This article covers using the DATETIME_DIFF() to calculate the difference between two different date times in specified units to streamline your team's and organization's work.
Introduction
All plan types | |
Platform(s) | Web/Browser, Mac app, and Windows app |
Related reading |
DATETIME_DIFF() in Airtable overview
DATETIME_DIFF() overview
NOTE
If no unit is specified, or the specifier is not recognized by the function, then the output will default to seconds. If the unit specified is not recognized, the output will default to milliseconds.
The DATETIME_DIFF() function will allow you to calculate the difference between two different datetimes in specified units. Each specifier has a corresponding abbreviation which will work the same as the longform version of the specifier, e.g. DATETIME_DIFF(Date, Date2, 'y')
will have the same output as DATETIME_DIFF(Date, Date2, 'years')
supported DATETIME_DIFF() time units and specifiers
NOTE
If you're looking to use workdays as a unit for DATETIME_DIFF(), you may want to use the formula WORKDAY_DIFF() instead.
Unit specifier | Abbreviation |
'milliseconds' | 'ms' |
'seconds' | 's' |
'minutes' | 'm' |
'hours' | 'h' |
'days' | 'd' |
'weeks' | 'w' |
'months' | 'M' |
'quarters' | 'Q' |
'years' | 'y' |
NOTE
When attempting to use
DATETIME_DIFF()
with static dates or dates that are formatted as strings you will want to nest theDATETIME_PARSE()
function within your formula in order to turn the string into a readable date on Airtable's backend. Example:DATETIME_DIFF(DATETIME_PARSE('12/31/2021', "M/D/YYYY"), {Start Date},'d')
