Security and compliance in admin panel
Review the Configuring SSO in the admin panel article for a deeper dive into the admin panel's SSO settings. As an admin, you can choose to make SSO either optional or required for each of your federated domains.
If you make SSO optional, collaborators can use SSO or log in with their email addresses and passwords. If a user does not have a password enabled, they can set one by visiting airtable.com/forgot.
If SSO is required, all users within that domain must use SSO to sign in to Airtable. If you make SSO required, all users within the organization’s verified domains will have to use SSO to log in to Airtable. Requiring SSO allows you to better manage access to Airtable and ensures that your users use the most suitable authentication method.
The Security & compliance section of the admin panel is made up the following sections:
Email domains and SSO configuration - This tool allows admins to verify domains, giving complete control over their associated user accounts.
Fixed Web Session length - Set how long collaborators can stay signed in to Airtable on the web before they have to sign in again. Learn more in this section.
Enable Change Events (Enterprise Scale) - Turn on/off change events logging and API access. This feature requires enablement; please contact your account manager for access.
Sensitivity labels - Provide custom sensitivity labels that builders can add to their apps. Labels appear in base and interface navigation. Helpful for admins looking to provide a visual cue of how sensitive the data contained in the Airtable app is so that end users can take preventative measures to ensure that data doesn’t get accidentally shared unintentionally.
Additionally, there are a few settings that only Enterprise Scale plan admins have access to:
Two-factor authentication - (a.k.a. multi-factor authentication) This feature allows admins to require that enterprise members (“On for members only” option), all users that access enterprise content (“On for all users” option), or no one utilizes two-factor authentication (the “Off” option). Contact our sales team if you are interested in learning more about enabling two-factor authentication.
Custom terms of use - Configure terms of use (TOU) that users must accept before accessing your organization's data. For more information, check out our Custom terms of use article.
HIPAA - Learn more about HIPAA here.
Enterprise Key Management (EKM) - Enterprise key management is discussed in this support article.
Restrict access to specific IP ranges (Enterprise Scale only) - Learn more in the section below.
Restrict outbound resource access (Enterprise Scale only) - Control whether members can access Airtable workspaces, bases, and interfaces owned by external organizations, including retroactively revoking existing external access. Learn more in our Restricting outbound resource access in Airtable article.
Sharing and data in the admin panel
The "Sharing & data" section of the admin panel is comprised of a group of “Sharing” settings and another group of “Access” settings.
Sharing settings
Org unit membership (Enterprise Hub) - Establish the default setting for how users are added to your org units. Click the > icon to adjust the following settings:
Admin review - Manage the ability to manually review each user before adding them as org unit members. A few notes:
This prevents automatic assignment from SCIM/group invites. You’ll need to update the org unit setting to “Automatically add invited users” in order to auto-claim users into the org unit.
Users not yet claimed by the org unit will be labeled as “Guest,” which is distinct from “external” (off-domain) users.
Automatically add invited users - Manage whether users invited to your org unit’s bases, workspaces, interfaces, or user groups are automatically added as org unit members.
Collaborator invites - Control users' ability to invite other users outside your organization and domains. Click the > icon to adjust the following settings:
Unrestricted - Users can invite any user to organization content.
Restricted to your organization’s domains - Users can only invite other users with email domains matching their organization domains. If you enable this setting, an “Email domain allowlist” will appear. To allow a new external domain, click the collapsed down arrow so that it appears up and enter a domain (ex. airtable.com). To remove a previously allowed domain from the list, click the X icon next to that domain.
Restricted to org unit members - (Enterprise Hub only) Users cannot invite non-member and non-org unit user groups to org unit resources. The following actions are also taken:
Non-member collaborators are removed from all org unit resources when the invite restriction is enabled for the first time.
Non-member collaborators are removed when workspaces, bases, and user groups are moved into the members-only org unit.
Org unit resources cannot be moved outside the org unit to bypass collaboration restrictions.
Org units previously using the "Autoclaim" membership capture type are updated to "Manual."
Super admins and org unit admins can add new members via the admin panel's "Global Users page" and the org unit's "Users" page.
Portal guest invites - (Organizations with the Portals add-on only)Prevent users from inviting portal guests outside of your specified email domains. Click the > icon to adjust the following settings:
Disabled - When this option is chosen, this will potentially cause several things to occur:
Users won’t be able to invite new portal guests.
Choosing this option hides the “Invite Guest Users” tab in the interface share dialog.
Any pending portal user invites will no longer work, meaning the potential portal user will not be able to accept the invite.
This will also remove portal users from the list in admin panel.
Unrestricted - When this option is chosen, users can invite portal guests from any external email domain.
Restricted to guest user email domains - Choose this option to allow users to invite portal guests only from specified email domains.
If you enable this setting, an “Additional allowed email domains” section will appear. To allow a new email domain to be invited as a portal guest, click the collapsed down arrow so that it appears up, enter a domain (ex. airtable.com), and click Allow. To remove a previously allowed domain from the list, click the X icon next to that domain.
Prevent public sharing of interface pages - This prevents the creation of share links for interface pages. Note that any existing publicly shared interface pages will remain accessible, as this option only prevents the creation of new publicly shared interface pages.
Share links - Control which users can access your organization’s shared base links or shared view links. Note that this setting will also affect the behavior of public interface pages.
This setting allows admins to restrict who can access share links across your organization. Individual share link restrictions can also be set within the base UI. There are three options to choose from, each with separate options specific to it:
Public - Share links are publicly accessible by default, but can be made private individually.
Flexible - By default, share links are restricted to your organization's email domain. However, restrictions can be removed on individual share links. There are also some additional configuration options:
Email domain allowlist: If needed, add email domains that are exempt from this setting. Users with those email domains will be able to access share links.
Keep existing share links public: If you change this setting from Public to Flexible, you can optionally allow existing share links to remain public.
Private - Users outside of your organization’s domain can’t access shared links. End users will need an Airtable account and will be required to log in to Airtable so that we can verify that their login domain matches a domain associated with your organization(s) or additional domains configured in the email domain allowlist. Note that if any share link has email domain restrictions, is password-protected, or an admin has made share links private, then iCal integration links will not be able to sync because the iCal link is no longer able to authenticate.
Additional settings:
Allow unrestricted access to password-protected shares: Allow anyone to access share links that are password-protected.
Allow access to shared forms: Allow anyone to access shared forms.
Members only - Users who are not approved members of your org will be prevented from accessing share links. The same “Additional settings” from “Private” are also available with the “Members only” setting.
When share links are set to Private or Members only, users must be signed in so Airtable can verify their domain. Logged‑out users are prompted to sign in. Users not on an admin‑approved domain see “This private share link is no longer available” or permission errors. This experience can also happen when the Flexible setting is enabled, depending on the email domain allowlist that an admin has configured.
To allow unauthenticated access, set share links to Public. Otherwise ensure users sign in with an approved‑domain account.
Restrict user group creation to admins - Toggle ON/OFF non-admin users’ ability to create user groups. Toggling this option on means that only admins can create user groups, so that users without admin privileges will be unable to create or modify user groups.
Data settings
Data export (Enterprise Scale plans, desktop only) - Control which users can print, download CSVs, and copy data to the clipboard from org unit apps. These settings enable admins to block one or more export methods for their selected audience.
Audience options:
Unrestricted
Restricted to members
Restricted to all
Export methods:
Printing
Downloading CSVs
Copying data to the clipboard
Data retention policy (Enterprise Scale plans) - Customize how long data is retained in trash and revision history, and create custom policies to manage inactive bases.
By default, the revision history is set to 3 years, and trash retention is 30 days. An inactivity deletion policy can also be enabled, which automatically moves bases that haven’t been edited in a chosen time range to the trash. Admins receive a summary of bases scheduled for deletion every 30 days.
Synced views - Control which bases can receive synced data from organization bases.
Restrict HyperDB installation (Enterprise Scale plans) - Limit installation of HyperDB-backed data sets to bases owned by this org unit.
File attachments - Control which attachment file types can be uploaded to Airtable bases in your organization.
Access settings
Synced view restrictions - Control which bases can receive synced data from Airtable bases.
Admins can choose between:
Unrestricted: Any base, within or outside your organization, can receive synced data from syncable share view links within your organization. Please note that when syncs are not restricted, users can sync data into bases that are not part of the organization.
Restricted: Users are only allowed to set up syncs between existing bases within your organization. Bases outside your organization aren't able to receive syncs.
The share view configuration defaults to restricting syncs within your organization, but can be disabled on a share-by-share basis. Admins can also decide who can disable restrictions for views by choosing from Anyone, Admins and creators, or Only admins.
With this setting enabled—and because individual share views are controlled separately—existing syncs outside your organization will continue to function.
The "Restricted" option prevents bases outside your organization from being sync targets by default.
Off: This option is the most restrictive and prevents all shared views from syncing to any destination base.
This list includes all synced tables that can sync data from your organization, regardless of whether a sync is active. Admins can also select "Review share links" to view, sort, filter, and download share links, allowing them to sync outside their organization. The three columns are calculated as follows
Total syncs: The total number of synced tables created from this shared view (internal and external).
Syncs to Airtable: The total number of synced tables created based on the shared view inside the Airtable corporate account—data that is likely being shared with Airtable. These tables are sometimes created during onboarding and service engagements or used to share information related to joint account planning between the customer and Airtable.
Other outside syncs: The total number of synced tables created—based on this shared view—that aren't part of your organization or part of the Airtable corporate account. Admins may want to keep some of the included data within their organization. If so, shared view links should be turned off but keep in mind that some desirable external syncs can be counted in this number, including:
Syncs with external consultants or vendors.
Syncs with other organizations under the same corporate entity (e.g., Division A and B, both of which are in Omnicorp Inc.)
File attachments - Control which attachment file types can be uploaded to Airtable bases in your organization. There are 3 restriction options that admins can choose from:
Unrestricted: No restrictions. All file types are allowed for upload.
Restricted: Files, regardless of their type, cannot be uploaded to any attachment fields in bases that are part of the organization's workspace(s).
Custom allow: Specific file types can be set as allowed for upload in attachment fields. Admins can choose to allow one or more of the following options:
Image - audio - video - PDF - Other: Create a custom, comma-separated list of allowed file types that your organization can upload to Airtable attachment fields. For more information on common MIME types, please visit this link.
Managing how users are added to org units
This feature is only available for admins on the Enterprise plan with Enterprise Hub enabled. Airtable’s org unit membership setting allows admins to determine how users become members of org units.
Users are only eligible to be assigned to an org unit after an admin manually assigns them to one.
If your org unit is connected to user groups that manage its assignment, the org unit membership setting can only be changed once the user groups are disconnected.
To manage how users are added to org units:
Click Settings, then Sharing & data.
Click the ˲ icon at the end of the “Org unit membership” row.
Click the pencil icon at the end of the “Org unit membership” row.
Select Admin review or Automatically add invited users.
If “Automatically add invited users” is selected, users may be assigned to org units once they are:
Invited to a workspace, base, interface, or user group that belongs to an org unit.
Collaborating on a workspace, base, or interface moved into an org unit.
A member of a user group that is moved into an org unit.
Click Save.
Integrations and development in the admin panel
Integrations & development overview
The "Integrations & development" section of admin panel is made up of the following sections:
Integrations (Enterprise plans only)
Block integrations in automations and external source sync - Turn on/off the usage of automations and external source syncs that communicate with third-party services unless they're on the allowlist.
Block sync via emailed data - Prevent users from syncing data into Airtable through email.
Block sync via API - Prevent users from syncing data into Airtable through API requests. API access also needs to be granted for API endpoint sync.
Block admin panel sync - Prevent admins from syncing admin panel data to Airtable bases. Consult this article section for more information.
Show previews of Airtable links in Slack - Turn on/off previews of organization-owned base and workspace links to authenticated users in Slack.
Block Google Drive shortcut integration - Turn on/off users from automatically creating shortcuts to Airtable bases in Google Drive.
Development
Block API access to organization-owned bases and workspaces - Control who can use API via personal access tokens to access organization-owned bases and workspaces.
Block API access for third-party integrations - Turn on/off guests and external users from granting third-party services that aren't on the allowlist API access to organization-owned bases, workspaces, and interfaces. Additionally, prevent org members from authorizing third-party integrations that aren't on the allowlist.
Prevent development of custom code - Turn on/off users from developing custom extensions, writing scripts, and installing scripts from the marketplace unless the user is on the developer allowlist.
Extensions (Enterprise plans only)
Third-party extensions - Control which extensions created by third parties can be used in your organization. All third-party extensions are reviewed for security and functionality by Airtable
Blocking integrations in automations and external source sync
This setting allows organizations to prevent usage of automations or external source syncs that may communicate with external services (outside of Airtable).
An allowlist will appear when you enable this setting. You can then allow or deny each integration based on your organization’s security practices.
At the bottom of the allowlist, you can disable or enable all integrations.
Lastly, integrations that require additional configuration will appear below the allowlist. Currently, only the Jira Server / Data Center integration requires this additional configuration.
Preventing development of custom code (Enterprise Scale plans only)
When this setting is enabled by an Enterprise Scale plan admin, users will not be able to interact with Airtable features that enable the deployment of custom code within your organization unless they are explicitly granted permission. This includes the scripting extension, script templates, the Run a script action within automations, as well as custom extensions. To enable this functionality for your entire organization, keep this setting turned off.
To prevent the development of custom code:
Click Settings.
Click Integrations & development.
Click the arrow icon to the right of “Prevent development of custom code.”
Toggle the button next to “Prevent development of custom code” to “ON.”
If this setting is enabled, you can optionally add specific developers to an allowlist, allowing them to use these custom code features. To add a developer to the allowlist, enter their email address in the space provided and click "Allow". Developers previously added to the allowlist can be removed by clicking X next to their email address.
3rd-party extensions are built and submitted to the Marketplace by third parties and reviewed for security and functionality by Airtable. They do not include the partner extensions that Airtable has closely vetted. Within both categories, there are three options that allow admins to control which extensions can be used:
Allow all: Allows users to access and use all third-party extensions.
Deny those that access non-Airtable servers: Disallows third-party extensions that send data to non-Airtable web servers.
Deny all: Disallows all extensions.
As of March 26, 2021 this setting will default to the “Deny those that access non‑Airtable servers” option. Admins can select one of the other options to opt-out of that default.
When an extension is disallowed in your organization, users will still be able to see all extensions in the Marketplace and click “Install,” but they will be met with an error message instructing them to contact their admin when they attempt to run the extension.
Block API access for all third-party integrations, unless explicitly allowed (Enterprise Scale plans only)
This setting allows Enterprise Scale plan admins to manage access to third-party integrations across their entire organization.
If this setting is "Off," org members can use third-party integrations.
If this setting is "On," org members cannot use third-party integrations unless they’re on the allowlist.
In addition to this admin panel setting, you can also manage the third-party integrations already authorized by your users and service accounts:
AI settings
When the AI setting is toggled off it will prevent AI from being used in all organization-owned workspaces
To enable AI in admin panel:
Click Settings.
Click AI settings.
Toggle on the “Airtable AI” switch.
If you cannot toggle on this setting, contact Airtable’s sales team to add Airtable AI to your Enterprise Scale or Business plan.
Once toggled on, admins can choose 1 or more AI platforms to allow at their organization. Toggle on or off the platform(s) that you want to allow under the “Status” column and then click Continue.
Enabling at least 1 AI platform is required.
Workspace owners can also choose to disable AI on the workspace settings page even if admins have enabled that workspace for AI in the admin panel settings.
Restricting AI access by workspace
When the Airtable AI setting is toggled on, you can choose to either:
Allow in all workspaces - (Default) This setting allows AI to be utilized across any workspace across the org you are managing.
Allow only in selected workspaces - Click the option to “Allow only in selected workspaces” and create an allowlist of Workspace IDs where the feature can be utilized. To add a new workspace to the allowlist:
Navigate to your organization’s admin panel and click on the Settings page.
Click the AI settings tab.
Then, click the “Workspace allowlist” dropdown, enter a workspace ID, and click Allow.
Controlling AI platform and model developer usage
Airtable Omni requires that OpenAI and/or Anthropic (Amazon Bedrock) models are enabled. If other AI models such as Gemini, Meta, IBM, or Amazon Titan/Nova are the only models enabled, Omni will not be available for use across your organization.
If you need to modify which AI platforms/models can be used at your org:
Click on the setting next to the “Restrict AI platforms & model developers” section. This will either be Restricted or Allow all depending on your org’s current settings.
Next, you can change the setting to Allow all to enable all current, and any future, platforms/models for usage at your organization.
Alternatively, you can change the setting to Restricted. Then, under the “Platforms and model developers allowlist” section toggle on or off the different platforms/models under the “Status” column.
Lastly, click Save to save any changes you’ve made.
Enabling Omni
This setting allows you to control whether Omni can be used in all organization-owned workspaces.
By default, this option is turned “On” meaning that Omni is available in all of the workspaces where AI is enabled.
In EUDR countries, this option is turned “Off” by default.
Omni can also granularly be disabled at the individual workspace or base level
Admins can turn this setting off, which will prevent anyone in the organization from using the AI assistant in any organization-owned workspace.
Controlling AI access to the internet
The “Enable internet access” setting allows you to control whether AI can access the internet.
By default, this option is turned “On,” meaning that it is available to all the workspaces where AI is enabled.
Admins can disable this setting, which will prevent anyone in the organization from allowing AI to access the internet.
Allowing web prototype generation
The “Enable AI web prototype generation” setting determines whether end users can generate web prototypes via a field agent.
AI Labs access
The “AI Labs: Get early access to new AI features” setting allows people at your organization to test new Airtable AI features before they're released. This helps us improve AI features before they are generally released.
By default, this option is turned “Off,” meaning that an admin will need to enable this setting for their organization to test AI features that are under development.
Please note that since features are in development, their functionality may change over time, potentially causing unknown downstream effects. We recommend using caution when signing up to test features via AI Labs.
To review your available AI credits and usage:
Click Settings.
Click AI settings.
Click the arrow icon to the right of “On.”
Click the arrow to the right of “View AI credit usage.”
Check out our AI billing article to learn more about how AI credits work.
For Enterprise Scale admins, AI credit usage can also be found in the Reports page.
Enabling Canvas
Airtable Canvas, currently in open beta, lets members build custom apps, reports, and presentations on organization-owned bases using AI. Canvas currently only runs on some AI models, so it needs Airtable AI turned on and Anthropic or Amazon Bedrock to be allowed as a model provider before an admin can turn it on. Learn more about Canvas and admin dependencies in this support article.
To enable Canvas:
Click Settings.
Click AI settings.
Make sure the Airtable AI switch is on.
If AI is limited with Allow only in selected workspaces, add every workspace, where base members should be able to use Canvas, to the workspace allowlist.
Next to Restrict AI platforms & model developers, choose Allow all, or choose Restricted and turn on Anthropic or Bedrock in the Platforms and model developers allowlist.
Turn on the Enable Canvas switch.
If the Enable Canvas switch is greyed out, hover over it to see which requirement is missing: Airtable AI, or a supported model as an allowed provider.
Enterprise Hub: Each org unit has its own Enable Canvas switch. A dash in place of a switch means that org unit's AI settings block Canvas.
Compliance: Canvas isn't available to organizations under HIPAA compliance, with regional data residency, or using Enterprise Key Management (EKM). Canvas stores data to run your projects, and Airtable's normal data retention rules don't cover it.
Workspace owners can still turn off AI for their own workspace, which also disables the Canvas feature in that workspace.
Org resources
The "Org customization" section of the “Org resources" tab allows admins to manage their organization’s logo, brand colors, and add a custom contact admin message. Learn more general information about organization branding in this article.
Customers using Enterprise Hub can also upload logos and configure brand colors on the individual org unit level as well. The same instructions apply as mentioned below, however, super admins will want to make sure to pay close attention to whether they are adjusting logo and brand colors at the organization or the org unit level.
To manage your organization’s logo
Be sure to upload a square image of your organization’s logo. The aspect ratio must be 1:1 (i.e. The width and the height must be the same).
The image should be at least 48x48 pixels in size, but can be larger.
Click the Settings tab on the left side of admin panel.
Under the “Org customization” section, click the pencil icon to the far right side of the "Organization logo” option. Note that org unit admins / admins not using Enterprise Hub will see an Edit button instead of the pencil icon.
You’ll see options to upload a “Square logo” as well as an optional “Horizontal logo.”
Click the pencil icon next to the logo you want to update.
Click the X option next to a logo that you want to remove.
Under “Preview: background color” you can choose from a palette of Airtable colors, including brand colors, to preview how the logo and colors will appear to Airtable end users. You can also toggle between Light and Dark mode under the “Preview: view mode” section.
Click Save once you are finished making updates.
To manage your organization's brand colors
Under the “Org customization” section, click the pencil icon to the far right side of the "Brand colors” option. Note that org unit admins/admins not using Enterprise Hub will see an Edit button instead of the pencil icon.
If your organization has not already created a branded color set, click 'Create a color set'.
Name the color set and give the first color a name and a hexadecimal color code.
Each color will be represented by a hexadecimal color code. You can find more information about hexadecimal color codes on Wikipedia, and a tool to convert RGB color codes to hexadecimal codes at rgbtohex.net.
If you like, you can also click on the circle showing the current color to open a menu where you can use a color wheel, a color dropper, or enter a RGB or HSL value to determine a color. We only recommend using the color wheel or dropper options when you do not already have a hexadecimal code. To change the menu’s coloring format (RGB, HSL, or hexadecimal) click the up and down arrow icon and enter the value of the format that your organization uses. Note that a color’s RGB or HSL values will be shown as a hexadecimal color code in the main color set menu.
Colors are automatically detected as being most accessible with white or dark text. If you’d like to manually override this, you can click Change, and select Dark or Light from the dropdown “Is this color dark or light?” The preview on the right can assist you in making your decision.
Click + to add a new color, click on an existing color to edit that color, or remove it from the color set by clicking the trash icon.
A color set can have up to 30 colors.
Click and drag a color to reorder it relative to other colors in the set.
Click Save to make the new color set available for your organization.
Click Done to update the color set when you are finished making updates to an existing color set. This will update the color set for your organization.
To manage your contact admin message
Under the “Org customization” section, click the pencil icon to the far right side of the “Contact admin message” option.
A new window will open, allowing you to preview and edit the Title, Message, and Contact method.
To save any changes you have made, click Done.
To manage your organization’s “Upgrade request” modal
Under the “Org customization” section, click the pencil icon to the far right side of the “Upgrade request” option.
A new window will open, allowing you to preview and edit the Title, Message, and Button action.
For button actions, you can either select Manage requests in Airtable or Go to URL or service desk. If you select the Go to URL or service desk option, then you’ll need to enter a URL to redirect the user to for additional assistance.
Additionally, you can choose to “Use a different action for external users” and select between the same Manage requests in Airtable or Go to URL or service desk options.
To save any changes you have made, click Save.
The "Apps & Components" section of the “Org resources" tab allows admins to manage who in their organization can create, modify, and delete managed apps and components. Learn more about this feature in this article.
Allowing or restricting managed apps and components across an organization
Click the Settings tab on the left side of the admin panel.
Then, click the Org settings tab.
Scroll down to find the “APPS & COMPONENTS” section.
Here you will find the “Restrict managed app & component creation in this organization” setting.
When toggled on, this setting will globally prevent components from being created and published across the organization. When the option is toggled off, all users across the organization can create and publish apps or components to the library.
Click the ← Back to Settings button near the top left corner of the page when you are finished updating any settings here.
Adding or removing specific users to or from the allowlist
To create an allowlist of users in your organization who can create and publish apps and components:
The “Restrict managed app & component creation in this organization” setting mentioned above must be toggled on to create the allowlist.
Click and expand the User allowlist option.
Enter a single email address of a user in your organization and then click the Allow button. To remove a user click the X next to the email address of a user you want to remove from the allowlist.
Preventing org unit admin edits (Enterprise Hub only)
Toggling on this setting will block individual “Org admins” from being able to make edits to the allowlist settings for their org unit in their admin panel. Only “Super admins” will be able to make edits.
Toggle on the “Prevent org unit admin edits” setting.
Managing individual org unit access (Enterprise Hub only)
This section will allow you to see and modify the “Status” (i.e. Whether or not the org unit has allowlist restrictions turned on. You’ll also be able to modify the individual org unit’s allowlist from here.
General actions:
Search org units - Search for an org unit by name. This is helpful when you are managing multiple org units.
Doesn't match default - Checking this box will filter out any org units that are currently set up with an allowlist that matches the default allowlist settings.
↓ CSV - Clicking this button will generate a CSV file of the current settings listed in the table. The CSV will contain 3 rows of data: Org units (name), Restriction status, and Allowlist (the email addresses of any users who have access to manage apps and components for the corresponding org unit).
Apply default - This option allows admins to apply the default allowlist to all of the org units shown in the table. You can also select one or more org units by clicking the checkbox next to its name and apply the default allowlist to each org unit you’ve selected.
Individual org unit actions:
Status - Turn the restriction On or Off for an individual org unit.
Allowlist - When the restriction is on, click the pencil icon to edit the allowlist of users who can add or modify apps and components for that particular org unit.
… - The options available in this menu will change depending on the status for each org unit. If the org unit’s status is off, then you can click the icon and then click “Apply default” to turn the restriction status to On and apply the default allowlist. For previously enabled org units, this option will not be available unless you turn the org unit restrictions off first.
Restricting access to specific IP ranges
Restricting IP addresses is only available on Enterprise plans, and restricting individual IP addresses is unsupported. This feature is available by request only, so you should work with your account team or contact Support to request it.
IP restrictions allow enterprise admins to specify a list of approved IP addresses or CIDR blocks. Only users connecting from these approved IPs can sign into the enterprise organization. This ensures corporate data is only accessed from trusted network locations.
Protection: Restricts where users can access your org from
Configuration: Customer self-service via Admin Panel (You may need to request the feature from your Airtable account team if it hasn’t previously been requested.)
Click Settings.
Click the Security & compliance tab
Scroll to the “Restrict access to Airtable to specific IP ranges” setting and toggle the setting on.
Click on IP ranges allowlist.
Enter a CIDR (Classless Inter-Domain Routing) block in the box provided and click Allow. It may take a moment for the newly allowed CIDR block to populate in admin panel. Continue this same process for any additional IP ranges that you want to allow.
Click the X next to any CIDR block previously allowed to remove that CIDR block from the allowlist.
Use case: Prevent employees from accessing corporate Airtable from unauthorized locations (e.g., coffee shop wifi)
For example, with IP restrictions set:
User can sign into user@enterprise.com from their office’s Wifi
User cannot sign in to user@enterprise.com from a public coffee shop’s Wifi
Setting a fixed web session length
Fixed web session length controls how long collaborators can stay signed in to Airtable on the web before they have to sign in again. The default is 1 year.
This is a fixed limit measured from the moment a collaborator signs in, it is not an inactivity timeout. If the session length is set to 12 hours, collaborators are signed out 12 hours after signing in, even if they were working in Airtable the entire time.
To change the session length for your organization:
Click Settings.
Click Security & compliance.
Select a session length under "Fixed web session length."
Admins can choose from the following session lengths:
Default (1 year)
4 hours
12 hours
1 day
3 days
1 week
1 month
These are the only available session length options and custom session lengths can't be added.
Admins can't extend web sessions beyond the 1 year default.
Collaborators on plans without an admin panel (Free or Team) stay on the 1 year default, because this setting is only configurable from admin panel.
FAQs
What admin panel pages can I access based on my admin role type?
Super admins and org unit admins can access all of the category pages listed below.
All other roles’ access is individually noted below.
Page | Permissions (Enterprise Scale plans only) |
Super admin (Enterprise Hub only) | |
Super admin, Org unit admin, User admin | |
Super admin, Org unit admin | |
Super admin, Org unit admin, Integration admin | |
Why is image analysis not showing the “Unsupported file types” error when trying to use it?
After upgrading to a Business plan, PNG, JPG, and WebP image analysis is only available after enabling Airtable Labs.
Why can’t I use image analysis via the AI agent fields after upgrading to a Business plan?
After upgrading to Business, PNG, JPG, and WebP image analysis is only available after enabling Airtable Labs.
What does the “Unrestricted” setting under synced views allow?
“Unrestricted” is the default behavior. With this setting, synced views can flow to any destination base. including bases outside your organization entirely.
Here's a summary of all three options (Admin Panel → Settings → Sharing & data → Synced views):
Setting | Setting Overview |
Sync off | No shared views can be synced to any destination base. Most restrictive. |
Unrestricted | Syncs are enabled with no boundaries; data can flow to bases inside or outside your organization. |
Restricted | Only bases within the same org unit can receive synced data by default. Admins or creators can override this for individual share links. |
How do I share a dataset across org units without allowing syncs to leave my organization entirely?
In Enterprise Hub, the synced views setting is configurable per org unit, so you don't have to choose one policy for your whole organization. To enable cross-org-unit syncing for a specific org unit without opening up external sharing, a super admin should:
Open the admin panel.
Click Settings.
Click Click
Click Data, then Synced views.
Locate the source org that owns the dataset and set its status to “Unrestricted” under the “Status” column.
Keep all other org units set to “Restricted” to prevent data flowing outside the organization from those units.
Ensure that users who need to sync the dataset are members of the source org unit. Org unit membership is required to access datasets published from it.
This allows the targeted org unit's data to flow across internal org units while keeping the remaining org units locked down.
How does the allowlist work for the Sync API and service accounts when "Block API access to org-owned bases and workspaces" is enabled?
There are two distinct steps, authorized by two potentially different identities:
Setting up the sync (generating the apiEndpointSyncId / endpoint URL): this is an authenticated API action, so the user performing the setup must be on the API access allowlist. If only service accounts are allowlisted and the setup is done by a human user who isn't, the setup step will be blocked. To create the endpoint sync, add that user to the allowlist (at least temporarily) so they can generate the apiEndpointSyncId.
Ongoing sync traffic: once set up, each sync request is authorized by whatever credential makes the call. If you push data using a service account PAT, the service account must be on the allowlist and stay on it for those calls to keep working. The user who did the initial setup does not need to remain on the allowlist for the service-account-based syncing — unless they still need their own PAT access to org-owned bases for other work.
