Airtable domain federation and verification
Plan availability
Business and Enterprise Scale plans only
Permissions
  • Enterprise Hub accounts: Super admin
  • Non-Enterprise Hub accounts: Admin
Platform(s)
Related reading
Airtable terminology
  • Domain verification - The process through which enterprise organizations verify ownership of their associated email domains.
  • Domain verification code - Domain verification code - The code that needs to be added to the domain's TXT records in the admin's DNS host to verify a domain.
  • Organization member - A user who is managed by an enterprise admin.
  • External domain - An email domain that doesn’t currently belong to an organization.
Accessing domain settings in the admin panel
The "Security & compliance" tab in the admin panel lets admins do things like configure SSO and add, remove, and verify domains independently. Verifying domains through DNS is an industry-standard practice that helps reduce risk while empowering IT admins to manage their enterprises' domains.
To open your enterprise’s domain settings in admin panel:
  1. Open your admin panel.
  2. Click Settings.
  3. Click the “Security & compliance” tab.
Managing email domains and SSO configuration
The “Email domains and SSO configuration” section in the admin panel features the domain verification code and a table detailing in-use domain names, subdomains, and more.
If your organization owns multiple domains, you don’t need to re-enter SAML metadata for each one: when setting up SSO on an additional domain, select Use existing SSO configuration to share the identity provider already configured for another of your domains.
To add and verify a domain, you must be an admin on a Business or Enterprise Scale plan and have access to the domain’s DNS TXT record.
To add a domain in admin panel:
  2. Click Settings.
  4. Click + Add domain.
    1. A window opens, asking you to enter your desired domain.
  5. Copy and save your “Domain verification code.”
  6. Confirm Add domain.
    1. Your newly added domain’s status will now appear as “Verifying.”
To verify a domain in admin panel:
To verify your domain, the DNS TXT record must be added to the root or main domain, not to a subdomain like airtable-verification.yourexampledomain.com.
  1. After adding a domain, copy your “Domain verification code.”
  2. Create a new TXT record in your DNS host with these settings:
    1. Type: TXT
    2. Name (sometimes labeled "Host"): the domain you added in admin panel—usually your root domain, such as yourexampledomain.com. Depending on your DNS host, you may enter @, leave the field blank, or enter the domain itself. Don't enter airtable, airtable-verification, or any other text in front of the domain—that creates the record on a subdomain, where Airtable doesn't check for the code.
    3. Value: your full domain verification code, exactly as it appears in the admin panel, including the airtable-verification= prefix.
  • If the domain's status in admin panel continues to show it as “Verifying,” it's likely because Airtable reviews the code, which can take up to 72 hours.
  • If your DNS host shows a duplicate-record error because your root domain already has a TXT record, don't move the record to a subdomain. Instead, add the verification code as another value on the existing root-domain TXT record. Other TXT values on the root domain, such as SPF records, don't affect verification.
To delete a domain in admin panel:
  2. Click Settings.
    1. Your full list of authorized domains appears on this tab.
  4. Click the trashcan icon next to the domain you want to delete.
  5. Click Delete domain.
Troubleshooting domain verification
If you are having trouble verifying an email domain, please check the following:
  • The email domain has been added in your “Email domains and SSO configuration” setting and is spelled correctly.
  • The email domain has a status of “Verifying.” You can update a domain to this state by clicking the “Verify” button in the “Status” column. Airtable doesn’t attempt to verify domains until they are in the “Verifying” status.
  • The Airtable verification code is present in the domain’s TXT records. This can be checked using a tool like Google Toolbox, and you should see a TXT record with a value that matches your domain verification code (i.e. "airtable-verification=XXXX"). Depending on the TTL value of the TXT record, changes made to the record could take some time to be published everywhere, and the email domain may take up to 72 hours to become verified.
  • If the domain stays in the "Verifying" status (unverifiedRectifying) for more than 72 hours, Airtable hasn't found the verification code in the domain's own TXT records. Usually, the record was created on a subdomain—such as airtable-verification.yourexampledomain.com—instead of the root domain, often because the DNS host rejected a second root-domain TXT record with a duplicate-record error.
    • To resolve, delete the TXT record from the subdomain and add the code as another value on the root domain's existing TXT record.
    • If Airtable doesn't find the code within 14 days, the domain returns to unverified, and you'll need to click Verify next to the domain again.
FAQs
What happens if I don’t verify my domain?
  • For customers on domain capture, unverified domains are disabled until verified, meaning all users on an unverified domain are treated as external users and can’t be converted to Organization members.
  • For customers not on domain capture, domains are unverified until Airtable validates the DNS record.
    • As a result, admins must request to manage user accounts that need to be added to the organization. This can be done from the overflow menu on the Users page of the admin panel.
  • SCIM can’t provision users, and SSO can’t be configured for disabled domains.
  • If sign-in with SSO is required, but an organization’s domain still needs to be verified, only organization members will be required to sign in with SSO.
    • When requiring SSO, users must consent to becoming organization members until you verify the domain.
What happens when I delete a domain?
  • User accounts hosted on that domain will no longer be organization members.
  • Admins will lose administrative rights over user accounts hosted in the deleted domain.
  • Any deleted domain must be verified again to re-add to your Organization.
Who should I contact with questions about DNS and domain federation?
We recommend contacting your IT department or IT admin for account-specific questions about DNS or domain federation. For general questions, please contact our support team.
How do I manage my individual DNS records?
Individual DNS record information isn’t something Airtable can provide support for. Please get in touch with your IT admin/team or review your host’s documentation for more information
Can I verify the same email domain for two separate organizations?
Yes, in most cases. Each organization has its own verification code, and both codes need to be published as separate TXT records on the domain.
The exception is domain capture: a domain can’t be added to an organization that uses domain capture if another organization already holds it, and it can’t be added to a second organization if the organization already holding it uses domain capture. This applies even if the other organization has added the domain but not yet verified it. Because Enterprise Hub requires domain capture, organizations on Enterprise Hub can’t share a domain.
Do I need to keep the airtable-verification TXT record in my DNS after my domain is verified?
Yes, keep the airtable-verification=… TXT record in place. Don't delete it once the domain shows as verified. Why:
  • 🔁 Verification is renewal-based, not one-and-done. Airtable will continue periodically checking their DNS record to renew their verification status, and there are dedicated verifiedFailedLastRenewal and verifiedFailedLastRenewalRectifying states, a "Verify" affordance that reappears in the admin panel for admins, and a "verification attempt expired" email sent. The TXT record is modeled as ongoing proof of ownership.
  • 🔑 One code covers everything on the account. verificationCode lives on the enterprise account, and a parent domain's TXT record also satisfies its subdomains — and any domain you add later reuses the same value. Removing it means putting it back before the next domain can verify.
  • ⚠ Losing verified status isn't cosmetic. Verification is what unlocks fully managing user accounts on the domain; autoclaim / domain-capture are enqueued when a domain flips to verified, and unverified domains get an explicitly "degraded enterprise experience."
If it ever does lapse, then re-add the same TXT value and click Verify again in the admin panel. You get a 14-day window for the check to succeed, and the in-product copy warns DNS propagation can take up to 72 hours.
Do external SSO users need a verified email domain?
Your organization needs a verified domain for the SSO configuration used in the email-attribute setup. External users’ own email domains do not need to be verified by your organization.
For example, an IdP configured under example.com can authenticate an external user at partner.example. The user remains external after linking; they do not become an organization member through that link.
Does a different NameID change domain capture?
No. The SAML NameID identifies the person during SSO. The email attribute provides their Airtable email address. Domain verification establishes your organization’s ownership of a domain, and membership settings determine how eligible accounts become organization members.
Using an employee ID as the NameID does not verify a domain or change its capture rules. For Enterprise Hub, work with the root organization’s administrators; an org unit cannot independently capture a domain.
