Enabling two-factor authentication in Airtable
Plan availability | All plan types |
Permissions | No matter your permission level, you may choose to set up two-factor authentication for your account. |
Platform(s) | Web/Browser, Mac app, and Windows app |
Related reading |
Two-factor authentication adds a second level of authentication to your Airtable account login. So, in addition to your email and password, you will need some additional information or a physical device to support logging in. By choosing a 2FA, you can protect your user login from remote attacks that may exploit stolen credentials.
Two-factor authentication can only be set up in Airtable if you create an account using a password you've selected. Suppose you log in with a Google account. In that case, you can't set up two-factor authentication using the below instructions. Before enabling 2FA, please review our support article on Adding a password for the first time.
To enable two-factor authentication in Airtable:
Open your Airtable account overview.
Click the Set up two-factor authentication option below your account name and email.
You will now be asked to sign in again for security purposes.
If you don’t see this option, then the account has already been set up for two-factor authentication.
Click Enable.
Next, you’ll need to set up an authenticator app (Google Authenticator, Duo, etc.) that you can use to receive security codes without receiving a call or a text message or needing an internet connection. The page will generate a QR code to configure an authenticator app on your phone. We recommend you use an authenticator app that supports cloud backups of accounts stored within the authenticator app.
After configuring your authenticator app and entering a verification code, your account's two-step authentication is enabled, returning you to the 2FA configuration page. Make sure you save your backup codes securely to prevent losing access to your account.
Two-factor authentication backup options
If you've lost your phone and don't have cloud backups enabled for your authenticator app:
Visit the "Backup options" section of your 2FA page.
Click Show single-use backup codes.
After clicking "Show single-use backup codes," a list of 12-character backup codes becomes visible.
If you believe your list of backup codes has been compromised, you can regenerate the backup codes by clicking the “Regenerate” option at the bottom of the "Show single-use backup codes" section.
If you've lost your phone or can't receive or generate authentication codes, each can be used only once to access your account. Be sure to write these down or store them into a safe place.
Disabling two-factor authentication
To disable two-factor authentication from your account:
Click Update two-factor authentication below your account name and email.
Click Disable.
This is the same control you used to turn two-factor authentication on—its label changes from "Set up two-factor authentication" to "Update two-factor authentication" once 2FA is active. If you see "Set up two-factor authentication" instead, two-factor authentication isn't currently enabled on the account, so there's nothing to disable.
Changing your account’s authenticator app
First disable 2FA for your account
Click Disable.
Once your authenticator app is disabled, you can re-enable 2FA which will generate a new QR code for you to scan with the new authenticator app.
Resetting two-factor authentication after a lost device or account lockout
If you've lost access to your authenticator app or device and don't have your backup codes, you can regain access to your account through Airtable Support's identity verification process.
To request a two-factor authentication reset:
Open your Airtable home screen.
Click the question mark icon in the upper-right corner.
Click Contact support.
Describe that you're locked out of your account due to lost 2FA access, and follow the prompts to verify your identity.
Airtable Support requires identity verification before resetting 2FA on your account. This process protects your account from unauthorized reset requests.
If your organization uses SSO, your identity provider (IdP) admin can manage and reset multi-factor authentication (MFA) on your behalf instead of going through Airtable Support. See our Enterprise SSO guide for details.
FAQs
I have another account that uses a phone number to receive security codes. Why isn’t that an option anymore?
We deprecated support of SMS security codes for new customers. Authenticator apps are a more secure way of supporting two-factor authentication. Suppose your account currently has a phone number associated with it. In that case, you can continue receiving codes via SMS, but you will not be able to change or update that phone number. Users with workspaces on paid tiers can still use a phone number to receive their security codes. You can permanently turn off two-factor authentication if you do not want to use an authenticator app.
Can two-factor authentication (2FA) be enforced for other users accessing my base or workspace?
Two-factor authentication (2FA) can only be enforced for Enterprise FAQs using SSO.
Why am I receiving the “Error submitting phone number; please try again.” or “Invalid phone number” message when attempting to authenticate?
There are two potential reasons for receiving the above error messages:
If a phone number is entered incorrectly 3 times, users are required to wait 24 hours before trying again due to daily 2FA limitations.
Due to changes in restrictions, we cannot send SMS to numbers based in Singapore or Russia
Why am I receiving the error message “Failed to load QR code” when attempting to enable 2FA?
The error message "Failed to load QR code" usually means you have exceeded the limit of 3 authentication requests within a 24-hour period. If you’re still unable to to access your code after 24 hours, please reach out to our support team.
I set up two-factor authentication (2FA) but lost access to my second authentication method. What can I do?
If you can no longer access your second authentication method, click the "Problems getting an authentication code?" error message.
This link will allow you to view all of your options for authentication. If you saved the backup codes provided when you set up 2FA, you can enter one by selecting Use a backup code.
If you are still unable to access your account, see the "Resetting two-factor authentication after a lost device or account lockout" section above.
How often does Airtable require me to sign in using my 2FA?
After entering your 2FA code, Airtable trusts your browser session for a period. You won't be asked for your code on every login. Instead, you'll be prompted again when your session expires or when you sign in from a new browser or device.
For Enterprise Scale and Business plans: Admins can configure a fixed web session length in the admin panel under “Settings.” When session length is reduced, users will be re-prompted for 2FA more frequently.
For all other plans, session duration is automatically managed by Airtable. If you've recently signed in, you may not be prompted for your 2FA code when you visit Airtable again in the same browser.
Why am I stuck in a loop between enabling 2FA and the authenticator app setup page?
If you click Enable and reach the QR code page, but after entering your verification code you're returned to the "Set up two-factor authentication" page with 2FA still showing as disabled, one of the following is likely happening:
Incorrect verification code - The code you entered may have already expired. Authenticator app codes rotate every 30 seconds—wait for a fresh code and try again immediately after it appears.
Clock sync issue - Authenticator apps use your device's clock to generate time-based codes. If your device's time is even slightly out of sync, codes will be rejected. Make sure your device is set to automatic (network-based) time.
QR code expired - If you left the QR code page open for a long time before scanning, the setup session may have timed out. Close the page, return to your Airtable account overview, and restart the setup from Set up two-factor authentication.
Rate limit reached - Airtable limits authentication attempts to 3 within a 24-hour period. If you've made multiple failed attempts, wait 24 hours before trying again.
If you complete the steps above and still can't get past the authenticator app setup page, contact Airtable Support by clicking the question mark icon in the upper-right corner while logged into Airtable and selecting Contact support.
