Linking existing records using automations
Last updated: November 9, 2026
Plan availability | All plan types with varying limitations |
Permissions |
Platform(s) | Web/Browser, Mac app, and Windows app |
Automations that link records involve multiple configuration steps and require careful field mapping. This article provides high-level guidance on the automation structure for accomplishing that. For detailed step-by-step instructions on creating automations, including triggers and action configuration, see our Getting started with Airtable Automations article. If you're new to automations, we recommend reviewing that article first to understand the general automation building process.
Preparing to link records with an automation
Below, you’ll learn how to set conditions to update existing records in your base to be linked to other records. We’ll show how to find records across tables and update existing records. The article below is still useful in many cases, but you might also find value in creating record templates that have similar functionality at times.
For this demo, we’ve set up two tables, Projects and Tasks, that are linked directly together using a linked record field.
You can see our table set up below, and can copy this base if you’d like to follow along with the rest of this demo.
For our example workflow, every time we add a new project we’d like to link the same three tasks to that project:
As you can see above our new project, Project D, will also need to be linked to the same set of Regular Tasks as all the previous projects. Now, we could go in and manually link every task, but that is time-consuming and error-prone. Automations to the rescue! The automation we’ll be crafting will add the tasks we specify to a project based on a condition we set. A common pattern for setting up a new automation is to create a checkbox field that can be used as the condition for triggering that automation.
Setting up your base and automation to link records
Add a checkbox field - With the section above in mind, the first thing we will do is create a checkbox on the Projects table that we can use as an easy trigger to kick off this automation.
With our checkbox in place we are up to begin creating our automation. We have three goals this automation will need to accomplish:
Identify the project to be updated (using the checkbox we just made)
Find all the Tasks that need to be linked to this project
Update the project that triggered this automation with the tasks we found in the last step
Choose a trigger - So we will start by creating a new automation and choosing the “When record matches conditions” trigger to take advantage of our new checkbox field. You can add a further condition to make sure our project has both the checkbox checked, and no other Tasks linked.
After testing out our trigger step, you can move on to setting up the two action steps.
Configure the action steps
Find records action - We now need to find all the records on the Tasks table that we’d like to link to this new project record. For our example, we know all the Tasks we’d like to link to have the same word (i.e. “Regular”) in their name field, which we can use to our advantage. We can set up a Find Records action to find all the tasks that have the word “Regular” as part of their {Name} field. Be sure to test this step to ensure that records were found based on our search.
Update records action - Now we can tie everything together in our third automation step. Setting up our final step, using the “Update Record” action, we will update the project record that triggered this automation.
Note that when using the “Update Record” action we always want to make sure we choose the table where the record we are updating is located. In this case, we are updating our triggering project record, which can be found in the Projects table.
We know we have a reference to the project we’d like to update from our triggering step, because that project record triggered this automation to run. So we can choose to use the
Record IDfrom “Step 1: Trigger.”
The “Update Record” action only accepts the Record ID of the single record that will be updated. However, linked records are bidirectional—so when we update a linked record field the other side of that link is updated too. Meaning, that not only are we updating the project record above, but we are also updating each newly linked task record to have a reference to that project record.
Now that we’ve identified which project record to update, we can choose what fields should be updated and the values to use for the update. We’ll be updating our project’s {Tasks} linked record field—so we can choose that field, then input the value of the Task records we previously found with our automation’s “Find Records” action.
When linking multiple records using an automation, make sure to choose to “Make a new list” of “Airtable record IDs”.
Again, test this action to ensure everything is testing successfully and working correctly.
Test and turn on the automation - After conducting our final test, and switching our automation on, we can now see our workflow in action.
Adding links without replacing the ones already there
The "Update record" action writes the value you configure into the field, so whatever you put in a linked record field replaces what was already there. To add a link and keep the existing ones, include the field's current value in the value you write.
In the "Update record" action, click + Choose field and select the linked record field.
Click the blue and white plus button, select the trigger step, and insert that same linked record field. Click the token and choose its record ID property so the token outputs "rec" identifiers rather than record names.
Type a comma after the token.
Click the blue and white plus button again and insert the records you're adding. If they come from a "Find records" step, choose Make a new list of and then Airtable record ID.
This pattern only works when the field already holds at least 1 record. If the field is empty, the value starts with a comma and the action fails validation, so build 2 branches instead:
Click + Add advanced logic or action and choose a conditional group of actions.
Set the condition to the linked record field, choose Length, and set it to is greater than 0. Put the "Update record" action described above inside this group.
Duplicate the group, change its condition to Length equals 0, and in that copy of the action delete the existing-value token and the comma, leaving only the new records.
Test each group against a record that matches its condition, then turn the automation on.
Every record ID you pass has to belong to the table the linked record field points to. If the automation reports that a record ID doesn't exist, check that the IDs you're passing come from that table and not from a lookup of a third table.
An error saying that record IDs must start with "rec" and be separated by commas means the token is passing record names rather than IDs. A linked record token returns the record's name by default, so selecting the field alone isn't enough - click the token and choose its record ID property, or, for a "Find records" step, choose Make a new list of and then Airtable record ID. For what each of those token options does and how to check an existing token without changing it, see Understanding tokens in Airtable automations.
Combining more than one list of records
The 2-branch approach above handles one token that might be empty. If you're writing several lists into the same linked record field—for example, the results of two separate Find records steps—the number of branches doubles with each optional token, so two lists need four branches and three lists need eight. Before you build that out, try to reduce the number of tokens you're combining.
Use one Find records step instead of two. If both searches run against the same table, widen the conditions on a single Find records step so it returns every record you want to link, then insert that one token. With only one token there's no comma to manage and no empty-value case to branch on.
Keep the lists separate only when you have to. Searches against different tables have to stay separate, because every record ID you pass has to belong to the table the linked record field points to. In that case each table has its own linked record field, so write each token into its own field rather than combining them.
If you're assembling values that already live on the record, such as several text or lookup fields, add a formula field that concatenates only the non-empty values and insert that one token instead. The result never starts or ends with a comma and never contains two commas in a row. The Send email action handles recipient lists the same way—for more details, see Airtable automation action: Send email. This approach doesn't work for Find records output, which exists only as an automation token and can't be read by a formula field.
Whichever approach you choose, test it against a record where one of the lists is empty and confirm the link still forms.
Linking to a table the found records point to
Sometimes the records you need to link aren't the ones "Find records" returns. If you search an intermediate table and the field you're updating points to a table further out, writing the found records' IDs fails, because every record ID you pass has to belong to the table the linked record field points to.
For example, a People table links to Episodes, Episodes links to Projects, and you want a person's "Projects" field to fill in from the episodes they're assigned to. A "Find records" step on Episodes returns episode records, but the "Projects" field accepts only project records. Pass the episodes' project link instead of the episodes themselves:
In the "Update record" action, click + Choose field and select the linked record field you're filling in.
Click the blue and white plus button and insert the "Find records" step's output.
Click the token and select Edit token.
Select Field values, then select the link field on the found records that points to the table you want—the "Project" field on the Episodes table, in the example above.
Select Make a new list of, select Airtable record ID, then select Entire list.
Test the action and confirm the link forms.
If the automation reports that a record ID doesn't exist, the token is still returning the found records rather than a field on them. Reopen the token and check that "Field values" is selected.
FAQs
How do I "pull in" data from linked records?
Why aren't my linked records populating automatically after I create a linked record field?
Creating a linked record field only establishes the structure for connections—it doesn't automatically create links between specific records. Records must be connected either manually (by clicking into the field and selecting records) or through an automation that specifies which records should link based on your criteria. If you expected data to appear automatically, you'll need to either manually link the records or configure an automation with a trigger (like "When a record is created") and an "Update record" action that specifies which records should connect based on matching field values.
Why does my automation run (and tests pass) but the linked record field doesn’t populate?
When an automation's "Update record" (or "Create record") action completes without error but the link doesn't appear, it's usually one of these:
The linked table's primary field is a formula. In automations, you can link records using the primary field value for any primary field type except formula. If the table you're linking to has a formula primary field, the link can't be established this way — use the matched record's record ID to link instead, or change the primary field to a non-formula type.
You're passing a name that doesn't exactly match. Linking by primary field value requires an exact match. If you feed "Dog Name" text that doesn't precisely equal the target record's primary field, no link forms. The most reliable approach is a Find records step that matches on a unique value, then an Update record step that links using the record ID returned by Find records (not the raw name).
The trigger fires before the matching value exists. A "when record is created" trigger can run the instant the record appears — before the field you match on is populated — so the link step has nothing to match. For form submissions all fields arrive together (so this is less likely), but for records created in the grid, trigger on "when record matches conditions" (e.g., the match field is not empty) instead.
The fix that resolves most cases: trigger on creation/condition → Find records in the target table matching a unique field → Update record linking via the found record ID.
How do I fill a linked record field when my source is a user field or plain text?
Use the record ID, not the name. A linked record field also accepts text, but only text that exactly matches the primary field of a record in the linked table, including capitalization. A user or Created by field gives you the person's name, which might not match (for example, "Ali Rose" versus "Allison Rose"). When there's no exact match, Airtable doesn't show an error. It creates a new record in the linked table with that text.
To link reliably, look up the record first with a Find records step:
Add a Find records action above the action that writes to the linked record field.
Set Table to the table your linked record field points to, and set Find records based on to Condition.
Add a condition on a field whose values are unique, such as email. For the value, insert your user or Created by token and choose its Email property. The email needs to match the one on the person's Airtable account.
In the Create record or Update record action, click the linked record field, select the Find records step, choose Make a new list of…, then select Airtable record ID.
Test the automation. Check that the field links to the existing record and that no new record appears in the linked table.
If Find records finds nothing, the person isn't in the linked table yet. Add a conditional group with the condition Length of Records equals 0. Inside that group, either create the record yourself or send yourself a notification.
