Using app library and components in Airtable
Plan availability
Enterprise Scale
Permissions
Consult this section for more information about the various user roles and permissions associated with this feature.
Platform(s)
Airtable terminology
  • Managed app - A pre-configured schema that typically consists of a base, interface, and automations meant to be implemented as a holistic, ready-to-use app.
  • Managed component - A pre-configured Airtable building block in Airtable that represents a subset of an app (and can be installed into an existing app). Three types of components are supported: managed fields, managed tables, and custom components (which may contain any combination of tables, automations, and interfaces).
  • Component library - The collection of managed apps and components that have been published at your organization.
  • Development base - A special type of base that is used to publish a managed app or component. Each managed app or component has its own development base.
Understanding managed apps and components
Managed apps and components are reusable configurations of Airtable base structure and functionality (data schema, automations, and interfaces) that you can publish and install from your organization’s library. Managed apps and components typically do not include record data.
Managed apps and components enable:
  • Global standardization with local flexibility - Build (and lock down) the critical elements of any multi-base workflow, while still empowering creators in each base to make the local customizations they need
  • Global process visibility - Standardize taxonomy and table schemas to keep data aligned and enable organization-wide roll-ups and reporting.
  • Management at scale - Publish and apply updates to managed apps and components from one place rather than manually replicating changes across multiple bases.
  • Accelerated building - Empower builders in your organization with ready-to-use components and apps so they can build faster and share best practices – including adding AI elements to large-scale workflows.
What’s the difference between a managed app and a component?
Managed apps are a good fit for repeated or scaled workflows where end users might otherwise have considered duplicating a template base. Typically, managed apps are meant to be holistic and include everything necessary to accomplish an entire replicable workflow or project.
Managed components can provide similar benefits of standardization and maintainability, but may be adopted in existing bases. However, their smaller scope may provide less overall control over the data and functionality in the bases that adopt them.
Why use managed apps or components?
When a managed app or component is added to a child base, its configuration is locked. Managed apps and components can be updated by publishing changes from their development base. After changes have been published, any user with creator permissions in one of the child bases can choose to update that app or component asynchronously.
Similar to the Airtable Sync feature, child bases can be extended with additional tables, fields, interfaces, and/or automations. These additions will only be present in that child base, not in any others, because any schema that was included in the original managed app or component cannot be modified except at the global level (unless the component is converted to be unmanaged).
Managed apps should be used to manage processes that require a standardized schema between multiple departments or business units, but while still optionally allowing a degree of flexibility for each. The standardized schema is what allows the data to be aggregated into reporting for global teams + leadership, which is a key value prop of managed apps.
For example:
  • A standardized OKR workflow to be adopted by multiple functions
  • A standardized store openings process to be adopted by multiple brands in a retail enterprise
  • A standardized production workflow to be adopted by many media brands or studios
  • A standardized roadmap to be adopted by many product divisions
  • A standardized project management app to be adopted by any employee managing a project
When should I use a single app versus a managed app and vice versa?
While using the app library offers numerous benefits, it's important to understand when it's the most appropriate solution. Here are some guidelines:
Use a single app when:
  • There's minimal need for ongoing customization
  • There's a single, central owner of the process
  • There's no requirement for data separation
  • The app's structure isn't overly complex
Opt for managed apps through App Library when:
  • Individual teams require significant customization
  • There's a distributed ownership model for the process
  • Compliance or sensitivity issues necessitate data siloing
  • The app's structure is complex and would become unwieldy in a single-app format
Understanding managed app and component user roles
Persona
Permission level
Role in the organization
Resources in this article to learn more
Admins
Admin
Can configure global organization settings for the App Library feature and also manage apps and components from the Admin Panel.
Builders
Admin, Owner, or Creator
The people who build and update your organization’s managed apps and components. These users will create development bases in the builder hub to manage apps and components over time.
Creators
Workspace Owner or Creator
The people who add managed apps and components into one or more of their department’s bases. This might be a departmental manager or someone else who has permissions in that department’s workspace or workspaces.
End users
Editor, Commentor, or Read-only
The people who interact with the managed app or component in a base or interface when they are working on a project or task. These individuals can interact with the app or component but are not able to change their configuration.
Building managed apps or components
Creating a managed app
  1. Navigate to the Builder hub. You can also access Builder hub from the account menu or in the lower-left-hand corner of the Airtable homepage.
  2. Under the “Library” section on the left side of the page click the Managed apps option.
  3. Click the + Create a managed app button.
  4. Give the app a “Name” and helpful “Description” so that end users will know what the app’s purpose is.
  5. If your organization contains multiple org units, choose the org unit where you want this managed app to appear.
  6. Toggle the “Create from existing base” option on and then choose an existing base from the dropdown menu if you prefer to use an existing base’s configuration as a template for the app that you are building.
  7. Click the Create button.
  8. This will bring you to a new development base. Typically, a managed app will contain multiple tables, automations, and interfaces, but the complexity can vary. Configure the development base in whatever way your use case requires.
  9. Once you’ve configured the development base to your liking, click the Publish button near the top of the page.
  10. Before publishing, you’ll have the opportunity to:
    • Edit the name of the app.
    • Edit the description of the app that appears when browsing the app library.
    • Add a “Long description” of the app that appears when previewing a particular app before adding it.
    • Set the audience, i.e. who can use the app. This is covered more extensively below.
  11. Lastly, click Publish. The chosen audience is now able to use the managed app.
Creating a managed component
  2. Under the “Library” section on the left side of the page click the Components option.
  3. Click the + Create a component button.
  4. Give the component a “Name” and helpful “Description” so that end users will know what the component’s purpose is.
  5. If your enterprise contains multiple org units, choose the org unit where you want this component to appear.
  6. Toggle the “Create from existing base” option on and then choose an existing base from the dropdown menu if you prefer to use an existing base’s configuration as a template for the component that you are building.
  8. This will bring you to a new development base. Configure the development base in whatever way your use case requires. This could be as simple as a single table containing a single field and as complex as a base with many tables, automations, and interfaces.
  10. Next, choose a component type and click Next.
    • If you choose to create a “Table” component, then you’ll choose one or more tables to include as the managed component. You’ll then need to choose whether to automatically include any linked tables that have dependencies via linked record fields.
    • If you choose to create a “Field” component, then you’ll first choose a table and then choose one or more fields within that table to include as the managed component.
    • If you choose to create a “Custom” component, then you’ll be able to check boxes to choose a custom subset of the development base you’d like to include in the published component. Note: When selecting an item, items it depends on will automatically be selected as well. For example, when selecting a linked record field, the table it references and the reciprocal linked record field are automatically selected.
  11. Before publishing, you’ll have the opportunity to:
    • Edit the name of the component.
    • Edit the description of the component that appears when browsing the component library.
    • Add a “Long description” of the component that appears when previewing a particular component before adding it.
    • Set the audience, i.e. who can use the component. This is covered more extensively below.
  12. Lastly, click Publish. The chosen audience is now able to use the managed component
Using managed apps or components
Adding a managed app
Managed apps cannot be appended to existing bases. Instead, they must be added from the home screen as a new base. From the home screen:
  1. Click the Templates & Apps option above the + Create button near the lower left side of the screen. Alternatively, click the + Create button and select Start with a managed app in the window that appears.
  2. Under the “Get started” section, click the Apps at {Your organization} option.
  3. Browse through the apps managed by your organization and click the one needed for your use case.
  4. This will lead to a screen where you can learn more about the app such as which tables, automations, and interfaces it contains as well as who published the app, when it was last updated, and how many times it has been used at your organization.
  5. When you are ready, click Add this app.
  6. Then choose which workspace to add the app and, optionally, the name and appearance of the app.
  7. Finally, click Create.
Adding a managed component
  1. From an existing base, click the Tools option from the top right corner of the base. You can create a new base if you’d rather build the base from scratch utilizing one or more components as a starting point.
  2. Next, click the Library option.
  3. From here there are several options to find a component to add. You can search for components by name or filter to show All components, Tables, or Fields.
  4. Once you find the component that you want to add to your base, click it. From here, you may preview what is included in the component and review a longer description.
  5. To proceed, click Add component. You may then be prompted for any required options. For example, when adding a field component, you must choose which table to add it to.
Updating managed apps or components
There are two high-level steps to updating a managed app or component:
  1. Development base changes - In the Builder Hub, users with creator permissions in a development base can update the managed app or component and then click Publish to allow other users across their org to update their individual managed app or component.
  2. Manual updates on individual bases - In a base created as a managed app or a base with an added component, a user listed as part of the audience of that managed app or component who also has creator permissions can update the base to receive changes made in the development base. This can be done via many surfaces, but we recommend the following steps:
    1. Navigate to the base you want to update and click the Tools ⌄ option on the right side of the screen.
    2. From the menu that appears, click the Library option. Next, click the Added to this base section. This will reveal any managed components or apps added to the base. You can also access this screen by clicking the “book” icon in the upper-right hand corner of a base – if there’s an update available, it will have a small circle on it.
    3. Find the app or component you want to update and click the … icon on the right side. You should see an “Update available” message. This will reveal a menu of options. Click the Update app or Update component menu item. This will vary based on the type you are updating.
    4. A menu will appear to show you a brief overview of the changes this will make to your base. You can optionally choose to toggle the “Take a base snapshot before updating” to take a snapshot in case the changes made by the update are unexpected.
    5. Click Update when you are ready. Certain updates may take longer to process. Once the update is complete, click the Done button to return to the base.
Converting a managed app or component to be unmanaged
Warning
When an app or component becomes unmanaged, it will no longer be able to receive new updates published from the development base. This cannot be undone.
There are times when creators across your organization may want to use a component or managed app as a jumping-off point to create a more custom solution. In these cases, you may want to convert the component or app to be unmanaged so the field, table, automation, and interface configurations become editable in the base rather than only in the development base. In these cases:
  1. Navigate to the base where the component or managed app has been added.
  2. Click the Tools ⌄ option on the right side of the screen and from the menu that appears, click the Library option. Next, click the Added to this base section. This will reveal any managed components or apps added to the base.
  3. Find the app or component you want to update and click the … icon on the right side. This will reveal a menu of options. Click the Convert to unmanaged menu item.
  4. A dialog will appear with a warning about the impact of this operation and that it is not undoable.
  5. Click Convert to unmanaged when you are ready.
Deleting a managed component from a base
There are times when you may want to delete a component from a base rather than converting it to be unmanaged. In these cases, you can either delete the individual table or field component (which can be tedious to find) or use the following recommended method:
  1. Navigate to the base containing the component that you want to delete and click the Tools ⌄ option on the right side of the screen
  3. Find the component you want to delete and click the … icon on the right side. Then, click the Delete component menu item. A warning message will appear. You’ll need to click Delete to finish the deletion process.
You can re-add a component at a later time if needed, but keep in mind that the component may have changed if any updates have been published in the development base for that component.
Pushing updates to bases
Pushing updates to managed components and applications carries additional risk because the exact changes to be applied to each child base cannot be reviewed. Please exercise caution when using this feature.
After successfully publishing an update to a managed app or component, you can push those updates to bases that have installed them. This can be done from the Builder Hub or admin panel:
  1. Click the Push updates button for the managed app or component you've updated.
  2. You'll see a list of all bases that have installed this managed app or component. Review the list to understand which bases will be affected.
  3. Select the checkboxes next to the bases you want to push the update to. You can select individual bases or use the Select all option if available.
  4. Click the Push update button. A confirmation modal will appear.
  5. (Optional) If a base has unmanaged dependencies that could cause the update process to fail, you can check the Force push regardless of dependency conflicts option to push the update anyway.
    Changes to column configurations, deletions, and changes that affect substituted columns may result in child data becoming unmanaged or destroyed. While a full app snapshot is taken prior to updating any installed component or application, there is no other way to roll back changes or restore lost data after updating.
  6. When you are ready, click Confirm update or Force push update.
  7. The system will begin pushing updates to the selected bases. Depending on the number of bases and the complexity of the update, this process may take some time.
  8. If any bases fail to update due to unmanaged dependencies, you can retry the push with the Force push regardless of dependency conflicts option selected in step 5.
Setting a managed app or component’s audience
  • Any user who is a claimed member of an org unit can create a managed app or component in that org unit.
  • Once the app or component has been created, the creator can add any user as a collaborator to the development base.
  • Any user who is a creator in a development base can publish the package to one of the following audiences:
    • Collaborators in the development base - Development base collaborators with “Creator” permissions. Collaborators with “Editor”, “Commenter”, or “Read only” permissions will not be able to install the app or component.
    • Specific user groups - One or more user groups in the managed app or component’s individual org unit and development base collaborators
    • Everyone at {your organization} - (Only Enterprise Hub organizations) All claimed users in the managed app or component’s individual org unit and development base collaborators
    • Everyone at {your enterprise account} – All claimed users in the managed app or components overall enterprise account and development base collaborators
  • From the library, users can see, install, and update any managed app or component if the following are true:
    • The user is part of the package’s audience.
      • If you are seeing an “Insufficient permissions to install updates” notification when attempting to update a managed app or component, this means that you do not have the proper audience permissions in builder hub. You should contact the user listed under the “Added by” field who manages that app or component and ask them to consider updating the audience settings to include more users.
    • The user has creator permission in the installation base.
    • The installation base belongs to the managed app/component’s org unit
There is no support for transferring managed apps or components to a different org unit or enterprise account.
Managing apps and components in the builder hub
Managing apps in the builder hub
  1. Navigate to the Managed apps section of builder hub.
  2. From here you can:
    • Search for a development base (app) by name
    • Filter to show development bases (apps) Owned by anyone or Owned by me
    • Create a new managed app / development base by clicking + Create a managed app
  3. In the list of development bases you see, you can:
    • View the app name
    • See when it was last updated
    • View the owner of the development base
    • View the number of collaborators who have access to the development base (When available, click the number of collaborators to view and adjust share settings)
    • View the audience that has access to see the app in the library
    • See how many times the app has been added since it was first published
    • Click the Edit button to make changes in the development base
    • Click the … menu to view details about the development base, edit library listing details, or delete the development base
Viewing an individual development base’s overview, contents, or listing
  2. Click on the name of a development base.
  3. This will bring you to a page displaying more details about the development base.
  4. Click Overview, Contents, or Listing.
    • The Overview tab displays:
      • The app type, current owner, when the development base was created, when the development base was last updated, the creator of the development base, which user made the last update to the development base, the name of (and a link to) the development base, and the org unit (Enterprise Hub only) the development base belongs to.
      • You will also see a list showing any apps/bases currently leveraging this managed app, who added it from the app library, when it was last updated, what the status of the managed app is, and an overflow menu with the additional option to go to the base (permission-dependent). You can search for a specific app / base by name using the search bar or filter the list of manages apps by clicking the dropdown and changing the value to All, Up to date, or Updates available.
    • The Contents tab displays a high-level schema of what the managed app contains (Tables, Fields, Views, Automations (Triggers and actions), Interfaces, etc. You can also search for certain items by the name, which is helpful in more complex apps.
    • The Listing tab displays the information that other users will see when they are browsing the organization’s app library. Here you can adjust the Name, Description, Long Description, and / or Audience for the managed app.
Managing components in the builder hub
  1. Navigate to the Components section of builder hub.
    • Filter to show development bases by component type (All, Field, Table, or Custom) or development bases Owned by anyone or Owned by me
    • Create a new component / development base by clicking + Create a component
    • View the component name
    • See the type of component contained within each development base
    • View the audience that has access to see the component in the library
    • See how many times the component has been added since it was first published
Viewing an individual component’s overview, contents, or listing
  2. Click on the name of a component.
  3. This will bring you to a page displaying more details about the component.
      • The component type, current owner, when the development base was created, when the development base was last updated, the creator of the development base, which user made the last update to the development base, the name of (and a link to) the development base, and the org unit (Enterprise Hub only) the development base belongs to.
      • You will also see a list showing any apps currently leveraging this component, who added it from the library, when it was last updated, what the status of the managed component is, and an overflow menu with the additional option to go to the base (permission-dependent). You can search for a specific app / base by name using the search bar or filter the list of manages apps by clicking the dropdown and changing the value to All, Up to date, or Updates available.
Managing apps and components in the admin panel
Customizing managed apps and components
Certain aspects of managed apps and components can be customized in a child app without having to convert the child app to be “unmanaged.” This allows child app creators to make customizations while still being able to accept any updates made from the managed app/component’s development base. The following product surfaces/features within a managed app/component can be customized in child apps:
  • Automations
    • The ON/OFF state of automations
    • Credentials for external accounts (e.g. JIRA, Salesforce, Slack) used in automations
    • Recipients of notifications (e.g. email addresses, Slack channels) sent from automations
  • Standalone forms
    • Title and description
    • Logo and cover image
    • Form submission configuration (redirect URL, success message, “submit another response” message, email notification settings and “Accepting submissions?” status)
    • The order of groups in a form (whether those groups are managed or not)
  • Interface pages using form layouts
    • Form submission configuration (redirect URL, success message, ‘submit another response’ message, email notification settings and “Accepting submissions?” status)
  • Interface pages using list, gallery, calendar, kanban, timeline, record review, or grid visualization layouts
    • Page-level filters (which control the underlying data available to the page)
    • User filters (tabs/dropdowns)
    • Toggling on/off user actions (sort/search/filter/group/row height)
  • Interface pages using the record review layout
    • Sort configuration
    • "Group by" configuration
    • "Color by" configuration
    • List item fields (image, title, details)
  • Interface pages using overview layouts
  • List elements in interfaces
    • “Group by” configuration
    • Visibility, order, names, and default widths of fields shown in the list
  • Record detail layouts in interfaces
    • The order of groups in a record detail layout (whether those groups are managed or not)
  • Choosing sync sources
    • Managed app and component builders can select relevant data for synced tables in their specific installation.
  • Field Format - Field format settings that can be modified in a child app.
    • Currency - Symbol, Thousands separator, Show thousands separator
    • Number - Thousands separator, Show thousands separator
    • Date - Date format
    • Duration - Duration format
    • Rating - Rating Style
In addition to the customizations listed above, builders are also able to add to most aspects of a child app without needing to convert the app to “unmanaged” in order to maintain their child app’s ability to receive updates from the managed app/component. Creators can freely add the following to a child app of a managed app/component:
Airtable surfaces that can be enriched/added to child apps without converting them to be unmanaged
  • New tables
  • New fields in existing (managed) tables
  • New views and view sections
  • New automations and automation sections
  • New interfaces
  • New standalone forms
  • New interface pages in existing (managed) interfaces
  • New groups in existing (managed) form and record detail layouts in interfaces
  • New groups in existing (managed) standalone forms
It’s important to note that there can be conflicts between managed app updates and child app customizations. In general, Airtable attempts to reconcile both the managed app update and any customizations made in the child base, however, the child app customizations will override the update in case of a direct conflict. Here's an example:
General example of conflicts between managed app updates and child app customizations
  1. A managed app is published with a given interface page with a list visualization that shows fields (in order): A, B, C
  2. The child app is installed from this managed app.
  3. A user with creator permissions in the child app reorders the fields to: A, C, B
  4. A builder of the managed app adds field D, such that the fields in the managed app are: A, B, C, D and publishes this change as an update.
  5. A creator in the child app accepts the update.
  6. The fields in the child app are now: A, C, B, D
  7. In this case, Airtable attempts to apply the update by adding field D while preserving the child app’s field order customization. In this way, the A, C, B portion of the field order is retained.
Customizing sources of synced tables in managed apps or components
You can customize the source of data for synced tables in a managed app or component installation so that each installation receives only the data that is relevant to it. This is in contrast to all of the data in the synced table present in the managed app/component, which may not be relevant to that app/component installation. For example, you could use this functionality to only sync in the projects and tasks relevant to one division or team using a specific managed appinstallation.
You can customize the source of data for a synced table at two points in time: when creating a new managed app installation, or any time after the installation has been created. We’ll look at an example of each in turn below.
For the example below, let’s imagine we work at a sportswear company called Zelos, and we’re using a Managed App to track goals across the various departments within the company. The managed app defines a standardized process for tracking goals using Objectives and Key Results (OKRs), and then each department (Marketing, Legal, Product, etc.) has a separate managed app installation.
Example scenario:
  • The development base of our managed app already includes a synced table that syncs in the “All initiatives” view of the “Initiatives” table from the company strategy base, which means this view will be synced into every installation of the managed app installation by default.
  • We have an Airtable app, separate from the managed app, that contains information about company strategy. This includes a strategic “Initiatives” table.
  • The “Initiatives” table includes several views, each filtered to show the specific initiatives that are relevant to a particular organization like “Marketing” or “Finance".”
  • Importantly, each of these views allows its data to be synced to other bases. You’ll leverage these different slices of the table data based on the view to customize the sync source in your managed app.
When customizing the view used by a synced table in a managed app installation, you must choose a view that has all of the same fields visible as the default syncable view leveraged in the managed app or component. If you attempt to choose a view with fewer visible fields, you will see the “This view is missing required fields. Please select a different view” error message.
Customizing sources of synced tables when installing a managed app
  1. From the Airtable home screen, click on the + Create button in the bottom-left, then click on Start with a managed app.
  2. Select a managed app from the app library, then click on Add this app.
  3. In the “Customize appearance” dialog you can choose the workspace to install the app and a name, color and icon for the managed app installation. Then, click Next.
  4. In the “Data” section, you can select a different source view for every synced table in the managed app. Click the dropdown menu next to “View to sync” to select a different view.
  5. Click Create to create the managed app installation. The synced table in the managed app installation will reflect only the data contained in the view(s) that you selected during the installation process.
Customizing sources of synced tables after a managed app installation has been created
  1. Open the managed app installation
  2. Click on the name of the base in the top-left corner, then scroll down to the “Managed by your org” section. Click on the … icon, then click on Edit settings.
  3. In the “Data” section that appears, you can select a different source view for every synced table in the managed app. Click the dropdown menu next to “View to sync” to select a different view.
  4. Click Save. The synced table will update to use the new view you selected in the data section.
Using substitution to reference existing tables or fields
When using components in particular, you may find yourself in a situation where you would like to add a component to your base and have it utilize existing tables and/or fields. The default behavior of a component is that it is a self-contained unit, meaning it includes all of its necessary dependencies. For example, if you publish a “field component” with a formula field, it will include the other fields that the formula relies on. If you publish a “custom component” with an automation, it will include any tables and fields that the automation relies on. When adding the component to a base, the default behavior is that all of these dependencies will be added to the base, as well. But, what if you want a formula field component to reference a field you already have in your base or have the automation reference an existing table in your base? This is where you can use substitution to reference existing tables or fields in your base.
Follow these general setup steps to map substitutions:
  1. When adding a component to your base, if substitution is available, you will be presented with a screen that says:
    • “What fields in your base should we use?” for a component that includes fields only
    • “What tables in your base should we use?” for a component that includes one or more tables
  2. At this point, the screen will show which existing tables/fields (if any) are going to be used in place of the managed tables/fields included with the component, and how many tables/fields will be created in your base.
  3. Make any adjustments as desired. You can click the “X tables/fields will be created” to replace those with existing tables/fields.
    • Airtable will attempt to automatically match existing fields/tables that you may want to use in place of managed fields/tables. However, you can always click on “X fields will be created” (or “N tables will be created”) to see the managed fields/tables which will be created and adjust any of these to be replaced with a valid existing field or table. Likewise, if there is a managed field/able that is mapped to an existing field/table, but you do not want to use that existing field/table, you can change or clear the existing field/table.
  4. Once your selections are set, complete the setup process to add the component to your base.
If you want to change any selections after adding the component to your base, open the Library via the Tools menu, go to the “Added to this base” tab, open the component’s menu, and click “Edit settings”. Be careful when changing substitutions. If a managed table/field was previously not mapped to any existing table/field and you now choose to replace it with an existing table/field, the managed table/field will be deleted from your base because the existing table/field will be used instead.
Example 1: Add a formula component to an existing base, but reference existing fields
Imagine that you or someone in your company has published a component containing a “Duration” formula. This component includes 3 fields: ”Start,” “End,” and “Duration.” The “Duration” formula field is defined as follows: DATETIME_DIFF({End}, {Start}, 'days') .
In another base that you use for tracking sprint tasks, you want to use this Duration formula component. If you add the “Duration formula” component to this base, the default behavior is that it will add 3 new fields – “Start”, “End”, and “Duration”. However, suppose you already have a “Due date” field in the “Sprint tasks” table. This field is used in several automations and interface pages, so you want to keep using it instead of getting a new “End” date field and having to switch to that. To achieve this, you can choose to use the existing “Due date” field by mapping it under the “Existing field” dropdown when you add the component to your base. Now, the “Due date” field will be used in place of the managed “End” date field.
Assuming you choose to replace the managed “End” date field with your existing “Due” date field, you will end up with only 2 new fields in your base – ”Start” and “Duration” – rather than 3 new fields. Your existing “Due” date field remains unmanaged. Notice how the “Duration” formula field in your base references your existing “Due” date field, rather than a new “End” date field:
Example 2: Add a Key Results, Projects, and Tasks component but utilize an existing “Tasks” table
Imagine that you or someone in your company has published a component containing 3 linked tables – ”Key Results”, “Projects”, and “Tasks”. Each Key Result is linked to one or more projects, and each project is linked to many tasks.
In another base that you use for tracking sprint tasks, you want to use this component. If you add the component to this base, the default behavior is that it will add 3 new tables – “Key Results”, “Projects”, and “Tasks”.
But suppose you already have a “Sprint tasks” table in this base. This table is used in several automations and interface pages, so you want to keep using it instead of getting a new “Tasks” table and having to switch to that.
To achieve this, under the “Existing table” section you can choose to map the existing “Sprint tasks” table in place of the managed “Tasks” table when adding the component. Click the Next button and choose which existing fields in your “Sprint tasks” table correspond to the fields in the managed “Tasks” table. In this case, we already have fields for the task name, notes, and due date. We can see that one field will be created – the linked record to the “Projects” table.
Assuming you choose to replace the managed “Tasks” table with your existing “Sprint tasks” table, you will end up with only 2 new tables in your base, ”Key Results” and “Projects,” rather than 3 new tables. For instance, the “Tasks” linked record field in the managed “Projects” table is linked to your existing “Sprint tasks” table, rather than a new “Tasks” table. Additionally, the existing “Sprint tasks” table will remain unmanaged after adding the managed component.
Example 3: Add an automation but utilize into existing table
Imagine that you or someone in your company has published a component containing a “Due date reminder” automation. This automation runs when a record in “Table 1” has a “Due” date field equal to tomorrow’s date, and sends an email to the user in the “User” field.
In another base that you use for tracking sprint tasks, you want to use this component. If you add the component to this base, the default behavior is that it will add the automation and a new table, “Table 1”, which the automation will reference.
But suppose you already have a “Sprint tasks” table in this base with a “Due” date field, and you want the automation to run based on records in this table, not a new table.
To achieve this, you can choose to use the existing “Sprint tasks” table in place of the managed “Table 1” table when adding the component, as shown:
Then, hit the Next button and choose which existing fields in your “Sprint tasks” table correspond to the fields in the managed “Tasks” table. In this case, we have fields that we want to use in place of the managed “Title”, “Due”, and ”User” fields.
Assuming you choose to replace the managed “Table 1” table with your existing “Sprint tasks” table as shown above, you will end up with a “Due date reminder” automation that references your existing “Sprint tasks” table. Your existing “Sprint tasks” table remains unmanaged. Notice how the email is addressed to the email address of the existing “Assignee” field, rather than a managed “User” field, and how the body of the email references the existing “Name” field rather than a managed “Title” field:
Managed app and component limitations
  • Features that are not supported in components are not available in development bases.
    • This includes:
    • Record Templates
    • Gantt View
    • Extensions
    • Third-party sync integrations
    • Multi-source sync
    • Public API
    • Omni
  • A child app is also subject to the per-base limit of 50 interfaces. If an update would take a child app over 50 interfaces, the push fails with the error "Performing this action would exceed the limit for number of interfaces in this base." The 50-interface limit can't be raised on request. To bring an app back under the limit:
    • Make the change in the source development base, not in the child app. Deletions made in a child app are overwritten the next time an update is pushed.
    • Move form-only interfaces to standalone forms. Standalone forms don't count toward the 50-interface limit, so this is usually the quickest way to free up room.
    • Consolidate related interface pages into a single interface, and delete interfaces that are unused or were never published.
  • Managed apps and components are owned by the enterprise organization’s account. This means that:
    • Components cannot be added in a base outside of the enterprise organization.
    • If a base with a component/managed app added is moved out of the enterprise, it will not be able to receive updates.
    • Non-enterprise members can be added as collaborators in a development base. In this case, they will be able to edit and publish this component or managed app, but it can still only be added in bases in the enterprise organization.
  • Links in a managed app still point to the development base - When you create a child app, Airtable copies any URL typed into the app's structure exactly as written. These URLs aren't updated and there's no warning, so they keep pointing at the development base. Check for hard-coded URLs in:
    • Prefilled form URLs, for example in a button field formula or an interface button. A prefilled URL contains the development base's form share ID, so submissions go to the development base, not the child app.
    • Interface buttons that open a static URL.
    • Field, view, and form descriptions, field default values, and form redirect URLs.
    • Automation steps that include a URL.
  • Records and share links aren't copied. URLs saved in cell values don't carry over, and forms and views in a child app start unshared. Avoid hard-coded links where you can:
    • To link between interface pages, set the button to open a page in the app instead of pasting its URL. Airtable updates these links in each child app.
    • For links that have to be different in each child app, like prefilled form URLs, store the URL in a record (for example, in a Settings table) and build the button field's formula from that field. Records aren't copied, so each child app creator enters their own URL once, without editing managed fields.
    • Fixing remaining links in a child app:
      1. In the child app, create a share link for the form or view the URL should open.
      2. Rebuild any prefilled URL on the new share link, keeping the same field parameters. For details, see Prefilling a form via encoded URL.
      3. Replace the old URL wherever it appears. If a field, view, or interface is locked, ask the app's publisher to change it in the development base. Converting the item to unmanaged also works, but it can't be undone and the item stops getting updates.
  • What child app creators can’t change - Elements that come from the managed app carry a “Managed by your org” tag. Apart from the customizations listed above, these managed elements are locked. In a child app, creators can’t:
    • Delete a managed table, field, interface, interface page, or automation.
    • Change the name or type of a managed field.
    • Change the structure of a managed interface page, other than the customizable properties listed above.
    • Changes also flow in one direction only. Creators can’t push a change from a child app back to the development base, which is always the source of truth.
  • Working around a locked element - Creators don’t need to disconnect from the managed app to work around a locked element. They can hide a managed interface page from navigation, unpublish it, or turn off a managed automation. They can also add their own tables, fields, views, pages, and automations alongside the managed ones.
    • If someone needs a different version of a managed page, they can duplicate it and hide the original. The duplicate is unmanaged and fully editable, but it won’t receive future updates.
    • To delete managed elements outright, convert the child app to unmanaged. This permanently stops the app from receiving updates. For steps, see “Converting a managed app or component to be unmanaged.”
Additional tips
  • Development bases are not shown on the home screen. Instead, they are accessed through the Builder hub.
  • Development bases cannot be moved, duplicated, or deleted.
  • Appearance changes are not allowed in development bases. They will appear gray in color with the word “Development” next to the name of the base.
  • Installers of managed apps are not able to pick which shared view on a given source table will be synced into their app. For use cases where you want multiple different managed apps to use different views from the sync source, we recommend either a) syncing the entire dataset into each managed app and then filtering the data down to the relevant subset, or b) manually adding unmanaged synced tables into each of these apps after creation.
FAQs
Can child apps or components be disconnected from their managed app/component “parent”? If so, can disconnection be prevented?
Yes, (instances of) managed apps/components can be disconnected from the source/parent. Consult the information in the accordion titled “Converting a managed app or component to be unmanaged” in this section to accomplish this. Keep in mind that doing so disconnects the entire app or all of the elements that a component is composed of.
There is currently no way for the author of a managed app/component to prevent it from being disconnected once used.
Can I customize individual parts of a managed app or component?
If the app or component isn't locked by your org, then creators can customize the various pieces in the app or component to fit their needs. However, if the change is locked behind a “Managed by your org” tag, then you'll need to duplicate the piece of the managed component or app.
In order to customize a part from a managed app/component without disconnecting it entirely, we recommend that creators duplicate the piece that needs to be customized. The duplicated piece will not be managed and can be freely edited but will not receive updates in the future. The original managed piece can then be hidden/unpublished/turned off as needed.
How can we report on the data collected by managed apps?
Initially, we recommend that users create a multi-source sync that includes data from the various instances (sources) of their apps. While this can leverage shared schema across apps, it is a relatively laborious stopgap and can only aggregate from up to 20 bases.
Do managed apps & components come with data?
Most of the time, no. Managed apps & components are primarily about reusing schema & configuration rather than reusing data. However, managed apps and components can include tables that sync data from other Airtable bases or published data sets. See the Data sets and verifying data in Airtable article for more information on publishing data for others in your organization to use.
When should I publish a managed table or select field vs. a data set?
Managed tables, managed select fields, and data sets all represent different ways of reusing data or data structure across multiple bases:
  • Use managed tables if you are trying to reuse a table’s structure (e.g. the fields that should be tracked in Projects)
  • Use a managed select field if you are trying to reuse a flat list of options (e.g. a list of project statuses)
  • Use a data set if you are trying to reuse record data (e.g. the actual set of projects)
When should I use managed apps vs. a sync ecosystem vs. a single base with multiple interfaces?
In general, we think most deployments should default to being a single base with multiple interfaces. This should simplify the building and maintenance burden, which should lead to more robust apps over time
However, there are cases when you might want to break things out to multiple bases:
  • Managed apps or a sync ecosystem
    • If you want to enable teams to customize their own workflows without handling centralized change management.
    • If you have compliance or political constraints that mean you can’t have the same data for multiple teams/personas in a single base.
  • Managed apps
    • If you want to facilitate new teams getting their own connected apps spun up quickly without guidance.
  • Sync ecosystem
    • If you can’t identify a single, committed builder to own a base and want to defray the ownership costs to multiple teams working in their own bases.
    • If you want to empower more organic building and rebuilding of workflows than would be possible with a single large base.
What filtering options in managed apps and components aren't supported?
Because managed apps/components do not contain data and may be used in different contexts than they were created in, the following are not supported:
  • Filters and record conditions (e.g. in views, automations, or interfaces) that reference specific linked records, as they may not exist in the base where the managed app/component is used.
  • Filters and record conditions (e.g. in views, automations, or interfaces) that reference specific users/collaborators, as they may not have access to the base where the managed app/component is used.
As new features are added to Airtable, they may not immediately be supported within managed apps/components.
Can I publish a managed app or component from an existing base?
Yes, use the “Create from existing base” option in the “Advanced” section when creating a new component. When this setting is enabled, we will create the development base for your new managed app or component using the selected base as a starting point. However, any features that are not currently supported in managed apps & components (see above) will not be copied over to the development base.
Can I publish a managed app or component to my entire organization on Enterprise hub?
Publishing across an Enterprise hub is supported, and managed apps or components can be used in other organizational units.
As an external collaborator, what permissions do I have?
External users (i.e. users who do not belong to your organization) may be added as collaborators to the development base of a managed app/component, just like any other base.
All collaborators with creator permissions (including external users) on the development base will be able to edit and publish a managed app/component. However, only members of the enterprise organization may change the Audience of the app/component.
You are only allowed to create managed apps/components in the org unit(s) you belong to. The only way to collaborate on a managed app/component in an org unit you are not a member of is to ask a member of that org unit to create the managed app/component and invite you as a collaborator on the development base.
Who can create managed apps or components?
Anyone with a non-restricted license at your enterprise organization and who is not otherwise restricted by settings configured in the admin panel.
Who can “install” managed apps or components?
Users with workspace or base Creator permissions can “install” a managed app or component. Base editors and below can edit data in a managed app or component but not change the underlying structure (i.e. field, automation, interface configurations and more).
Can structural changes to an installed app or component (ex. field name change, additional select options, etc.) be reflected back in the managed app or component?
No, the managed app or component is the source of truth. Any changes to the configuration of the app/component must be made within builder hub in order to have those changes reflected in other connected apps/components.
I want to substitute a table/field but I don’t see the option to replace any tables/fields when adding a component to my base, what might be the issue?
Existing components that were created before the substitution feature was released (May 2025) may not give the option to replace managed tables/fields with existing tables/fields. Try having someone who manages your organization’s app library publish a new version of the component. In most cases this should remedy the issue.
When attempting to make a substitution I want to use an existing table/field, but it isn’t shown as an option. Why is that table/field missing?
Not every existing table or field in a base can be used in place of a managed table/field – certain requirements must be met:
  • When substituting a managed field, you can only choose a field that has a matching type.
  • When substituting managed tables, the primary field type of the existing table must match that of the managed table.
Let’s illustrate why this requirement exists. Suppose you have published a component that includes a date field and a formula which uses a date function on that date field. If you were allowed to replace the date field with an existing number field when adding the component to a base, the formula will be broken because it will attempt to call a date function on a number field.
Note that you are allowed to replace a field of a given type with a formula that produces the same type. For example, you can replace a managed number field with a formula that produces a number.
I want to delete a table/field, but it says it is “being used as a dependency for a managed component” and can’t be deleted. What should I do?
You cannot delete a table/field that is being used in place of a managed table/field because this may break other parts of the component. If you want to delete the table/field, then the best option in most cases is to stop using this table/field in place of the managed table/field. To do this, open the Library via the Tools menu, go to the “Added to this base” tab, open the component’s menu, and click “Edit settings”. Find the table/field you want to delete and clear it. This will mean that this existing table/field will no longer be used by the component, and instead, the component will create its own managed table/field. Click the Save button. Now that the table/field is no longer used by the component, you can delete it.
The table/field can also be deleted if the component that is using it is deleted from the base or converted to unmanaged. However, these actions cannot be undone, so be very careful if doing one of these actions.
Can you customize the source of synced tables in managed components as well as managed apps?
Yes, when customizing sync sources, all of the functionality applies to managed components in the same way as managed apps.
Is there a way to customize the source of synced tables without creating multiple Views?
No, the feature relies on using different views (with sync enabled) to customize the data being synced into managed app installations.
Do synced tables remain “managed” by the managed app after I customize the view used to source data?
Yes. The synced tables remain managed and the configuration can be updated through future updates to the managed app.
Can I select views that have fewer visible fields than the default view used by the synced table?
No. When customizing the view used by a synced table in a managed app installation, you must choose a view that has all of the same fields visible as the default syncable view leveraged in the managed app or component. If you attempt to choose a view with fewer visible fields, you will see the “This view is missing required fields. Please select a different view” error message.
Can I select views of a different synced table instead?
No, the managed app sync customization functionality relies on selecting different views of the same synced table so that the synced table can remain ‘managed’ and receive future updates to its configuration through the managed app.
What happens when a new synced table is added in the development base of a managed app/component and then published in an update?
When an app that includes a managed app installation accepts the update, the builder of the app can choose to customize the view used by the new synced table in the same way that they can while first installing the managed app.
Can I call managed app development bases via the Airtable API?
API calls are not supported for Managed App development bases. Calls to a development base will result in a 403 permissions error. However, API calls can still be made to bases where a managed app or component has been installed.
Is there a limit to the number of times that a development base (or component) can be used to create a managed app (or component)?
No, there is no limit for the number of times a development base can be used to create a managed app or component.
What happens when I change field types in a Managed App development base?
When you change the field type in a Managed App development base and publish that change to the App Library as an update, the data stored in that field in bases that are installations of that Managed App can be affected when the update is applied.
The consequences depend on the field types you are changing from and to.
Airtable will attempt to convert the existing data to the new field type, which may or may not match your expectations. In some cases, conversion may not be possible and data will be lost entirely. This is the same behavior as when you change a field type in a normal Airtable base, but you do not have the ability to undo these changes when a Managed App update is applied to a Managed App installation.
We recommend 2 best practices for making field type changes in a managed app:
  • Test the change with realistic data in the Development base first
    • Before you make the field type change in the Development base, ensure there are some realistic values for the data in the field in the Development base. After you make the field type change in the Development base, observe the effect on the data in the field in the Development base. If it matches your expectations, it is likely safe to publish this change as an update and apply the update to Managed App installations.
  • Duplicate the field in Managed App installations before applying the update from the Managed App
    • Before applying an update that includes field type changes to a Managed App installation, first duplicate the affected field(s) in the Managed App installation base (and ensure you copy all existing records to the duplicated field.) Then, after you apply the update from the Managed App, if the changes to the record data in the affected field(s) do not match your expectations, you retain a copy of the older data in the duplicated field(s).
I’m unable to map a field when substituting, as it does not appear as an available option. What might be occurring?
Often, when this occurs, a new field ("New field 2") is added to the base, resulting in a user being unable to properly map or utilize the intended field. The issue occurs because substitution is not supported for lookup fields of linked records during the field mapping step. As a result, these fields do not appear as options for mapping and are instead added as new fields in the base. This is expected behavior, and there is currently no workaround to enable substitution for lookup field types.
How do I prevent overwriting a child base's customized HyperDB sync filter when I push updates from a managed app to child base?
Whether a push touches a child base's HyperDB sync configuration depends on whether the managed app's HyperDB filter changed:
  • Managed app's HyperDB filter unchanged between publishes → pushing updates leaves each child base's synced-table configuration untouched, even if you're publishing other changes. (This is why routine pushes can go a long time without affecting child filters.)
  • Managed app's HyperDB filter changed and published → the push applies that new filter to every child base's synced table, including child bases whose filter was customized locally. In this case, the local customizations are not preserved — they're overwritten with the managed app's filter.
Re-customizing a child base after an overwrite restores its filter, but doesn't protect it from being overwritten again the next time the managed app's filter changes. To keep child filters stable:
  • Treat the managed app's HyperDB filter as fixed. As long as you don't change it on the managed-app side, future pushes won't disturb the children's customized filters.
  • For data that genuinely differs per child, add a separate unmanaged HyperDB synced table directly in each child base. Because it isn't part of the managed app, pushes won't touch it. (This matches the documented pattern of syncing the dataset and filtering inside Airtable, or manually adding unmanaged synced tables, when installations need different subsets.)
  • When you must change the managed app's HyperDB filter, plan to re-customize the affected children as part of the same release.
  • Avoid "Force push regardless of dependency conflicts" for routine updates, and after each push verify each child's sync configuration via Sync Activity to catch unintended changes early.
